ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙‍♂️
Locked
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP
dcgumis wrote: Sat Feb 13, 2021 4:19 pm how do you like the new lamps? :) Your golf course is fully equipped :D :D :D 8)
At the moment I can only say that they are pretty 😂, just like my super wonderful Replica LED headlights.
I've only had time to install the new original 8IU LED headlights, this coming week I will do the coding, parameterization, adaptations, basic adjustments, installation adjustments and tests of the units involved in order to evaluate these new original Matrix Beam LED headlights. (VCDS, VCP and ODIS)
After connecting them without having done everything I just mentioned, and due to their first behaviors I have the suspicion that everything will work perfectly. 😊
Ready2Go.
It took me all day to collate, compare and store all the data so that everything works perfectly according to the current configuration of my wife's Golf ... 😅
(20, 29, 39, 4B, D6, D7)
Golf 7.5 Retrofitted Matrix 8IU LED headlights.
💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/rAm2jW4uo ... autoplay=1
1- Mercedes.
2- Left LED Headlight.
3- Right LED Headlight.
4- Low Beam.
5- Low Beam + DCLs activated.
6- High Beam.
7- 520 Maximum Lux ~ 2080 Lumen (7.62m = 25 feet). Low Beam!
8- Light Assist, DCLs.
9- Travel mode.
10- FPA Sport, DCLs.
11- Light Assist symbol on IC.
12- Presentation-Start.
VCDS Autoscan.
Thursday,18,February,2021,14:20:12:32438
VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
Data version: 20201125 DS322.1
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: MATRIX 8IU LED Headlights. FUNCTIONAL TEST OK!
Mileage: 34856km-21658mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 20 29 39 3C 42 44 4B 52 5F 65 D6
          D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 34856km-21658miles
29-Left Light -- Status: OK 0000
39-Right Light -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DKRF)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 L    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6198
   Revision: D7H20000
   Coding: 01190032234415082000
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_ECM10TFS01104C906025L 002003
   ROD: EV_ECM10TFS01104C906025L_002.rod
   VCID: 290F00D8897EC92304C-807C
Readiness: 0010 0000
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 DD    HW: 5Q0 614 517 AC
   Component: ESC           H25 0424
   Revision: 00000000    Serial number: 51998000000173
   Coding: 01FA6AA114202170477B060560CA2580562884E26006A4733420F00A4082430B00000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 76B51BA40840D6DB59E-8022
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Component: Climatronic   H04 1801
   Revision: 00001K08
   Coding: 00020003200110011005004000101022
   Shop #: WSC 00028 028 00068
   ASAM Dataset: EV_ACClimaBHBVW37X 006145
   ROD: EV_ACClimaBHBVW37X_006_VW37.rod
   VCID: 6D8734C87D161503A84-8038
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 DH    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H40 0312
   Serial number: 72007150025702
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020_VW37.rod
   VCID: 015F7878518EE1637CC-8054
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    180621  043  0551
   Serial number:         180705074106
   Coding: 0E4DDD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  052  0107
   Serial number: SBY18M08D06H04M32S34
   Coding: 06A8DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 507     HW: 5Q1 953 549
   Component: J527 SMLS MQB  004  0060
   Serial number: 00000002081804401346
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417318277
   Coding: 0271165841
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 51FF8838C16ED1E3ACC-8004
Address 13: Auto Dist. Reg (J428)       Labels:| 3Q0-907-572.clb
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0682
   Coding: 2B00678119FFC728949C810560400600000000000000000004
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   ROD: EV_ACCBOSCHVW416_002_VW37.rod
   VCID: 44D1B16C0E1C344B17A-8010
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4F1CUQ
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 00028 028 00064
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 094F605869BEA92324C-805C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169667E30071820325
   Coding: 333135
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169668E31071830145
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 307 18
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000F8745C23S
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 480 002 807 18
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000000EC18233G
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A729FD154210-
   Coding: 2D2D2D
   Subsystem 6 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001A929FD1515577
   Coding: 2D2D2D
   Subsystem 7 - Part No SW: -----------    HW: 480 402 306 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001A326704A3C63.
