Patil's T-roc 2020 1.5Tsi evo+Dsg7 RHD
Re: Patil's T-roc 2020 1.5Tsi evo+Dsg7 RHD
The J949 module has an emergency battery (A16).
edit
hmm ... take a look at those 28 + 32...
edit
Ok, thank you dear Master, I will have a look at the information you've provided
I am currently home, visiting my dear parents to celebrate our big Indian festival DIWALI( festival of lights, it symbolises triumph of light over darkness, good over evil and knowledge over ignorance)
I wish all my dear friends, forum members and everyone a happy Diwali
Happy DIWALI to all India! 🕯
It would be good if the rest of the planet also had a special DIWALI day to celebrate with the same meaning as for India, but it is obvious and evident that there is nothing to celebrate...
I guess 'Blyat' Friday is enough.
edit
Please, my dear Doctor, translate and read this web page https://thediplomatinspain.com/2017/10/ ... en-espana/
This is great, Thank you so much!!
edit
Thank you dear Master, I missed your editciclo wrote: ↑Tue Nov 14, 2023 6:40 am Happy DIWALI to all India! 🕯
We Indian's feel humbled as our festivals are appreciated and celebrated throughout the world
What is the purpose of this bit0, byte 11 in both front door control modules? What connection does doors have with ACC. I guess if doors are opened when ACC is ON, ACC gets disabled
I suppose it is a signal for the interaction between control modules to enable/disable some operation. Let us remember that these door modules are installed on a wide range of VW Group models (ATW), from those with high-tech doors to those with ignominious doors (e.g. manual window opening, without central locking, etc).
ACCording to ODIS:
[LO]_ACC_door_contact: [VO]_not_active
I activated it on both front door modules for a while, but nothing happened...
What is the definition for ACC in this case?
By using a little the imagination 'without great effort'...
- Adaptive Cruise Control.
- ACCessories, terminal 15 or similar, 'ON/OFF'.
- ACCident, in case of collision.
- ACCelerate.
- ACCompaniment.
- ACCable.
- ACCeptation.
etc...
Please let us know if you find the purpose of that Bit, I am sure that someone will be able to discover it one day, either by knowledge, diagnosis or by chance.
ACCording to ODIS:
- ACCelerate.
- ACCompaniment.
- ACCable.
- ACCeptation.
etc...
Log#22
Retrofit Electric tailgate + Virtual pedal (for Easy open+ Easy close) OEM
Background: Without doubt, T-roc rear lid is heavy. Though opening the lid is easy, but it goes up little high to be comfortable to reach it and close, my wife always complained about it. So decided to make life little easier with my roc.
Parts:
1. 2GA827552A/B - RH strut gas filled
2. 2GA827851B - LH strut motor drive
3. 3G0827887C - Motor to close tailgate latch
4. 3G0854719B -Motor latching clips (3 pcs)
5. 2GA827535A - Bowden cable
6. 2GA827506A - Lid lock for power tailgate
7. 2GA827427A - Strut mount bracket RH
8. 2GA827428A - Strut mount bracket LH
9. 5Q0919279 - Buzzer
10. 5Q0959107T - Tailgate control module
11. N91158501 - Rivets for Buzzer ( 2pcs)
12. 3G0959831BWHS - Push button for electric lid locking. OR 3G0959832AWHS/5NG959832A ( 2 button switch for Easy close via second button)
13. 2GB86742682V (RHD)- Trim for switch driver door to open tailgate. 2GA86742682V for LHD
14. 5GD959831 - switch on driver door to open/close tailgate.
15. Wiring kit: I bought the electric tailgate full kit along with wiring including virtual pedal set from AliExpress.
https://a.aliexpress.com/_mqXzusc
I got the electric tailgate wiring customised by seller to include easy close wiring + button + compatible rearlid control module.
PS:
1) T-roc never came with easy close (2 buttons on rear lid ) from factory, so the wiring kits sold on websites like AliExpress, Kufatec, Car systems etc.. only comes with factory wiring configuration (single button). AliExpress seller was kind enough to oblige my request and customised the wiring for me according to my requirement, for which many thanks to him.
2) I will highly recommend to buy wiring kit readymade for electric tailgate retrofit. You will save lot of time and money.
