It's perfect.CNK wrote: This 7E0 BCM will be ok?
18.11.15, 0733 H80
CNK's Polo 6R 2.0 Shadow Blue
Re: CNK's Polo 6R 1.4
- CNK
- Drives: 6R
That's good news, thanks Fernando!ciclo wrote:It's perfect.CNK wrote: This 7E0 BCM will be ok?
18.11.15, 0733 H80
So I have right BCM, now
Could you tell me, if I need any new connectors?
I know only about additional wires (https://drive.google.com/file/d/0B2nv91 ... JXSnc/view)
Rear View Camera works great:
Thank you for your kind words, zarfieldzarfield wrote:I like your polo so much! i didn't expect this post comes from Poland, a remote mistery country for us!
i will view all your photos when i am back at home with my pad at hand~
The end of winter, so I replaced the wheels, now it's look much better.
Beautiful rims, the new looK is awesome.
Depending on what you are going to install in future (Bi-xenon, RLS, auto lights, HBA - mirror 8G1) the wirings can be installed in one way or another.
Initially you need the wirings to BCM Max (read again
090) and communication wiring between BCM and instrument cluster.
It would be very advisable to install 5K7 rain light sensor and 7E0 stalks in order to install these wirings, it requires redo DRL wiring in your 6R, and perhaps the front foglight wiring.
In this way everything would be perfect.
I have reviewed some of your posts on the forum but I am not able to find an image your fuse box. An image of the fuse box is essential.CNK wrote: Could you tell me, if I need any new connectors?
- CNK
- Drives: 6R
Hmm.. In future I'm going to install headlight washers, washer fluid reservoir and Bi-Xenon or LED headlights.ciclo wrote:Beautiful rims, the new looK is awesome.
I know only about additional wires (https://drive.google.com/file/d/0B2nv91 ... JXSnc/view)![]()
Initially you need the wirings to BCM Max (read again090) and communication wiring between BCM and instrument cluster.
Later (maybe next year?
My fusebox:
This afternoon I look your questions (email), I have not yet had time. This is a hell...
Do not worry that everything has a solution.
According to autoscan you sent me by email ...
... there is a problem in the new harness that you have installed, I think that communication wires not are connected properly. Maybe (not sure) the harness is not appropriate. Try to do an autoscan where it is possible read all units. Clear all DTC's if possible.
Please tell us a brief history (images, links) of how, when and why it was installed the new harnness.
However...
... try this new coding to activate the Voice Control
New coding: 00000440000000A10000
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0256
Revision: BF046001
Coding: 002200
Shop #: WSC 85046 004 02308
VCID: F0E9208223D4F99EEBD-80A5
3 Faults Found:
01304 - Radio
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 160
Mileage: 48124 km
Time Indication: 0
Date: 2003.14.19
Time: 01:00:20
01300 - Control Module for Navigation with CD-Rom (J401)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 160
Mileage: 48124 km
Time Indication: 0
Date: 2003.14.19
Time: 01:00:20
01303 - Telephone Transceiver (R36)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 160
Mileage: 48124 km
Time Indication: 0
Date: 2003.14.19
Time: 01:18:28Please tell us a brief history (images, links) of how, when and why it was installed the new harnness.
However...
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 R HW: 1T0 035 680 R
Component: RNS-MID H23 6276
Revision: AB001001 Serial number: VWZ6Z7P2234584
Coding: 00000440000000A20000
VCID: 3D7749B6A406C4F6B0B-8068
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V13 8348
No fault code found.New coding: 00000440000000A10000
- CNK
- Drives: 6R
These are old errors, when I removed RNS510ciclo wrote: ... there is a problem in the new harness that you have installed, I think that communication wires not are connected properly. Maybe (not sure) the harness is not appropriate. Try to do an autoscan where it is possible read all units. Clear all DTC's if possible.
However...... try this new coding to activate the Voice ControlCode: Select all
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb Part No SW: 1T0 035 680 R HW: 1T0 035 680 R Component: RNS-MID H23 6276 Revision: AB001001 Serial number: VWZ6Z7P2234584 Coding: 00000440000000A20000 Shop #: WSC 85046 004 02308 VCID: 3D7749B6A406C4F6B0B-8068 Subsystem 1 - Part No: 1T0 919 859 B Component: EU West V13 8348 No fault code found.