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         404 4191
   Coding: 07A52A802E88000801887A0D1401000000000000
   Shop #: WSC 00200 935 01530
   ASAM Dataset: EV_DashBoardVDDMQBAB 009058
   ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
   VCID: 2B03FAD08382DB33F60-807E
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 09012020001767
   Coding: 030100047F085700DB00025E080F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW37.rod
   VCID: 70B92DBC6A24F8EB832-8024
   Generator:
   Component: 4-01-02-01-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H18 0052
   Serial number: 39190002063230049307
   Coding: 2CFFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 9353818504
   Part No SW: 3G0 857 511 BD    HW: 3G0 857 511 BD
   Component: FLA           H01 0010
   Revision: AA001001
   Coding: 0404000000000000000000
   ASAM Dataset: EV_HighBeamAssisAU33X 001019
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 6B833AD043021B33B60-803E
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   ASAM Dataset: EV_LCMLeftHELLAAU736 001012
   ROD: EV_LCMLeftHELLAAU736_VW37.rod
   VCID: 47CBA6603F2A1F53F28-8012
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   ASAM Dataset: EV_LCMRightHELLAAU736 001012
Address 3C: Lane Change (J1086)       Labels:| 5Q0-907-686.clb
   Component: HRE_Master    H12 0081
   Serial number: 0519386082
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D27C4886DF64583584-8068
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 5Q0 907 685 C    HW: 5Q0 907 685 C
   Component: HRE_Slave  H12 0081
   Serial number: 0519601132
   Coding: 020111
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
   Component: TSG FS        006 0246
   Serial number: 0000305474246
   Coding: 00150320D000048000001000
   Shop #: WSC 00020 999 12345
   ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
   VCID: 48C9A55C3234102BFB2-801C
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000009798407
   Coding: 010000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: 831F0000
   Shop #: WSC 12345 102 209715
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B322B01B32C3F37E0-8026
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 01081930001280
   Coding: 000000050900164201201F41020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 372BD6A04FCA6FD3828-8062
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000336638884
   Coding: 00150320DE00048000001000
   ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000009846262
   Coding: 090000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0891
   Serial number:
   Coding: 02731001FF0000005111000100880A001F0500F401200000CF
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 323DE7B4A4A88AFBB56-8066
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV2691212
   Data carrier:
   Subsystem 2 - Part No SW: 5NA 919 866 AR    HW: -----------
   Component: ECE AS 20/21  --- 1430
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 30000000250801
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3431E1AC5EBC84CBA7A-8060
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 392FD09879DE79A374C-806C
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:33, VBatt start/end: 12.3V/12.3V)-----------
VCP
ODIS-E
VCDS
:arrow: viewtopic.php?p=580495#p580495
danikd
Drives: Citigo
Post by danikd »
Superb as many times :!:
MaDwArLoCk
Drives: Cross Polo 2010 TSI
Post by MaDwArLoCk »
ciclo wrote: Fri Feb 19, 2021 8:33 am Golf 7.5 Retrofitted Matrix 8IU LED headlights.
https://www.youtube.com/watch?v=rAm2jW4uocs
Beautiful, Fernando! 😊👍
Now the last step left - A5 camera
MaDwArLoCk
So they are much brighter then Xenon replica headlights?
2080 lumen against 1440 lumen
danikd
Drives: Citigo
Post by danikd »
IMHO only from some speed ...
Edit, Dont know if can be changed in adaptations ...
danikd wrote: Fri Feb 19, 2021 8:52 am Superb as many times :!:
Thank you very much danikd. :wink:
How are you doing with your Golf ...and your super 'Citigo'?
I'm going to review your private message and I'll tell you something shortly. Wait for me there. :)
MaDwArLoCk wrote: Fri Feb 19, 2021 9:14 am
MaDwArLoCk wrote: Fri Feb 19, 2021 9:23 am So they are much brighter then Xenon replica headlights?
