Remote central locking. How easy to fit?
Re: Remote central locking. How easy to fit?
maplins. they need to be red and not blue - blue is too big.
The ones using are red. But they are feel so cheap. Lol
Screwfix used to do really good quality ones they may still do
- Mart!n-GTI-DK
- Platinum Member
- Drives: '14 Polo BlueGT
I just fitted remote to my central locking...
I can highly recommend the Cobra 1046. It can be ordered as a model specifictly med for the mk 3 Golf. And therefore also all other models using the same vacuum powered central locking.
http://www.cobravehiclesecurity.co.uk/p ... -1046.aspx
The only thing needed to fit it is to remove the plug from the vacuum pump and plug the remote module in between and connect 2 wires (that are color coded as in the car) to the indicators behind the taillights.
Check out the installation manual her: http://www.stylingshop.dk/cgi-bin/uploa ... _Golf3.pdf
This system could be fitted as an option when buying the car from the dealer.
AND it the car is fitted with electric windows with comfortmodule this system cam also open and close the windows when locking and unlocking.
- red6n2
how horrible are those keys though !
mk4gtiturbo
I'll be fitting an rclick kit to the Polo shortly, are the red connectors supplied with the kit ok or do I need to get some better quality ones? I don't really want to have to leave the car in pieces while I get more bits!
i used a set of the red connectors supplied recently and had no problems
I found I didn't have enough of them. Also there not straight push on clips. I had to make a slice in the insulation of the wires to get a contact
i know this is an old thread..... can you please direct me on which one is the correct one for my 6n2 please
on my key it has a HAA code.. bt r click doesnt seem to have it
will this be ok for me?
http://www.rclick.co.uk/product_info.ph ... cts_id=398
any help much appreciated people!
HU66 is the key you need. You have a worm laser cut key yes?
And yes thats the correct kit
yep worm laser cut key mate... so that is correct yes?
nice one... thanks again mate!
hello ther people.... got a lil issue with the r click.... the lock/unlock works fine... but i cannot seem to get the incdicators working when i lock it... i connect the brown to the blck/green (on drivers side) and nothing.... do i have to connect the passangers side aswel for them to work?
im abit confused on this... any help asap would really help....
thanks in advance
thanks in advance
connect both brown wires as per this guide http://www.uk-polos.net/view ... 10&t=47102