Here are some stores where it's available:
https://www.carsystems.eu/vw-skoda-full ... d4267.html
https://www.carsystems.eu/vw-t-roc-a11- ... d4169.html
https://www.kufatec.com/en/volkswagen/v ... -a11-42748
Following parts are also needed if installing Virtual pedal ( kick sensor) for Easy open + Easy close via kick.
16. 3G0/D 962243D ( preferably C or higher)- Control unit
17. 3G0 962 283 A- control unit bracket
18. 5NA962253 - Sensor lines (wires)
I bought the kit along with electric tailgate kit.
To begin with, whole of lid trims, boot trims on both sides, roof liner partially, rear seats, trims running along the running board from back to front on both sides must be removed for proper laying of wirings on both sides.
Installation pictures:
Buzzer fixed:
Power latching motor:
Lid lock unit: Top power lid lock, bottom stock.
Bowden cable: I struggled a bit to figure out how the cable locks on the lid lock unit side. On the power motor side it's a easy installation. Finally repair manual came to help. This is how it is fixed
Installed new struts: Electric strut on left side and Gas strut on right side.
Brackets for new struts Left stock, Right new
How to remove stock struts:
Left strut
Right strut
Tailgate control module fixing location: On the left side above the wheel arch.
As all the necessary parts have been fixed in tailgate, it's time to fix tailgate control module and do the wiring part.
Before taking up wiring part, here are the relevant wiring diagrams.
This is the final wiring scheme for my T-roc electric tailgate with easy close by second button.
This Wiring scheme is inspired by wiring scheme from 10zt a drive2 member https://www.drive2.ru/l/528382958185219848/
When I checked the AliExpress wiring, I saw a problem. There is no coupler to bridge the wiring between lid side and boot side. It makes routing of wires almost impossible. To fix this issue, we need to cut the wiring at appropriate length and add a coupler.
The coupler and the terminals:
At the same time while modifying the wiring, I also added wires for future tailgate warning/exit light
Final modified wiring with scheme and we connect accordingly:
Rear lid control unit installed and its ground connected to nearby groud hub.
Power supply for rear lid control unit:
Canbus connection to lid control unit from gateway:
KL30 for rear lid buttons backlight from boot light. Also for rear lid warning lamp.
Bringing the main wiring from rearlid control unit along C- pillar towards the rear lid coupling point via roof. At the same time connected the connector for left electric drive in the roof.
Connected the other half of wiring in the tailgate by routing the wires from left side.
Completed wiring in tailgate:
Next, installing kick sensor + wiring for Easy open+ Easy close by kick.
WD:
Kick sensor kit:
The kick sensor module installation with partial wiring was done when installing rear sensors for PLA 3.0. I didn't had bracket for kick sensor module, my dealer gifted me one.
Now the last part of physical installation. Installing remote opening of lid via button on driver door.
WD:
There is already factory marking for cutting the trim for installing button on the back side of driver door trim. We cut accordingly and install the button and do the wiring according to WD. There are also plastic clips from factory to route the wiring of button
This concludes complete physical installation. Next comes the fun and most important part: Coding/Adaptation/Basic settings/ Parameterisation. For this I primarily used ODIS-E and occasionally VCDS.
Coding:
1. Gateway address 19 - Enable 6D ( rearlid control unit ) in gateway installation list.
2. Address 6D:
coding:
Adaptations:
Basic setting:
Parameterisation:
Now here comes the most tricky part. T-roc with electric tailgate from factory comes with single button in lid to close and no easy open/close offered from factory. So logically, for my setup dataset simply doesn't exist. Well no problem.. will prepare one
Thanks to the pioneering work of iprot, who extensively researched and shared his work on electric tailgate control modules on various VAG models. Here are the links to his articles.
https://www.drive2.ru/b/642225567491444832/
https://www.drive2.ru/b/639294819247599097/
https://www.drive2.ru/l/644835533217877960
https://www.drive2.ru/l/648070571304699691/
And also an excellent article by respected Sen78 about different types of rearlid control modules with easy close support .https://www.drive2.ru/l/604452670152911929/
As a starting point, first took the dataset from T-roc rear lid module 5Q0959107R( SW271) matching the SW of module I bought 5Q0959107T(SW271). R module doesn't support easy close by button but it doesn't matter, we edit dataset from R and flash into our T module.
