Yesterday afternoon I was driving home from work, and when attempting to turn a bit of a sharp corner while on the brakes the steering went very stiff. Once I had passed the corner it seemed to be back to normal right up until I started to turn onto the front drive, when it went hard again until I was off the brakes.
I have since driven it to and home from work again and the steering it generally intermittent when driving, sometimes going slightly tougher and sometimes light, however whenever the brakes are applied hard it starts to go extremely stiff almost losing all power steering.
I’ve checked the battery voltage and it was 13.07v when not running and 14.30 when running so no trouble there, no lights on the dash, and I’m checking for codes tonight when I get home from work.
I have had a number of issues with the epc light coming on in the past month and had the brake switch code appear, and will be changing that switch tonight.
Any help will be appreciated as I would like to fix myself if possible.
