Stupid fog light question
bango690
Post by bango690 »
I have just naught the honey comb grills and a pair of fog lights for me 6n2.
Question is, can I wire up so they come on with the side lights?
cornishdrummer
Re: Stupid fog light question
Post by cornishdrummer »
Seeing they are fog lights, i.e ment for fog the idea of this would be ?
red6n2
Post by red6n2 »
i agree with cornishdrummer mate... cant really see much point fogs are fogs and have a seperate switch for a reason
bango690
Post by bango690 »
I like the look I presume the wires are there to connect up
cornishdrummer
The wires are already there to fit into the back of the fogs yes, and are joined to your head light swtich, which if you are/were going to use them just for fog reason you would need a new switch.
I know with some cars you can get normal lights, that look like fogs, but not sure if you can with a 6n2
bango690
Post by bango690 »
Ok thanks for the replies will make do with normal use
cornishdrummer
At the end of the day its your car, you can do what you like.
red6n2
Post by red6n2 »
also agree mate its your car do with it what you want dont let us persuade you either way
the way i see it is driving with fogs on can get you pulled over if its not foggy and if a copper tells you to turn them off what would you do ? take out your sidelight fuse ?, then you have no side lights,
also i dont think wiring them up would be great for an MOT
bango690
Post by bango690 »
I ould put a online switch on to turn off when needed
cornishdrummer
Would you be able to get away with that on an mot tho ?
red6n2
Post by red6n2 »
bango690 wrote:I ould put a online switch on to turn off when needed
you mean like the on off switch already in place ? lol
cornishdrummer
But its only right if you want to use them wrong tho lol
red6n2
Post by red6n2 »
basically what you want i think is to have fogs and sides on without having your mainbeams on ?
first thing you need to find out is... are they on the same loom, im guessing they are as they are both applied by the same switch so is it just a case of bridging a connection between earylu sidelight to late fog ?
by the way i know very little about car electrics, :D
cornishdrummer
red6n2 wrote:basically what you want i think is to have fogs and sides on without having your mainbeams on ?
It prob could be done, someone might all ready of done it.
Have a look around you might find some more info.
alexperkins
Site Admin
Post by alexperkins »
Fogs and sidelights can be put on easily - turn to sidelights and pull it out one notch
Point to note is, it is illegal to use foglights when it is not foggy and there is a hefty fine for this too. A mate of mine was pulled recently for it
Plus, personally, I think people who drive with foglights on when its not foggy are bloody stupid in all honesty - theres nothing cool about glaring other road users
If you want to do it properly, get DRL certified bulbs from Hella and replace the fog unit completely with them.