Stock 'R' dataset zip contains 20 datasets.
As explained in iprots posts.. we modify only four ( 720D, 720E, 7217 & 7218)of the 20 datasets in zip folder.
Example : Editing 720D dataset using notepad++, hex editor and online CRC calculator.
Similarly we edit datasets 720E, 7217 & 7218. Repack the edited datasets into zip folder. It will look like this
First, flash the stock R dataset zip folder followed by modified R dataset zip folder using ODIS-E. If everything is done correctly then dataset flash should be successful. Invalid dataset error will hang after flashing, it's temporary, erase it and will never be seen again.
3. BCM address 09:
security access:31347, enable adaptations.
4. KESSY address B7:
security access: 20103
coding: enable
Adaptations: enable
After coding/adaptation, we get Easy open menu in MIB. Select it for Easy open to start working
There are many adaptations channel values for easy close & easy open control module in kessy unit, which need to be adjusted for correct working. I will share my settings, which work perfectly in my T-roc.
Basic settings of sensor for rear lid opening:
After correct completion of basic setting, the rear lid open control module appears under Kessy module.
5. Driver door control module: address 42, enable remote open/close rear lid via switch in driver door.
6. Telematics: address 75( if present) enable
7. PLA : address 76 enable
After everything is said and done, I was left with one final problem, Easy close by pressing second button on lid refused to work. Rest all, easy open and close by kick, closing of lid by first button, remote opening/closing by keyfob and driver door button were working. An erasable error was registered in rear lid control module everytime I pressed the second button.
I spent many days trying to find out the cause and solution for this final problem. I could not get any leads, negative thoughts started to make me believe that easy close by button may not be possible in T-roc.
Well, my sadness didn't last long another maverick Jackson hu from Taiwan came to my help. He told me to swap the two wires T8/5 and T8/7 of easy close button.
.. and Alas.. finally problem solved.. easy close by button started working immediately He had similar problem with easy close by button in his Touran Damn, Chinese messed up the wiring I remember I had checked the wirings with WD before installation, may be I overlooked these 2 wires.. I guess am getting old fast
Autoscan: Bit old, but it's taken after successful installation of electric rear lid.
Video:
I sincerely thank Sen78, iprot, Lazo downtime, Jacky and dear friend iichel for all the help
"kriegst du immer was du willst"? ...“meistens”
https://youtu.be/whqYBka7_O4?si=QpfkToPBjYTdfdsd
Parts:
PS:
Buzzer fixed:
Left strut
Right strut
WD:
Kick sensor kit:
WD:
Coding:
2. Address 6D:
coding:
Adaptations:
Basic setting:
Parameterisation:
3. BCM address 09:
coding: enable
Adaptations: enable
[VN]_Rear_lid_power_opening_control_unit_sender_1_threshold_1:
[LN]_sensor_1_treshold_1: 69
[VN]_Rear_lid_power_opening_control_unit_sender_1_threshold_2:
[LN]_sensor_1_treshold_2: 16
[VN]_Rear_lid_power_opening_control_unit_sender_1_threshold_3:
[LN]_sensor_1_treshold_3: 16
[VN]_Rear_lid_power_opening_control_unit_sender_1_threshold_4:
[LN]_sensor_1_treshold_4: 16
[VN]_Rear_lid_power_opening_control_unit_sender_1_threshold_5:
[LN]_sensor_1_treshold_5: 16
[VN]_Rear_lid_power_opening_control_unit_sender_2_threshold_1:
[LN]_sensor_2_treshold_1: 2
[VN]_Rear_lid_power_opening_control_unit_sender_2_threshold_2:
[LN]_sensor_2_treshold_2: 31
[VN]_Rear_lid_power_opening_control_unit_sender_2_threshold_3:
[LN]_sensor_2_treshold_3: 2
[VN]_Rear_lid_power_opening_control_unit_sender_2_threshold_4:
