6n2 gti windows
Skandy
6n2 gti windows
Post by Skandy »
Hi Pretty much every time I turn my car on and the passenger side window go's down on its own I can put it up a again put it Jst go's down and up as it pleases? I've tested all the plugs and wires they are fine any have a idea? Could it b a relay?
greypolo9n3
Drives: white 6r 1.6 tdi rline/gti
Re: 6n2 gti windows
Post by greypolo9n3 »
Skandy wrote:Hi Pretty much every time I turn my car on and the passenger side window go's down on its own I can put it up a again put it Jst go's down and up as it pleases? I've tested all the plugs and wires they are fine any have a idea? Could it b a relay?
get in the car start it up and hold left and right buttons up for 2 seconds, that reprograms the system and they should be okay
alexperkins
Site Admin
Re: 6n2 gti windows
Post by alexperkins »
Its likely you have a damaged wire between the door and body, or the window switch has failed. Try unplugging and swapping the window switch with the drivers one and see what happens.
