numberior´s 2011 Polo 6R GTI DSG
Re: numberior´s 2011 Polo 6R GTI DSG
numberior wrote: Fri Oct 06, 2017 8:45 am Mods thus far:
-tilting side mirror for parking by external module control
Can you provide us with more information about this module, links, module image, etc? thank you in advance.
numberior
Drives: Polo GTI 6r
Post by numberior »
Hi Ciclo,
My pleasure...
I used these.
http://www.kptechnologies.com/docs/MT30 ... lation.pdf
On sensing reverse gear engagement, it feeds 12V to the tilting mirror motor.
When you shift out of reverse, the module tilts back the mirror to the original position, by feeding voltage in opposite polarity.
I chose this method as I do not have the tilt motor with memory, and it's also straight forward to implement.
You will also need to tap the reverse +12V.
I intercepted the wires at T12 connector.
So it's inferior to stock tilting mirror as it's simply tilting mirror by an amount of time.
After some weeks, you may find your mirror going out of position and needs fine positioning. This is likely due to voltage differences when the engine is running vs non-running.
I find using this DC-DC converter helps : https://www.digikey.com/product-detail/ ... ND/4488021 . I'm looking to implement a delay timer soon as the converter is supplied by battery currently.
I have actually installed 2 of these for my passenger side mirror: for left/right and up/down movement.
Then I programmed the left/right module to mode 1 and the up/down to mode 2(see the pdf above).
In mode 2, my mirror will tilt down only if I shift in sequence R(for about 1 sec)->D->R. The module tilts the mirror by sensing gear positions is especially attractive for me.
Ok, thank you very much for the explanations and info. :wink:
(http://kptechnologies.com/forums/viewto ... =41&t=1971)
numberior
Drives: Polo GTI 6r
Post by numberior »
Hi Ciclo, I've question on WL3.
I've ordered the switch with p/n: 6R0 941 531G APV, and fabricated WL3 exactly as in
"How to install 7E0937090B in 2011 Polo 6R non Bluemotion ‘H7’ halogen headlights (Pave).pdf".
From your previous post, I understand my car has some minor differences in wiring scheme at the dimmer and light switch.
To adapt the BCM Max you must follow this installation guide.
viewtopic.php?f=56&t=69826#p520951
Yes, there is some difference in the wires reaching the Light switch/Dimmer connectors.
- Blue / Gray = Yellow / Gray (T17 connector, and T6 connector)
- You must also remove/isolate the T17/6 original wire.
As for the Chinese automatic lights kit.
It is the old kit, in the new one the black box is smaller and it does not have the red wire (this red wire in old Kit is for the CH/LH functions - when connected to the blinker wire -).
If it does not work, remove it.
For auto lights it is best with original parts. (RLS, LSW AUTO, etc.)
I will remove the old switch with black box.
Will I be ok with the new light switch if I use WL3 as it is, and additionally isolate T17/6 ?
Yes. But at some point in our conversation I understood that you were not going to install the front fog lights...
... and the light switch you've ordered has the position for the front fog lights.
numberior
Drives: Polo GTI 6r
Post by numberior »
Hi Ciclo,
Sorry for the confusion.
I bought this in case I'm installing fog lamps in future.
For now, I will not. I'm ok with the switch not doing anything in the fog on position.
numberior
Drives: Polo GTI 6r
Post by numberior »
Hi Ciclo,
I've fabricated BCM Max wirings and installed them today. Kufatec's wiring have mostly been replaced apart for the T14-T10 adaptors.
After some coding, the xenon headlamps worked instantly as they should :D
I really appreciate your help!
Cornering lamps are working as well, just that left and right are reversed. I've coded module 19-> Byte 1 for RHD but that just corrected the MFD doors' statuses.
Should I just swap T73b/9 and T73b/10 ?
I haven't done ABS and xenon range initialization yet thus the errors below.
I'm not sure why "02: Auto Trans" is unreachable though. Will observe again when I'm done with the initialization.
