AIR FILTER REPLACEMENT
Salman
Post by Salman »
Hi i just changed the original air filter with k & n air filter but when i took the cover out there were 3 little pipes that was connected to the original air filter cover,, i put the k & n air filter and i dnt no what to do with those 3 little pipes some1 help me please.
whitegtipolo
Post by whitegtipolo »
they only go one way LOL :lol:
Salman
Post by Salman »
what you mean?
LeMeph
Post by LeMeph »
im guessing you swapped for a cone filter. If you did that then theoretically you need to filter the air going into those three pipes (as thats what your standard airbox was doing already, as you could probably guess. This means you need to add filters to those pipes for them to work correctly. Aka diddy little oil breather filters.
If im wrong someone please correct me. If not ym ego shall balloon, coz i is so cleva. init.
whitegtipolo
ahh i get ya now i thought you fit a panel filter LOL, you need a little filter for the black pipe and thats all you should have extra it is a gti isnt it??
Salman
Post by Salman »
hmm that means i need to get a new air filter pipe with holes on it so i can connect those oil breathers to the air filter, would anything happen if drive like this for couple of days?
Salman
Post by Salman »
no its not a GTI :) its x rage polo 1.0 :$:D lol and where can i get those little filters?
whitegtipolo wrote:ahh i get ya now i thought you fit a panel filter LOL, you need a little filter for the black pipe and thats all you should have extra it is a gti isnt it??
monk
Post by monk »
http://www.knfilters.com/search/product ... od=57-0569
this is the kit for the gti, which includes the small filters... send an email to k&n and see if they fit your engine.
alexperkins
Site Admin
Post by alexperkins »
lol for the MK5 1.0E, there are two/three pipes depending on the engine you have. The one far left needs a filter. The one at the front needs a one way valve only letting things in or you will lose a good amount of oil very quickly, and the other one....well...that must be on a recirc valve or something so it might need a filter
Can you take a photo mate
Salman
Post by Salman »
yes these are the pictures of the pipes.
alexperkins wrote:lol for the MK5 1.0E, there are two/three pipes depending on the engine you have. The one far left needs a filter. The one at the front needs a one way valve only letting things in or you will lose a good amount of oil very quickly, and the other one....well...that must be on a recirc valve or something so it might need a filter
whitegtipolo
the top one is a breather so can add a small filter to that at the rockercover loose the pipe, second is for the air pump to the exhaust same with that, third one looks like another breather add a filter to that like these
http://shop.ebay.co.uk/?_from=R40&_trks ... her+filter
best if you loose the pipes and connect the filter direct to where they from it will be tidy!!
Salman
Post by Salman »
hmmm ok, i know what i need to do now, thanks for everything...
alexperkins
Site Admin
First needs a one way valve as said above - break this out the airbox.
Second needs a one way valve - out the airbox
3rd needs a breather filter
If you dont do it that way, you will lose oil bud
LeMeph
Post by LeMeph »
alex seems pretty certain mate id do it. i wish i could help but the fact your airbox has mroe then one breather pipe has stumpd me lol. these new fuckign cars and theyre technology....
whitegtipolo
i know they are stupid now LOL!!! :lol:
