Hazy Headlights
BobbyG
Hazy Headlights
Post by BobbyG »
Hi all,
My headlight lenses are looking hazy and discoloured, almost as if someone's gone at them with a brillo pad!
Anyone got any advice as to a product that will sort it? Will T-Cut do the job or is it too abrasive?
Cheers,
Polo96CL
Re: Hazy Headlights
Post by Polo96CL »
Probably a good idea to use something more suited to the job, you might make them worse with an abrasive.
tegwin
Re: Hazy Headlights
Post by tegwin »
The guys on the detailing forum use a rotary polisher and coarse polishing compound... but I wouldnt want to do it myself... very easy to cock it up!
alexperkins
Site Admin
Re: Hazy Headlights
Post by alexperkins »
meguiars plast-x and a machine polisher should do the trick ;)
Tim_GTi
Post Whore
Re: Hazy Headlights
Post by Tim_GTi »
Yep machine polisher is a must to get it out properly.
Scratch-X is good, along with any other high abrasive polish. where are you located?
BobbyG
Re: Hazy Headlights
Post by BobbyG »
London at the moment, but I won't be doing anything to the car until I move up north in a month or so!
Would a drill mop work?
Tim_GTi
Post Whore
Re: Hazy Headlights
Post by Tim_GTi »
Maybe, if you had a high abrasive pad.
When I mean high abrasive, I mean a compound pad like this.
That won't fit a mop drill, but if you get something along those lines I can't see why it wouldn't do the job just fine.
M54 SINGH
Re: Hazy Headlights
Post by M54 SINGH »
g3 compound will do the trick... try not to rub too hard thou at it may scratch it up