Wednesday,18,October,2017,19:35:30:27502
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZBY312116   License Plate: 5TH SCAN
Mileage: 100070km-62180mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 55 56 0B
VIN: WVWZZZ6RZBY312116   Mileage: 100070km-62180miles
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAVE)       Labels:. 03C-907-309-V1.clb
   Part No SW: 03C 906 027 AR    HW: 03C 906 027 AR
   Component: 1.4l R4 TSI   H15 9971
   Revision: L2H15---    Serial number: 00000000000000
   Coding: 00250012002400000000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ECM14TSI01103C906027AR 001014
   ROD: EV_ECM14TSI01103C906027AR.rod
   VCID: 71E99E02A0C274CE75-8024
1 Fault Found:
4660 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [039] - -
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 100075 km
                    Date: 2017.10.18
                    Time: 07:31:52
                    Engine speed: 702.50 /min
                    Normed load value: 13.3 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 90 °C
                    Intake air temperature: 59 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 13.264 V
                    CAN status - engine control module-Bit 0: 0
                    CAN TimeOut meter - transmission-Bit 0: 0
                    Generator power: 0 W
                    CAN TimeOut meter - gateway-Bit 0: 0
Readiness: 1110 0101
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 230248E3416E02B4C42612E382D740811700
   Shop #: WSC 00788 648 00255
   VCID: 071DD0DAB2465A7ECB-8052
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
            005 - No or Incorrect Basic Setting / Adaptation
                    Fault Status: 01100101
                    Fault Priority: 0
                    Fault Frequency: 3
                    Reset counter: 0
                    Mileage: 100075 km
                    Time Indication: 0
                    Date: 2012.03.10
                    Time: 00:07:31
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x3019
                    Hex Value: 0x149E
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
   Part No SW: 6R0 907 044 E    HW: 6R0 907 044 E
   Component: Climatronic   H09 0609
   Revision: V0000000
   VCID: 35616A129C2A18EE69-8060
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 321160318
   Coding: 3CB02BBF08A10000083808F17C290CD0FFC067CF60051041200000000000
   VCID: 2A5B496E45944716F4-807E
   Subsystem 1 - Part No SW: 6R0 959 802 AB    HW: 6R0 959 802 AB  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  007 1611
   Serial number: KU0KU024031100012688
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 801 AD    HW: 6R0 959 801 AD  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  007 1611
   Serial number: KU0KU016031100015781
   Coding: 08BC30
   Subsystem 3 - Part No SW: 6R0 959 591 A    HW: 7P0 959 591
   Component: J245 PS72.015  H05 0006
   Serial number:     WOO1165901/
   Coding: 081001
   Subsystem 4 - Part No SW: 5K0 959 542     HW: 5K0 959 542
   Component: E221__MFL-TAS  H05 0010
   Serial number: 0050759
   Coding: 830000
   Subsystem 5 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  007 1611
   Serial number: KU0KU011041100017315
   Coding: 08BC32
   Subsystem 6 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  007 1611
   Serial number: KU0KU011041100013053
   Coding: 08BC32
1 Fault Found:
03906 - Control Circuit for High Beam Relay
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 100075 km
                    Time Indication: 0
                    Date: 2012.03.10
                    Time: 07:31:52
   Part No SW: 6R0 959 655 M    HW: 6R0 959 655 M
   Component: VW10Airbag01E H09 0020
   Revision: --------    Serial number: 003GZ000HCNK
   Coding: 003145
   VCID: 4C972FF6E7A0792626-8018
   Serial number: 3575HRB40550HJHG9ON%
   Serial number: 3585HRB40590HJHG919A
   Serial number: 3515RRB405B0I4AG6OGL
   Serial number: 3525RRB404R0H4DUHPLR
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6R0 920 870     HW: 6R0 920 870
   Component: KOMBI         H21 0320
   Coding: 140A00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
   VCID: 72EB910EA5C44FD68C-8026
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 002000
   VCID: 68DFF3669B18B50622-803C
1 Fault Found:
01304 - Radio
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 100075 km
                    Time Indication: 0
                    Date: 2012.03.10
                    Time: 07:31:57
   Component: IMMO          H21 0320
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6ADB896E8D14871634-803E
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 31414
   VCID: 2F6D587AEA76223E23-807A
   Revision: --------    Serial number: --------------
   Coding: 0114000001000000
   VCID: 77FDA01ACEA62AFEBB-8022
1 Fault Found:
5275220 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 100075 km
                    Date: 2017.10.18
                    Time: 07:31:51
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:52)--------------------------
I have a bugging problem now though: I cannot program the key fobs.
Factory mode is already disabled.
And I have reset Ch 0 in adaptation before attempting to program.
In Ch1, as soon as I enter '1' or '2', the "Test" and "Save" buttons grey out.
What can I do now?
Xenon range(55) coding: 0114000001000000
BCM(09) coding: 3CB02BBF08A10000083808F17C290CD0FFC067CF60051041200000000000
also tried graaja's BCM coding : 3AB02BBF08A10000013806917CEB96905AC0672F600D304120 0000030000
numberior wrote: Wed Oct 18, 2017 4:52 pm I have a bugging problem now though: I cannot program the key fobs.
What can I do now?