[LN]_sensor_2_treshold_4: 31
[VN]_Rear_lid_power_opening_control_unit_sender_2_threshold_5:
[LN]_sensor_2_treshold_5: 224
[VN]_Rear_lid_power_opening_control_unit_sender_1_timer_value_1:
[LN]_sensor_1_timer_1: 170
[VN]_Rear_lid_power_opening_control_unit_sender_1_timer_value_2:
[LN]_sensor_1_timer_2: 0
[VN]_Rear_lid_power_opening_control_unit_sender_1_timer_value_3:
[LN]_sensor_1_timer_3: 9
[VN]_Rear_lid_power_opening_control_unit_sender_1_timer_value_4:
[LN]_sensor_1_timer_4: 33
[VN]_Rear_lid_power_opening_control_unit_sender_2_timer_value_1:
[LN]_sensor_2_timer_1: 11
[VN]_Rear_lid_power_opening_control_unit_sender_2_timer_value_2:
[LN]_sensor_2_timer_2: 165
[VN]_Rear_lid_power_opening_control_unit_sender_2_timer_value_3:
[LN]_sensor_2_timer_3: 147
[VN]_Rear_lid_power_opening_control_unit_sender_2_timer_value_4:
[LN]_sensor_2_timer_4: 204
[VN]_Rear_lid_power_opening_control_unit_sender_1_control_parameter:
[LN]_sensor_1_vref: 16
[VN]_Rear_lid_power_opening_control_unit_sender_1_burst_length:
[LN]_sensor_1_burst_length: 16
[VN]_Rear_lid_power_opening_control_unit_sender_1_active_shield:
[LN]_sensor_1_AS: 16
[VN]_Rear_lid_power_opening_control_unit_sender_2_control_parameter:
[LN]_sensor_2_vref: 16
[VN]_Rear_lid_power_opening_control_unit_sender_2_burst_length:
[LN]_sensor_2_burst_length: 2
[VN]_Rear_lid_power_opening_control_unit_sender_2_active_shield:
[LN]_sensor_2_AS: 31
[VN]_Rear_lid_power_opening_control_unit_foot_gesture_detection_timer_value_1:
[LN]_sensor_fusion_timer_A1: 2
[VN]_Rear_lid_power_opening_control_unit_foot_gesture_detection_timer_value_2:
[LN]_sensor_fusion_timer_A2: 31
[VN]_Rear_lid_power_opening_control_unit_reset_all_counters:
[LN]_reset_counter: 224 [not defined]
[VN]_Rear_lid_power_opening_control_unit_checksum:
[LN]_checksum: 170
[VN]_Rear_lid_power_opening_control_unit_data_set_version:
[LN]_Data_Identification: 0
[VN]_Rear_lid_power_opening_control_unit_foot_gesture_detection_evaluation:
[LN]_comparisson: 0
[VN]_Rear_lid_power_opening_control_unit_play_protection_increment_value:
[LN]_increment_value: 6
[VN]_Rear_lid_power_opening_control_unit_play_protection_decrement_value:
[LN]_decrement_value: 25
[VN]_Rear_lid_power_opening_control_unit_threshold_play_protection_active:
[LN]_activ_treshold: 255
[VN]_Rear_lid_power_opening_control_unit_threshold_play_protection_inactive:
[LN]_deactiv_treshold: 5
[VN]_Rear_lid_power_opening_control_unit_play_protection_decrement_interval:
[LN]_Rear_Lid_Opening_Sender_decrement_interval: 60
[VN]_Rear_lid_power_opening_control_unit_sender_1_timer_value_5:
[LN]_sensor_1_timer_5: 34
[VN]_Rear_lid_power_opening_control_unit_sender_2_timer_value_5:
[LN]_sensor_2_timer_5: 23
[VN]_Rear_lid_power_opening_control_unit_duration_status_request:
[LN]_Rear_Lid_Opening_Sender_Duration_Sensor_Request: 4,960 [UN]_ms
[VN]_Rear_lid_power_opening_control_unit_vehicle_type:
[LN]_Rear_Lid_Opening_Sender_vehicle_type: 22
[VO]_Easy_close_detection_areas:
[LO]_Easy_close_antenna_current_step: 4
[LO]_Easy_close_open_door_antenna_current_step: 2
[LO]_Value_area_4: 70 [UN]_mV/m
[LO]_Value_area_leaving_area: 65 [UN]_mV/m
[VO]_Easy_close_alignment:
[LO]_RSSI_ sample_rate: 500 [UN]_ms
[LO]_Timeframe_scan_active: 20.00 [UN]_s
[LO]_Min_threashold_trunk: 70 [UN]_%
[LO]_Max_time_IDGeber_rear: 2.00 [UN]_s
[LO]_max_threashold_reopen_EasyClose: 30 [UN]_%
[LO]_max_time_reentry_EasyClose: 5.00 [UN]_s
[LO]_min_rssi_values_hysteresis_EasyClose: 150
[VO]_Rear_lid_power_opening_control_unit_data_set_upload:
[LN]_Easy_open_S1_number_of_pulse: 1
[LN]_Easy_open_S2_number_of_pulse: 1
[LN]_Easy_open_S1_oversampling_value: 0
[LN]_Easy_open_S2_oversampling_value: 1
[LN]_Easy_open_sensor_1_treshold_1: 16
