Subwoofer
helloimjammie
Subwoofer
Hey guys
Just wondering if anyone has managed to install a subwoofer into the polo, still using the standard RCD 510 head unit, is it possible yes/no? Is it worth it yes/no?
- benhowarth6
Re: Subwoofer
Hello,
Yeah I've managed to do it in mine using an RCD 510, required using scotchlock connectors to splice into the wires and then to an RCA adapter as the RCD 510 doesn't have RCA outputs. Then wired it all to the boot so the interior looks completely stock.
Here's my thread anyway: http://www.uk-polos.net/view ... 56&t=60727
Hopefully that will help!
helloimjammie
Subwoofer
What did you manage to do for the remote wire?benhowarth6 wrote:Hello,
- benhowarth6
Re: Subwoofer
I used the cigarette lighter in the boot, pulled it out of the side panel then spliced into the 12V cable in that, works a treat, only live when the ignition is switched on. Took a while to figure that out.
- Mart!n-GTI-DK
- Platinum Member
- Drives: '14 Polo BlueGT
Re: Subwoofer
Why not install this original Helix sub and 300W amp? It's a plug-n-play system.
http://www.ebay.co.uk/itm/Volkswagen-Pl ... 1113379240
- benhowarth6
Re: Subwoofer
Isn't that only available on the MK7 Golf? Wasn't aware this was available for the Polo's, and not too sure how you'd connect it to an RCD 510 since there is no other outputs or inputs etc? I also believe if there was any way to retrofit these it would require coding to add the DSP? I'm guessing the new head units in the MK7 are the only ones compatible with this? However I may be wrong...
helloimjammie
Subwoofer
I'd be interested in that if it was plug and play on the polo!Mart!n-GTI-DK wrote:Why not install this original Helix sub and 300W amp? It's a plug-n-play system.
Re: Subwoofer
I have an Alpine SWE-815 fitted into my R Line by Dan at Unique Audio And Styling in Llanelli (01554 755749).It has improved the sound 100%.It's a fantastic bit of kit and does not cost the earth either,I really can't reccomend this sub highly enough read the review on talkaudio.co.uk.
- greypolo9n3
- Drives: white 6r 1.6 tdi rline/gti
Re: Subwoofer
thats 8 inch...isnt it a bit small?...say you felt like one day being a bass junky..would it satisfy?mark68 wrote:I have an Alpine SWE-815 fitted into my R Line by Dan at Unique Audio And Styling in Llanelli (01554 755749).It has improved the sound 100%.It's a fantastic bit of kit and does not cost the earth either,I really can't reccomend this sub highly enough read the review on talkaudio.co.uk.
Re: Subwoofer
Plenty of bass for me,especially when running standard head unit and speakers.
- greypolo9n3
Re: Subwoofer
hmm but you can get good 12" ones for that price...mark68 wrote:Plenty of bass for me,especially when running standard head unit and speakers.
I do like the remote bass controller idea though
Re: Subwoofer
Another plus is that it fits neatly on the split boot shelf and tucks itself just under the parcel shelf.
- Ben90
- Drives: Olympian Blue Polo TDi Sport
Re: Subwoofer
I've got the SWE-815 as well, I'm no bass junkie either but it's still really good at adding depth and bass where the stock system lacks. It also doesn't take up much space in the boot being about half the width of a normal sub. There's a handy wired remote with gain and Low pass filter and even a phase switch which sits beside my handbrake.
If you shop around you can pick it up for about £87.
Review
Review
helloimjammie
Subwoofer
Hmm seems to be exactly what I'm looking for tbh! Thanks for the suggestions guys!Ben90 wrote:I've got the SWE-815 as well, I'm no bass junkie either but it's still really good at adding depth and bass where the stock system lacks. It also doesn't take up much space in the boot being about half the width of a normal sub. There's a handy wired remote with gain and Low pass filter and even a phase switch which sits beside my handbrake.
Review
I'm fine with fitting subs and everything. Just weird fitting it to a new car with a new system, quite anxious must admit
- greypolo9n3
Re: Subwoofer
im sort of double minded now...i might just go for a 12" but just keep it on low gain and get a universal remote for it....
hmmm help! lol
hmmm help! lol