First most urgent:
You have to type 0 for all keys. (never 1,2,3 or something else)
Test, save and do the indicated process.
http://wiki.ross-tech.com/wiki/index.ph ... l_Matching
Now I check your autoscan and tell you what to do .... wait...
Gateway coding
002300
... wait for BCM coding :lol:
numberior wrote: Wed Oct 18, 2017 4:52 pm Cornering lamps are working as well, just that left and right are reversed.
Yes, do it.
numberior wrote: Wed Oct 18, 2017 4:52 pm I haven't done ABS and xenon range initialization yet thus the errors below.
Do it.
...wait ... :lol:
New BCM coding
3CB02BBF08A1000008380C916C2B0CD05AC0672F60051040200000030000
There may be faults due to the type of lamps you have installed for the various lights.
Check that 'Coming Home' works.
Post a new Autoscan.
Your DSG gearbox can be read by the VCDS individually by entering in address 02.
These DSG gearboxes of A/B model years communicate in a different way than the following manufactured models. Right now I can not check the Elsawin for diagrams ...
You can also customize the reading of all units when performing the VCDS autoscan (to show all units you want). Please talk to benzinkopf, I explained to him how to do it.
numberior
Drives: Polo GTI 6r
Post by numberior »
Hi Ciclo,
Thanks for your TREMENDOUS support.
I'm back to work today and will try your coding once I'm home.
I'm quite worn out from working on my car yesterday lol :mrgreen:
Will report back soon.
Thank you again.
numberior wrote: Thu Oct 19, 2017 10:28 am I'm quite worn out from working on my car yesterday lol :mrgreen:
as long as you enjoy it, it's ok!
numberior
Drives: Polo GTI 6r
Post by numberior »
Yesss...iichel, definitely.
BCM Max upgrade only opens the door to more such experiences! :lol:
Curiosity drives me to go down this route. And of course, knowing that Ciclo and you are around to help out.
numberior
Drives: Polo GTI 6r
Post by numberior »
Hi Ciclo,
Update:
I've done the following:
1) Keyfobs successfully programmed :)
2) Corrected CAN Gateway coding
3) Performed basic setting for ABS
4) Performed basic setting for xenon range module. I haven't align beam pattern properly yet.
For now, I'm just doing basic setting to clear the DTC.
5) Tried BCM coding as per your instruction
When I switched off engine, the cabin light is on until I leave the car and locks the car by remote.
When I unlock the car by remote, cabin light comes on, then turns off when ignition on.
I did not know at time of testing to observe the headlight and tail light also. Was not familiar with this feature.
Will observe again tomorrow.
Latest scan gave error on reverse lamp diagnostic, which I find strange as diagnostics for backup lamp is already disabled.
It comes back even after clearing the DTCs.
I'm using full LED taillights https://item.taobao.com/item.htm?spm=a1 ... uav4oqe1eb
by the way.
Another error is related to xenon range module.
I'm using LED H7 bulbs https://www.philips.com.sg/c-p/12985BWX ... light-bulb for the cornering lamps.
I can change them out for halogen if required.
Regarding our bi-xenon headlamps: will they perform a up/down sweeping range check each time the engine is started?
Because I don't see them doing it, even after xenon range basic setting is accepted.
Latest autoscan:
Thursday,19,October,2017,23:36:14:27502
www.Ross-Tech.com
VIN: WVWZZZ6RZBY312116   License Plate: 8TH SCAN
Mileage: 100140km-62224mi   Repair Order:
VIN: WVWZZZ6RZBY312116   Mileage: 100140km-62224miles
Cannot be reached
   Revision: --------
   Revision: V0000000
   Coding: 3CB02BBF08A1000008380C916C2B0CD05AC0672F60051040200000030000
   Coding: 18BC30
   Coding: 08BC30
   Coding: 081001
   Coding: 830000
   Coding: 08BC32
   Coding: 08BC32
1 Fault Found:
00901 - Back-Up Lamps
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 4
                    Mileage: 100145 km
                    Time Indication: 0
                    Date: 2012.03.11
                    Time: 23:16:21
   Coding: 003145
   Coding: 140A00
   Revision: B9081001
   Coding: 002300
1 Fault Found:
01304 - Radio
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 4
                    Mileage: 100145 km
                    Time Indication: 0
                    Date: 2012.03.11
                    Time: 23:16:26
   Serial number:
   Coding: 11230
   Shop #: WSC 31414
1 Fault Found:
5275648 - Left/Right Driving Switch-Over Active
          C1080 00 [009] -  -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 4
                    Mileage: 100145 km
                    Date: 2017.10.19
                    Time: 23:31:50
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 03:01)--------------------------
Again, thanks for your help Ciclo :o