It has definitely been worth it 👍, it is great to see at night how the lights dance from all sides illuminating the road perfectly.👌
The Replica LED headlights that I previously installed are perfect for those who are not very demanding in terms of functions and do not want to overspend. They illuminate better than halogen headlights if the correct LED lamps are used for "legal use". With Morimoto 2.0 LED lamps they work great, though now Morimoto has evolved to 3.0 LED lamps. The dynamic turn signals in the Replica LED headlights help make these headlights pleasant to install.
Yes.The A5 camera becomes part of what will be a spring project due to what I have told you by email. I really liked the video from VAG Italy :arrow: viewtopic.php?p=579764#p579764 with the SW 'L', which is the one my A5 camera has, but I would also like to know your opinion for also being able to compare the L with the H. 8)
Logically I am going to try to sell the Replica LED headlights together with the Morimoto 2.0 LED lamps already installed because I do not have space to have them stored and because they are worth it. I will sell them for half of what it cost me all, although I will not be very picky if someone wants to buy them (they are in perfect condition).
I comment just in case someone reads this conversation and is interested, I don't even have time to post the sale of these headlights in the sales section of the forum, but in this thread is all the information about them (first 5 pages).
danikd
Drives: Citigo
Post by danikd »
ciclo wrote: Fri Feb 19, 2021 11:49 am
My super Citigo (with your mods :) ) its in my wifes hands ... I swap to Golf 7.5 2018, same as your wife :)
So its great, and I made/plan many mods to Golf ... Now I find your Golf thread, so it will be much more fun :)
I have already swapped to heated windshield and now I am making wiring for A5 ... BTW, there is newest SW for A5 from skoda, index Q - SW920. It can be flashed without problem, but not on early A5 units ( HW 01 - 03 )
Than Full LEDs are in plan, I bought damaged headlights ( only glass cover cracked ) and I will install new covers. Maybe dechrome inside of headlights - and paint it pure black :)
Thx for your work and advices ...
Dan
I am glad to know that the Citigo is with you :D , I showed it to my wife when we were improving it and we liked it a lot, a very attractive and fun color.😊
Hope you get good results with the projects on your Golf 7.5, I will show you the content of the VCDS and ODIS files (txt and png) in the following posts. The parameterization files (flash and xml for VCP and ODIS) must be obtained through legal channels.
Many thanks for the information about the HW of the cameras, we know that there are much more recent SW versions for the A5 camera, there is a link in the Slavik thread on Drive2.ru, but the most updated version for Golf 7.5 according to ETKA is the "L". We must test it to also give our opinion.😆
I suppose that Slavik and I will always have the same software installed for the camera to be able to contrast opinions about functions apart from enjoying its operation...
VCP
ODIS-E
VCDS
ODIS-E
4B + 19 Coding BUS Master
VCDS
Before I start posting the data of the txt files I made for my wife's Golf I would like to show you this image:
Note: image from when I installed the mirror for HBA, with original BCM, not the current one.
The reason is because each Golf has a specific equipment and the data that I am going to post is the work I did in my wife's Golf.
The info will be useful for many who do this retrofit but I recommend comparing data with other Golfs that also did it and posted the data that was applied to their cars. Also search for online data from vehicles with original equipment, Ross-tech forum is a good source of information.
4B Adaptation
4B Adaptation
IDE00001-Production mode,not active ,3
IDE00820-Activating and deactivating all development messages,not active ,1
IDE01996-MAS14455-Installation list: specified installations-Multifunction module on the second bus connection,Yes ,1
IDE01996-SFT00041-Installation list: specified installations-Left light control,Yes ,1
IDE01996-SFT00057-Installation list: specified installations-Right light control,Yes ,1
IDE01996-SFT00075-Installation list: specified installations-Multi-function module,Yes ,1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,Yes ,1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,Yes ,1
IDE02332-Deactivate production mode,0 ,3
IDE03641-Presentation run dynamic AFS light,active ,1
IDE03642-Presentation mode,not active ,1
IDE03679-Adaptive light functions,active ,1
IDE03787-Activate left/right hand drive switch-over,not active ,1
IDE08418-Matrix light: total dimming,100 %,1
IDE09156-Matrix headlamp: function at standstill,not active ,1
IDE13611-Cornering lamp in operation,not active ,1
IDE13612-Matrix head lamps: steering angle,9600.00 °,2
ENG124608-Order_Reference_Run_Activation_Effect,No dependency ,1
ENG124607-Reference_Run_Activation_Effect,Activation effect disabled ,1
ENG103979-Reference_Run_Start_Condition,Engine start ,1
4B Headlight Basic Settings + 4B with A5. ONLINE INFO
Copied from forums (many thanks to their authors 👌 8) ).