Today I clear CAN Gateway and it's ok, no errors
Thursday,14,April,2016,23:09:49:30570
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
VIN: WVWZZZ6RZCY019098 License Plate: NEW 14.04.2016 23:09
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 37 44 56 77
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 CN HW: 03C 906 024 BH
Component: CGGB MM4HV G 8994
Revision: --H09--- Serial number:
Coding: 0000071
Shop #: WSC 00788 648 00255
VCID: 6CD1B4F24CFC9D7E575-5072
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 210224E3216E00BB842524EB84D900401300
VCID: 871B6B5E325ADE265A7-80D2
Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326D6A8A6D580B8E5D9-8067
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0256
Revision: BF046001 Serial number: 0434 158110732
Coding: 3CB02BBF08F32400923808002C2B0CD100C0410F60040000200000000000
VCID: 45872156CCD68C36E8B-8010
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Coding: 08BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 4 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 1K8 951 171 A HW: K89 511 71A
Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Coding: 08BC32
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX00NXZLZ
Coding: 003232
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9D126AEDC8634E059-801F
Crash sensor for side airbag; driver side:
Serial number: 3575HRB40570INGS61HS
Crash sensor for side airbag; passenger side:
Serial number: 3585HRB405R0ILP041NW
Crash sensor for side airbag; rear driver side:
Serial number: 3515RRB404P0K4DOJGD6
Crash sensor for side airbag; rear passenger side:
Serial number: 3525RRB404P0K4DOM92Z
Part No SW: 6R0 920 870 CX HW: 6R0 920 870 CX
Component: KOMBI H05 0608
Coding: 140A00
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: 8D1759765C26B47660B-80D8
Revision: BF046001
Coding: 002200
Component: IMMO H05 0608
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EADD32EA0D08034EA59-80BF
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660186144
Coding: 010000
VCID: 295F8DE6408E4856EC3-807C
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F6B63FEEA6A2666327-807A
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: None
Part No SW: 3C8 035 730 E HW: 3C8 035 730 E
Component: Telefon 025 0983
Revision: -------- Serial number: 35502105249241
Coding: 020100010101010000000101
ASAM Dataset: EV_UHVPremi 002709
ROD: N/A
VCID: 254781D624966C36C8B-8070
No ASAM data for: "EV_UHVPremi" (VW25)
End ---------------------------------------------------------------------
The problem is with uncheck field Voice Control inactive...
I can't save any new coding with this option, maybe I should enter any access code?
I have alert "Coding accepted", but when I close controller and open it again, there is old coding with checked "Voice Control inactive" field.
I connect wires like this scheme:
Now it looks a bit clearer.
With this MFSW you have...
...and must be...
... so there is a communication problem between MFSW buttons and BCM.
By the other hand...
... maybe the problem to activate the Voice Control is in this coding and therefore you can not encode navigation module to enable Voice Control. Must be correctly coded telephone module, radio or radio-navigator, and MFSW buttons to work properly the Voice Control.
Maybe anyone can help us because I do not know how is coded this telephone module.
Coding: 000000Code: Select all
Subsystem 6 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Coding: A4FFFFBy the other hand...
ROD: N/A
No fault code found.Maybe anyone can help us because I do not know how is coded this telephone module.
- CNK
- Drives: 6R
Hmmm..ciclo wrote:Now it looks a bit clearer.
...and must be...
Coding: A4FFFF
I clear all DTCs and after many attempts of saving new coding i have some success..
I found this instruction: http://www.carsystems.home.pl/instrukcj ... 8%20EN.pdf
New coding:
I have tried many times activate the buttons MFSW, and finally it works. Same with Inactive Voice Control (http://www.my-gti.com/1234/volkswagen-r ... ce-control).
New log:
Friday,15,April,2016,18:19:54:30570
VIN: WVWZZZ6RZCY019098 License Plate: 15.04.2016_18.19
Mileage: Repair Order: Clear-all-DTCs
Coding: 0000071
Readiness: 0110 0001
Revision: --------
Revision: 0002S 02
Coding: 18BC30
Coding: 08BC30
Coding: 08BC32
Coding: 08BC32
Coding: 003232
Coding: 140A00
Revision: BF046001
Coding: 002200
Serial number:
Coding: 010000
Coding: 00000442000000A10000
Coding: 11250
Shop #: WSC 00788
Coding: 020000010100010000000100
ROD: N/A
- CNK
- Drives: 6R
Ok, I change language of my RNS510 to English, and now it works.. but only when I press star on RNS510.
Button in MFSW is strange and it does not work as it should: https://www.dropbox.com/s/akbxdqe8mdjle ... 8.mp4?dl=0
Any ideas?
PS. If it's possible to use english voice commands with set Polish language?
Any ideas?
An idea
Remove and isolate T41/11 wire from connector of the steering column, this wire is no longer necessary with multifunction steering wheel. It may be the cause of conflict between the buttons and bcm.
Try to coding subsystem 6 again. A4FFFF
Test the MFSW buttons and horn, and save the new Autoscan.
- CNK
- Drives: 6R
ciclo wrote:An idea:
Horn and buttons works, I will try to coding this on the new BCM.
Some new photos:
Willni
- Drives: Polo '14 6R, Golf 07' Edition 30
When are you doing the r-line bumper, I'd like to know what it looks like without sideskirts
- CNK
- Drives: 6R
But I bought sideskirts tooWillni wrote:When are you doing the r-line bumper, I'd like to know what it looks like without sideskirts
Without sideskirts it looks like a single stair between bumper and rest of car.
For example: https://scontent.fwaw3-1.fna.fbcdn.net/ ... e=572D24D1
Therefore will be soon, let's see what happens.CNK wrote: Horn and buttons works, I will try to coding this on the new BCM.
Do you have the three bags?
By the way, Krzycho's Golf can be one of the best in its class around the world, I like it