[LN]_Easy_open_sensor_1_treshold_2: 16
[LN]_Easy_open_sensor_2_treshold_1: 16
[LN]_Easy_open_sensor_2_treshold_2: 16
[LN]_Easy_open_sensor_1_counter_1: 2
[LN]_Easy_open_sensor_1_counter_2: 31
[LN]_Easy_open_sensor_2_counter_1: 2
[LN]_Easy_open_sensor_2_counter_2: 31
[LN]_Easy_open_hub_comparison: 224
[LN]_Easy_open_A1_timer_value_open: 10
[LN]_Easy_open_A2_timer_value_open: 10
[LN]_Easy_open_sensor_1_hub_depth_open: 0
[LN]_Easy_open_sensor_2_hub_depth: 0
[LN]_Easy_open_hub_period_comparison: 9
[LN]_Easy_open_symmetry_comparison: 0
[LN]_Easy_close_operation: [VN]_active
[LN]_Easy_close_parameter_set: [VN]_not active
[LN]_Easy_close_power_save_function: [VN]_not active
[LN]_Easy_close_sensor_position_switching: [VN]_down
[LN]_Easy_close_reference_value_generation_open: [VN]_dynamic
[LN]_Delay_rear_lid: [VN]_2_sec_lock
[LN]_Delay_rear_lid_close: 3
[LN]_Recalibration_faulty_activation: [VN]_not active
[LN]_Easy_open_reference_value_generation_close: [VN]_dynamic
[LN]_Easy_open_parameter_set_version: 0
[LN]_Easy_open_environment_negative_gradient: 5
[LN]_Easy_open_number_of_faulty_activations_by_car_wash: [VN]_6
[LN]_Easy_open_environment_ total_rise_analysis: [VN]_active
[LN]_Easy_open_tolerance_band: 19
[LN]_Easy_open_pre_rest_time: 2
[LN]_Easy_open_countdown_reset_environment_event: 12
[LN]_Easy_open_environment_post_rest_time: 4
[LN]_Reset_environment_lock_by_rear_lid: [VN]_Do not reset
[LN]_Easy_close_sensor_1_threshold_1: 16
[LN]_Easy_close_sensor_1_threshold_2: 16
[LN]_Easy_close_sensor_2_threshold_1: 16
[LN]_Easy_close_sensor_2_threshold_2: 16
[LN]_Easy_close_sensor_1_counter_1: 2
[LN]_Easy_close_sensor_1_counter_2: 31
[LN]_Easy_close_sensor_2_counter_1: 2
[LN]_Easy_close_sensor_2_counter_2: 31
[LN]_Easy_close_hub_comparison: 224
[LN]_Easy_close_A1_timer_value_close: 10
[LN]_Easy_close_A2_timer_value_close: 10
[LN]_Easy_close_sensor_1_hub_depth: 0
[LN]_Easy_close_sensor_2_hub_depth: 0
[LN]_Easy_close_hub_period_comparison: 0
[LN]_Easy_close_symmetry_comparison: 0
[LN]_Rear_Lid_Opening_Sender_vehicle_type: 34
[LN]_Rear_lid_power_opening_control_unit_data_set_checksum: 23
Tuesday,08,August,2023,15:38:47:09269
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WVGZZZA1ZLT-roc License Plate:
Chassis Type: A1-VW27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 3C 42 44 4B 52 5F 65 6D
75 A5 BB BC CA D6 D7
VIN: WVGZZZA1ZLT-roc Mileage: 34829km-21641miles
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
75-Telematics -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DPCA) Labels:. 04E-907-309-V1.clb
Part No SW: 05E 906 018 AT HW: 05E 907 309 H
Component: R4 1.5l TFS H20 9640
Revision: 8AH20000 CVN: 5E8A0C2D
Coding: 012500322304190830000000000000000000000000000000
Shop #: WSC 00020 043 00000
ASAM Dataset: EV_ECM15TFS01105E906018AT 003003
ROD: EV_ECM15TFS01105E906018AT_003_VW27.rod
VCID: 77A8E2A6DF4F07E23E1-8022
VINID: 9E65EAAAA441A9C9801C720314E84F2DE4
Readiness: 1010 0001
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 050 J HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1911
Revision: 00005009 Serial number: CU501911185682 CVN: ABB5E1C0
Coding: 0014
Shop #: WSC 17734 418 534600
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021_VW27.rod
VCID: 3C223D8AA6E9E4BA133-8068
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 DK HW: 5Q0 614 517 BN
Component: ESC H35 0113
Revision: 00000000 Serial number: 63139000003538
Coding: 46FA8A7D90272473477F060362C82562510924E26046A4733022F00A52A24B0B00000523525212121035351919323200
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
VCID: 7DA4F08EFD732DB264D-8028
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0534174099 Dataset Number: V03935301VA 0001
Coding: 132C2C0723
