newbie to uk polo
timmywills17
newbie to uk polo
hi mate,
welcome to the forum. It sounds like one of the vacuum/air lines is damaged.
the central locking pump is in the boot on the right hand side (where the 1st aid kit should be)
take it out and check to make sure all pipes are correctly inserted...
The central locking pump is a black box with a cylinder shape on top of it.
timmywills17
thanx
timmywills17
help
yosin wrote:i had the samee problem..one of the pipes wasnt correctly inserted...sorted it out but now its happening again but the whole central locking system aint working..
any ideas?
wot do u mean the whole central locking does not work? can u still open the car?
timmywills17
any1
does anyone know if this prob can b solved by buying a remote cl kit?
timmywills17
kool
might jus do that its just that i was plannin on getting the remote cl kit that gives u headlight flash and dat beep sound do i still need da vacuum pvmp fixed?yosin wrote:timmy: try going to the garage they would sort it out cos i had the same problem, it would be cheaper than buying a whole cl kit![]()
cost me like 20 bucks to sort that out
randomage
the vacuum pump is what works the central locking so yeah you will need it. i had this problem when i first got my car, turned out someone had unplugged the pump from the electrics! when we plugged it back in, we found out why.... theres a leak in mine somewhere so when i lock it, it keeps whirring for about 30 secs. the look on peoples faces when i walk away from my car, whirring like mad is totally priceless!
lee s3 plo
