Hi
I have dropped the gearbox, removed the clutch, and have now attached the new bearing and lever into its place into the gearbox, and have now also bolted the new clutch unit to the flywheel, and I am now ready to connect the gearbox to the engine but........... I dont know which bolts go where around the bell housing as I forgot to make a note of them as i was removing them ....is there a schemetic diagram showing which bolt goes where (its size and place etc) any help would be appreciated
SoL
