iichels VW Passat 2.0 TSI DSG 4-Motion 2017
Re: iichels VW Passat 2.0 TSI DSG 4-Motion 2017
more to come with RGB footwell lights and perhaps some addition to the door lights.
I can write a lot about it, but the pioneer in all of this must be ciclo. Check out his and his wifes Golf for all the know-abouts on this subject:
viewtopic.php?t=72376
search for "Ambient" in the first post and read all 13 articles.
Audi RS3 brake coolers 8V0407811 8V0407812, plug and play, to cool the brakes a bit.
There is nothing worse than touching the brake and feel the steering wheels shake violently.
https://imgur.com/a/5J2wjn9
I fitted extra lights to the rear lid, just like in my Polo :mrgreen:
patil
Post by patil »
We always want something in our new cars like in our Polo :mrgreen:
iichel I see 2 buttons in your electric tail gate switch. How they work?
One is the normal close button and the other is the easy close function. It works in conjunction with the sensor in the rear bumper for the kick-to-open function.
It's been a while since I wrote about my Passats updates, I have one today: The OEM 1T0065400 coolbox that holds +- 25 litres.
patil
Post by patil »
How is the cooling effect? I saw one similar at my dealer for around 200€. In my T-roc there is no 12V socket in boot, I need to install one.
I'll let you know after the weekend. It's a 35-ish watt Peltier element solution so I'm not expecting miracles.
Some small updates regarding running mods:
- Brought the Audi TTS calipers to the sand blasting. I'll make them black with white 'R' logo on the front and neutral black on the rear.
- Bought a new windshield for heating 3G0845011CR
- Bought some LEDs for ambient lighting in the doors and along the panoramic roof
- Bought a new bike carrier 3C0071105B
- Bought some dealer showroom plates 3G9071801
- Bought some parts for 360 area view cam, thanks to Slavik
- Bought some parts for massage backrest for passenger (3AA959257A, 5N0959730, 3AA881880, 5G0959777A, 1S0972706, 8E0972126, 3G0881859b, 4B0973721, 8E0971832, 3G0959917)
- Bought some parts for the passenger side mirror to dim (glass 3G0857522B + wires)
- Bought a sun visor without airbag writing (3G0857552)
- Bought two fire extinguishers with mounting brackets for below the seats (000016995, 3C8881286, 000016997, N90812302, N10632102)
- Bought two bandaid kits for Passat an Polo (000093114)
- Installed the new 5NB gear lever with a manual boot (5NB713203K, 3G1711113G)
- Installed new style rear logo (5H0898633)
- My trusty Skoda washer bottle cap 6V0955449 6V0955485 is back
FFA76
Drives: Polo 6R BlueGT
Post by FFA76 »
I think the part number for the Skoda washer bottle cap should be 6V0955485.
The one you posted (6V0955449) is for the whole reservoir.
Yes sorry. You are right.
iichel wrote: Fri Jan 06, 2023 6:43 pm I got myself a brake kit from the Audi TTS 8S 2.0 TSI.
The front calipers are 4-pots for 340mm (same size) and the rear setup is identical. Just red calipers.
Finished product, just need to install now
Diverter valve upgrade from 06H145710C (=OEM) to 06H145710D. Revision D is said to hold the pressure a bit better at high boost.
This is the Pierburg 7.01830.13.0, same part but no VW sticker, saves about 30 euros.
https://www.amazon.nl/dp/B0068MTMLM
https://www.youtube.com/watch?v=BH63qp7LX6Q
I now have the massage function in the Passat's passenger seat, just like I have on the Polo 6R.
It's a matter of changing the backrest adjustment package to a version with position sensors.
Then install the 3AA module, the button, the 3-pin lumbar adjustment button and wire it all up.
parts:
3AA959257A module
5N0959730 bracket for module
3AA881880 backrest
5G0959777A 3-pin adjustment button
1S0972706 6-pin plug for button
8E0972126 16-pin plug for outputs and switches
4B0973721 12-pin plug for power
3G0959917 massage button
3G0881859b emblem for button
8E0971832 4-pin plug for button
wiring, you can take power from the original T6 plug for the old lumbar adjustment. it's red/black (+30) and brown (GND)
I've installed like RHD, because it's virtually a RHD driver seat.
finished product:
all images:
https://imgur.com/a/nv6qBkB
In preparation for the 360 degree Area / overhead view camera installation, I've modified the support for the Dynaudio amplifier below left seat, to fit below the right seat.
I'll install the module using tie-wraps to the frame. This way it's nicely covered and looks a lot better than the OEM foam!
Parts:
Cover: 3Q0863051
Bracket: 3Q0907390
Module: 5Q0907556C
https://imgur.com/a/hnazXY1