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_KessyHellaMQBAB 004052
ROD: EV_KessyHellaMQBAB.rod
VCID: 45D4586ED523A5727CD-8010
Rear lid opener control module:
Subsystem 1 - Part No SW: 3GD 962 243 D HW: 3GD 962 243 D
Component: GEB.F.Heckoef H17 0908
Serial number: 05086671
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5G0 907 044 FQ HW: 5G0 907 044 FQ
Component: Climatronic H04 2401
Revision: 00001K10
Coding: 061200242001100D1105004012101836
Shop #: WSC 00020 999 12345
ASAM Dataset: EV_ACClimaBHBVW37X 006151
ROD: EV_ACClimaBHBVW37X_006_VW27.rod
VCID: 7BA0FE96E36723825A9-802E
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 EC HW: 5Q0 937 084 EC
Component: BCM MQBAB H H44 0511
Serial number: B2701012207200 Dataset Number: V03935394NB 0001
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_BCMMQB 022001
ROD: EV_BCMBOSCH_022_VW27.rod
Rain/Light Recognition Sensor:
Subsystem 1 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 051 0206
Serial number: S6Y19M10D15H05M19S28
Coding: 0018DD
Anti-theft alarm system sensor:
Subsystem 2 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY192950M1T
Alarm horn:
Subsystem 3 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000000754028
Steering Column Switch:
Subsystem 4 - Part No SW: 5Q1 953 521 Q HW: 5Q1 953 569
Component: Lenks.Modul H03 0170
Serial number: 0100221120190C400340
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5QA 919 294 G HW: 5QA 919 294
Component: PDC 8 Kanal H08 0061
Serial number: 000150058419329 Dataset Number: V03935306ND 0001
Coding: 0471155011
ASAM Dataset: EV_EPHVA18AU3700000 009046
ROD: EV_EPHVA18AU3700000_009_VW27.rod
VCID: 50FA793A1A6170DADFB-8004
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Dataset Number: V03935314EN 0001
Coding: 3204604318FF8748949C810500408500000000000000000004
ASAM Dataset: EV_ACCMRRCONTIVW376 003016
ROD: EV_ACCMRRCONTIVW376_003.rod
VCID: 43D04676DB179B42529-8016
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 3Q0 959 655 CM HW: 3Q0 959 655 CM
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z2PPMRKF2 Dataset Number: V03935298UN 0001
Coding: 88CCC0C0000000005C5400CF008840000065
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
ROD: EV_AirbaVW21TS6VW48X_VW27.rod
VCID: 0B40AE56B3C713026A9-805E
Subsystem 1 - Part No SW: ----------- HW: 454 002 910 19
Component: SideSensor_Df 008 0887
Serial number: 357000000004A1316142
Coding: 2D2D2D
Subsystem 2 - Part No SW: ----------- HW: 454 002 810 19
Component: SideSensor_Pf 008 0887
Serial number: 35800000000C98B8424V
Coding: 2D2D2D
Subsystem 3 - Part No SW: ----------- HW: 454 802 210 19
Component: SideSensor_Dr 301 0148
Serial number: 35100A0CB121A000000D
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 454 802 510 19
Component: SideSensor_Pr 301 0148
Serial number: 35200E4A8381A000000P
Coding: 2D2D2D
Subsystem 5 - Part No SW: ----------- HW: 454 802 310 19
Component: FrontSensor_D 304 0149
Serial number: 35500964D2C1A000000R
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 17A 920 790 B HW: 17A 920 790 B
Component: KOMBI 503 4310
Coding: 65FC00986A88080C0188770F1801000000000906
ASAM Dataset: EV_DashBoardVDDMQBA0 001042
ROD: EV_DashBoardVDDMQBA0_001_VW27.rod
VCID: 2616FFE248654E6A557-8072
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 442 4388
Revision: -------- Serial number: 0000427114 Dataset Number: V03935301GP 0001
Coding: 030100046F08560023100248180F00010001070000000000000000000000
GVL: 014E3C000800060040CC80008000C80010000000000200000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_VW27.rod
VCID: 70BAD9BABA2150DAFFB-8024
Generator:
Component: 5-01-14-01-04
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5NA 959 442 HW: 5NA 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H06 0025