The VCDS dialog boxes for the basic setting are not the same but the combination of the info makes it very easy to do so.👍
When 4B is coded, clear all errors on 29, 39, D6, and D7.
Clear errors on 4B, headlight basic settings should still be an error.
Perform headlight basic settings:
Basic settings
Basic headlight settings
Activate
Back to Basic settings
Acknowledge basic settings
Activate
There should be no faults on 4B at this point. If you get the “Dynamic cornering light” error….
verify coding
verify adaptions
reset the module
clear faults
perform basic settings again
Soft Reset infotaiment system 5F
Long press the power button until the system reboots and you see the startup screen
Set Factory Light Defaults
Car> Settings> Vehicle > Factory Defaults > Lights
A5 DLA
So, this is the MDF/DLA activation.
You're essentially telling the 3 modules that you are no longer using high beam assistance
(light assist- which turns the high beams on/off above 37mph where permissible),
but instead are using the MDF function which keeps high beams on essentially constantly with adaptability to oncoming traffic.
1. Make 3 Adaptations in Module 09
Select "Fernlicht_Assistent" adaptation menu
Change "Erweiterte Fernlichtsteuerung" to AFS FLA Fernlicht (GLW:MDF).
Change "Menusteuerung Fernlichtassistent" to present.
Change "Menusteuerung Fernlichtassistent Worksteinstellung" to present.
2. Make 2 Long Coding Changes in Module A5
Find byte 19. Change it to hex value 33.
Find byte 21. Change it to hex value 40.
3. Make 3 Long Coding Change in Module 4B (This also adds city lights, highway lights, rain lights, intersection lights)
Go into byte 10. Change it to hex value 7F.
Go into byte 11. Change it to hex value 23.
Go into byte 12. Change it to hex value 63.
4. Soft Reset MIB-II
5. Set Factory Light Defaults
6. Run Headlight Basic Settings in Module 4B (Make Sure on Level Ground)
Clear fault for "No headlight basic setting" in 4B- Won't initially work, but mandatory.
Go to "basic settings"< "Headlight basic settings" and hold green tick to set them. You'll notice the headlights pivot out.
Go back to "basic settings"< "Acknowledge headlight basic settings" and hold green tick to set them. The headlights will pivot back to normal position.
Clear fault for "No headlight basic setting" in 4B a second time. Your headlights should dance and the fault should clear.
7. Soft Reset MIB-II
8. Set Factory Light Defaults
Remember to put in the security access code in each module for good measure.
Related :arrow: viewtopic.php?p=582892#p582892
4B Long coding
- See Autoscan on this page, I will likely re-code the unit for some predictive functions.
