Polo engine noise
Polo engine noise
Good afternoon fellow polo owners,I have a 2017 1.2 Tsi bluemotion model but when you pull away, I get a noise coming from the engine but sounds like the air filter is blocked.I only get it on the initial pull away so would like to ask fellow owners as to what this may be.
Your help and advice is much appreciated.
Re: Polo engine noise
No replies anyone,I have asked VW and their answer was ???.
Andy Beats
Everyone is probably as lost as I am when you say "noise like the air filter is blocked"
I've genuinely no clue what is meant by this.
Might be worth posting a video.
- Black6c
- Drives: 6c 1.2 (110) TSI DSG
If I understand you correctly, maybe what you hear is what the engine suppose to sound like. I have a 1.2 tsi 6c and it does have a different sound, I would describe it as a 4 cylinder with a stuffed nose, a rather bassy growl when under load.
Yes, just that an increased load has been applied to the engine, so it is starting to work a lot harder, that is all.
I can understand the suggestion that it sounds a bit like a strangled air inlet - or a blocked exhaust!
Edit:- I think that this noise is best listened to from being some distance from the car as it is being driven away from a standing start on level ground, I'm only really aware of hearing it when I have been kind enough to be outside to close the garage door after my wife has driven her Polo 1.2TSI 110PS away after reversing out of the garage and up the steep long driveway - so the car is then position higher than my head/ears and so I can heard more of the noises normally supressed by other things!
wolfie
- Drives: 6R1-1.2 TSI (2011, CBZB, 77Kw)
Yeah I noticed this but since I've had the car such a long time I'd forgotten about it, just go used to it. As you say the 1.2Tsi sound a little asthmatic pulling away, it's actually quite slow off the mark in the first few yards compared to a normally aspirated 1.2, but once it's on the move it punches above it's weight and is generally pretty nippy. I simply put it down to turbo not really spooling up and doing it's stuff from very low revs. To me it also feels like first gear is very short and you just go through the rev range pretty quickly. Never really bothered me, I've reached an age where I drive like a granddad anyway.
The OP has the later belt driven 16V engine as their car is a 2017 model, so different characteristics.
wolfie
Cheers, missed that. Not paying attention as usual..RUM4MO wrote: Wed May 15, 2019 10:32 pm The OP has the later belt driven 16V engine as their car is a 2017 model, so different characteristics.
kasapovic75
- Drives: VW polo gti 2016
Yes, true. But send a video of the noise to compareBlack6c wrote:If I understand you correctly, maybe what you hear is what the engine suppose to sound like. I have a 1.2 tsi 6c and it does have a different sound, I would describe it as a 4 cylinder with a stuffed nose, a rather bassy growl when under load.
Sent from my iPad using Tapatalk
kasapovic75
I Got a racechip from racechip.com to the 1,2 tsi. Workes with the facelift 110h and the older 90h. Gives 25h/40nm. 100£wolfie wrote:Yeah I noticed this but since I've had the car such a long time I'd forgotten about it, just go used to it. As you say the 1.2Tsi sound a little asthmatic pulling away, it's actually quite slow off the mark in the first few yards compared to a normally aspirated 1.2, but once it's on the move it punches above it's weight and is generally pretty nippy. I simply put it down to turbo not really spooling up and doing it's stuff from very low revs. To me it also feels like first gear is very short and you just go through the rev range pretty quickly. Never really bothered me, I've reached an age where I drive like a granddad anyway.
Yes indeed that is how it sounds,only when you pull away though.Black6c wrote: Tue May 14, 2019 9:23 pm If I understand you correctly, maybe what you hear is what the engine suppose to sound like. I have a 1.2 tsi 6c and it does have a different sound, I would describe it as a 4 cylinder with a stuffed nose, a rather bassy growl when under load.