Serial number: 2601917550901873BZ2B
Coding: 250000
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Component: J367-BDMHella H10 9070
Serial number: 3250843205
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Serial number: 19000332474005
Coding: 0800000000000000
ASAM Dataset: EV_ELVMarqMQBA0 002002
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 313C1CBE71AB19D2B05-8064
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0150
Serial number: 14520011985865 Dataset Number: V03935308HF 0001
Coding: 92A54640
ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
VCID: 392C249EA9DBD192085-806C
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H06 0150
Serial number: 14520011913860
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 K HW: 5Q4 959 593 K
Component: TSG FS 007 0485
Serial number: 0000397175085 Dataset Number: V03935313VT 0001
Coding: 00151A20D001028000001000
ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
VCID: 4DC4604E0D535D32B4D-8018
Subsystem 1 - Part No SW: 5Q0 959 408 HW: 5Q0 959 164
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000036110727
Coding: 1D0000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 AB HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 131 1082
Dataset Number: V03935312TK 0001
Coding: 171F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 74B2D5AACE396CFA1B3-8020
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0367
Serial number: 17111910522941 Dataset Number: V03935304ZR 0001
Coding: 000000070900204600000900000000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 003003
ROD: EV_MultiModulContiVW48X_003.rod
VCID: 372822A69FCFC7E2FE1-8062
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 K HW: 5Q4 959 592 K
Component: TSG BFS 007 0485
Serial number: 0000396858048 Dataset Number: V03935313WJ 0001
Coding: 00151020DC01028000001000
ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
VCID: 4CC26D4AF649543AA33-8018
Subsystem 1 - Part No SW: 5Q0 959 407 HW: 5Q0 959 163
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000036011483
Coding: 050000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 864 C HW: 3Q0 035 864 C
Component: MU-S-N-ER 854 0879
Serial number: Dataset Number: 5G0CV1v____ 0001
Coding: 02720601BE0000004111000100080A201F0500F601200000C6
ROD: EV_MUStd4CDELP_VW27.rod
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav 361 8214
Serial number: VWZ6ZHX1471458
Data carrier:
Subsystem 2 - Part No SW: 5NA 919 866 DH HW: -----------
Component: MRM2 2023/24 --- 2010
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 30000000255241 Dataset Number: RDKS_TinyQ_ 1017
ROD: EV_RDKBERU30_005.rod
VCID: 343215AA8EB92CFADB3-8060
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 T HW: 5Q0 959 107 C
Component: HDSG-Modul H12 0271
Revision: -------- Serial number: PLG01908160021 Dataset Number: V03935301SX 0001
Coding: 1C28
ASAM Dataset: EV_DeckLidCONTIAU736 001017
ROD: EV_DeckLidCONTIAU736_VW27.rod
VCID: 49CC545EF93B4112985-801C
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5NA 035 284 C HW: 5NA 035 284 C
Component: OCULowMQBLGE H19 0825
Revision: -------- Dataset Number: V03935298KU 0001
Coding: 02720601EA16380D3F1CBE000045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004049
ROD: EV_OCULowMQBLGE_004_VW27.rod
VCID: 3D24308EBDF3EDB224D-8068
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H12 0610
Serial number: 15111915K10993 Dataset Number: V03935315JQ 0001
Coding: 0002070600000401000212568150A90084000E20002000
ASAM Dataset: EV_MFKBoschMQBB 002041
ROD: EV_MFKBoschMQBB_002.rod
VCID: 40DA497ACA01805A4FB-8014
Address BB: Door Rear Drv
Cannot be reached
Address BC: Door Rear Pass
