Erk!
- Sponsor
- Platinum Member
Well I think one of the problems with these square toothed belts is they need to bed in. Because youre putting a new belt on old pulleys there will be a bit of play. And with the teeth being sqaure it probably allows more movement untill the belt wears itself into the right shape for the pulleys. The round tooth design of later engines is much much better. because the edges are rounded theres less need for it to bed in. and theres twice as many teeth and theyre twice the depth, which means in theory they will last longer.
- Location: Birmingham! Enjoys: The pseudo-G-Smiles provided by a 1.6 Megane Sport valver...
- Sponsor
Cheers for that, I found out this afternoon that that was the problem The 90° rule was a bit vague, didn't know whether to set it so that I could only just turn it, or so that it turned quite easily to 90° but not much further, so I went for the tighter option Didn't think for a moment that it'd sound as bad as it did..
Also, I had a slightly bent camshaft sprocket, so I changed it for another one that I had in the shed, which is also a bit wonky but a lot better than the last one. I'll get a straight one next time I'm at the scrappy.
Thanks for all the advice guys
- Platinum Member
- Sponsor
Yeah, at first I set mine so I could just about twist it but it took some effort. Now if I really try I can just about turn it 180° if I really try, but 90° is quite easy. Sounds sweet as a nut now.. if you ignore the rattle coming from under the car that's just developed, need to look into that really..
- Sponsor
Oh, nice one.. if you wouldn't mind, that'd be great. Doubt my scrappy would want much for one, but it's a pain in the backside to get them off. My email address is carrot@groovycarrot.co.uk, let me know how much you want and I'll send you some money and my details