BCM Disable old light settigns
Leuchte 0 BLK VL B36
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,127 ,16 ... to 0
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16 ... to 00
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16 ... to 00
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,33 - LED-Modul Blinkleuchten ,16 ... to not active
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16 ... to not active
Leuchte1BLK VRB20
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,127 ,16 ... to 0
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16 ... to 00
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16 ... to 00
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,33 - LED-Modul Blinkleuchten ,16 ... to not active
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16 ... to not active
Leuchte2SL VLB10
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100 ,16 ... to 0
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,28 ,16 ... to 0
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,28 ,16 ... to 0
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16	... to 00
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16 ... to 00
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16 ... to not active
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights ,16 ... to not active
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,not active ,16 ... to not active
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Blinken links aktiv (beide Phasen) ,16 ... to not active
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,Nebellicht links ,16 ...to not active
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16 ... to not active
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16 ... to not active
Leuchte3SL VRB21
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100 ,16 ... to 0
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,28 ,16 ... to 0
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,28 ,16 ... to 0
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16	... to 00
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16 ... to 00
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16 ... to not active
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights ,16 ... to not active
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,not active ,16 ... to not active
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Blinken rechts aktiv (beide Phasen) ,16 ... to not active
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,Nebellicht rechts ,16 ... to not active
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16 ... to not active
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,Parking light right ,16 ... to not active
Leuchte4TFL LB4
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16 ... to 0
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,127 ,16 ... to 0
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16 ... to 00
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16 ... to 00
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16 ... to not active
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16 ... to not active
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,not active ,16 ... to not active
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16 ... to not active
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16 ... to not acitve
Leuchte5 TFL RB32
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16 ... to 0
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,127 ,16 ... to 0
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16 ... to 00
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16 ... to 00
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16 ... to not active
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16 ... to not active
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,not active ,16 ... to not active
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16 ... to not active
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,Parking light right ,16 ... to not acitve
BCM Enable new light settigns
Leuchte6ABL LC5
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,6 - LED Lichtmodul ,16 ... to LED Abblendlicht
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,not active ,16 ... to Lichthupe generell
Leuchte7ABL RB1
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,6 - LED Lichtmodul ,16 ... to LED Abblendlicht
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,not active ,16 ... to Lichthupe generell
Leuchte8FL LB39
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16 ... to 127
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C ,16 ... to 4B
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37 ,16 ... to 44
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,6 - LED Lichtmodul ,16 ... to LED Abblendlicht
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Left high beam ,16 ... to Versorgungsbedarf der LCM Module
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell ,16 ... to not active
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16 ... to Standlicht allgemein (Schlusslicht, Positionslicht, Begrenzungslicht)
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16 ... to Parklicht links (beidseitiges Parklicht aktiviert li & re)
Leuchte9FL RB2
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16 ... to 127
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D ,16 ... to 49
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41 ,16 ... to 3A
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,6 - LED Lichtmodul ,16 ... to LED Abblendlicht
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Right high beam ,16 ... to Versorgungsbedarf der LCM Module
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell ,16 ... to not active
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16 ... to Standlicht allgemein (Schlusslicht, Positionslicht, Begrenzungslicht)
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16 ... to Parklicht rechts
BCM Fernlicht_assistent
20 + 4B + 8IU LED headlights installed:
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,Basis: FLA ,6 ... to AFS: FLA: Fernlicht ueber AFS
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,not active ,6 ... NOT ACTIVE! (to remember HBA active at every ignition cycle)
BCM Level Sender. Leuchtweitenregulierung
Level Sender - BCM Adaptation
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,not installed ,62 ... to rear
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut,HIM ,62 ... to not installed
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,0.0 %,62 ... to 10%
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,100.0 %,62 ... to 90%
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-101.5 ms,62 ... to -114.3 ms
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,255 km/h,62 ... to 0 km/h
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,1.0 %,62 ... to 20%
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR,1.00 s,62 ... to 0.00 s
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,10.0 %/s,62 ... to 0.0 %
BCM Light_Control_Module
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,not installed ,18 ... to installed
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,true ,18 ... to false
GW Adaptations and coding, IC coding
GW Adaptations
IDE01996-SFT00075-Installation list: specified installations-Multifunction module,Not coded ,32 ... to coded
GW - Coding
Byte11 Bit1 ... enable
IC - Coding
Byte4 Bit3 ... enable
dcgumis
Post by dcgumis »
Full admiration :D Now you can enjoy full LED lamps: D I have the impression that the polo has a brighter LED than the golf :)
Thanks dcgumis.👍
I don't know how bright the Polo's LED headlights are, but these 8IUs light up 'perfectly'.
Please do not refer to the video or the images that I post for the brightness of the G7.5 LED headlights because my smartphone is a big s**t.🤣
safm
Drives: Golf MK7.5 Variant
Post by safm »
:shock: :shock: :shock:
What amazing job!!!!
Congrats!
I'll have to wait several months, several attempts to do the same..... :oops: :oops: :oops: :oops:
Locked
