The engine only occasionally cuts out when accelerating and loses all power steering and brakes along with it. Nothing on the dash is lit up other than the battery icon.
Once it does this it can start first time or sometimes take 3/4 tries before it fires and runs properly.
At other times it will continually crank for 10/15 seconds before anything happens at all.
The fuel pump does not prime every time I turn the key.
Scanned the ecu with my OBD11 device and also with VCDS but no faults appeared at all.
I’m going to try a new fuel filter as I can’t see it’s been changed at all in the service history, just hoping I can get it sorted as am planning to sell it next month.
Any help or suggestions will be greatly appreciated