Cannot be reached
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Dataset Number: V03935280ME 0001
Coding: 508040727602
ASAM Dataset: EV_SunRoofCONTIAU736 009011
ROD: EV_SunRoofCONTIAU736_009_VW27.rod
VCID: 75B4E8AEC54375F22CD-8020
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AH HW: 7P5 941 591 A
Component: LED1L H07 0009
ASAM Dataset: EV_LED_PLUS_L_KEBODAVW416 001003
ROD: EV_LED_PLUS_L_KEBODAVW416.rod
VCID: 025E8372848D524A19F-8056
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H07 0009
ASAM Dataset: EV_LED_PLUS_R_KEBODAVW416 001003
ROD: EV_LED_PLUS_R_KEBODAVW416_VW27.rod
End----------(Elapsed Time: 02:02, VBatt start/end: 12.9V/13.1V)-----------
Holy moly that's really impressive patil. Well well done and a nice write up too.
"" awesome work! ... when you decide to sell your T-ROC I'll buy it from you, I don't care if it has the steering wheel on the 'wrong' side.
Thank you iichel and dear Master for your kind words
There was lot of scepticism in the beginning about successful implementation of Easy close via button in T-roc. I took a bit of gamble, but in the end everything worked out well. It's so satisfying when your efforts pays off
I feel like tailgate is no more in my roc
Hi, my dear Doctor, due to a spark in my brain I thought again about the RVC High that you previously posted to install your TRoc.
Because the data sets must be 'appropriate' in order to successfully achieve camera Calibration with ODIS I was poking around MIBSolution to see what data sets they had out there, maybe you find there a dataset of a model 'similar' to the TRoc (SK,etc).
However, I have the VW Taos data sets for the RVC High that I no longer remember where they come from and that I will send to you by email in case you want to try them...
I haven't received the RVC high camera yet. I am also planning to change the RVC logo to new type at the same time. I will take your help with calibration and datasets when I am ready with all the parts. Thank you so much dear master for offering the help
Meanwhile I got a confirmation from an AliExpress seller that, Customised side mirrors base to fix area view cameras will be available soon for T-roc. This will be one step closer to those who wish to retrofit 360 camera in their T-roc.
Bought touch climatronic unit with frame from AliExpress.
I am little sceptical if the frame would fit in my RHD T-roc. A buyer from South Africa wrote in review that frame wouldn't fit in his RHD T-roc.
OEM climatronic frame is not sold seperately for T-roc, it's a part of whole central console trim.. VW
I will try to modify the frame if it wouldn't fit. I will write.
Post edited to correct the mistake.
BRAZIL= LHD
South Africa=RHD
BRAZIL= LHD
South Africa=RHD
The AliExpress touch Climatronic panel won't fit in RHD T-roc
The south african buyer was right!... I wish I would have found his review before placing the order.
There is no way this panel can be modified to make it fit perfectly. A case of double blind, neither seller told me nor it crossed my mind that the panel would only fit LHD T-roc.
Will try to get RHD panel 2GB863099B, as I mentioned in previous post, this part is not sold seperately, it's a part of RHD central dash trim 2GB863042B.
Without a doubt it is an inconvenience, something similar happens with the color of the touch climatronic trim for G7.5, only available in glossy black. Fortunately, the 'gray' touch chinatronic trim is also available on Ali, which I think is only for sale on Ali (at least when I bought it).
Looking at it from another point of view, at least the entire Troc RHD touch climatronic trim/panel was later manufactured for the following Troc MYs.
Another 'small' hole in the pocket...
