Help needed: MQB MIB2 steering wheel CAN frames / MFSW button CAN IDs
Hiroki
Drives: 6r Polo 1.2 TSI 2011
Post by Hiroki »
Hi everyone,
I’m working on a PQ25 → MQB MIB2 CAN translator for my Polo 6R and I’m looking for some help obtaining the actual MQB CAN frames used for the multifunction steering wheel controls.
The setup is:
* Polo 6R / PQ25
* BCM Max
* MQB MIB2: 3Q0 035 844B
* Teensy 4.1 with two CAN interfaces
* Polo CAN side: 100 kbps
* MIB/MQB side: 500 kbps
I already have several parts of the translator working. For example, I’ve successfully translated the Polo ignition state to MQB Klemmen_Status_01 (0x3C0), and the MIB now correctly recognizes Terminal 15. Illumination/dimming translation is also working.
The remaining problem is the multifunction steering wheel.
I’ve already captured and decoded the Polo/PQ side. My wheel sends the following on 0x5C1:
Release 00 00 00 50
Next 02 00 00 50
Previous 03 00 00 50
Volume + 06 00 00 50
Volume - 07 00 00 50
Phone 1A 00 00 50
Voice 2A 00 00 50
Mute 2B 00 00 50
0x5BF also mirrors these frames on my Polo.
However, simply forwarding these frames to the MQB/MIB CAN at 500 kbps does not operate the MIB.
I’ve also experimentally tried PQ-style frames on 0x5C1 and 0x5BF, including:
0x5C1 06 00 00 50
0x5C1 06 00 01 11
0x5BF 06 00 00 00
with no response from the 3Q0 MIB.
So rather than continue guessing, I’m looking for a raw CAN capture from a genuine MQB vehicle with MIB2.
Ideally I need the frames seen on the Infotainment CAN / CAN network feeding J794 while individually pressing:
Volume +
Volume -
Mute
Next
Previous
Phone
Voice
A short capture of idle → button press → release → idle for each button would be perfect. CAN ID, DLC and all data bytes are what I need.
If anyone has CAN logs from a Golf Mk7, Polo 6C/AW, Tiguan AD1, Passat B8, etc. with MQB MIB2 and multifunction steering wheel, or knows the actual MQB message/ID used by J794 for these commands, I’d greatly appreciate the information.
I’m particularly interested in the actual frames reaching the infotainment side, rather than the LIN communication between the steering-wheel buttons and steering-column electronics.
I’m happy to share the finished PQ → MQB Teensy translator code and findings once this is working, as it may be useful for other people retrofitting MQB MIB2 units into PQ cars.
Thanks for any help.
Re: Help needed: MQB MIB2 steering wheel CAN frames / MFSW button CAN IDs
Hi Hiroki
First of all, we want to thank you for trusting the knowledge of this forum. We feel flattered, but to be completely honest, you’ve brought a NASA-level engineering query to a place where we are usually busy arguing about which engine oil is better or how to change a cabin filter! :mrgreen:
We are good at many car things, but your project is on a whole different level of specialization.
That being said, we love a good challenge and your PQ25 → MQB MIB2 translator project with the Teensy 4.1 sounds absolutely brilliant. Massive respect for already cracking the ignition state (Terminal 15 on 0x3C0) and the dimming translation. That’s a huge milestone!
Since we don't want you to leave empty-handed, here is the technical reason why your experiments aren't working on the 500 kbps MQB side:
1- State vs. Event: Your PQ25 steering wheel works on events (it shoots a frame when you press a button and another when you release it). MQB architecture is strictly cyclic (state-based). The MIB2 (J794) expects a continuous "heartbeat" message from the steering wheel controls roughly every 100ms. If you just send a single burst frame, the MIB2 simply ignores it.
2- The MQB IDs: On the MQB Infotainment bus, the Multi-Function Steering Wheel (MFL) typically broadcasts on ID 0x5BF (and sometimes interacts with 0x2C3), but the internal byte layout is completely different from your Polo's PQ format.
Where to find the exact raw logs without guessing: Instead of shooting in the dark, you should look into open-source autonomous driving projects. Check out the Comma.ai (OpenPilot) GitHub repository. If you look for their Volkswagen .dbc files (the database files that map the CAN bus), they have already reverse-engineered the entire MQB Infotainment network. You will find the exact bit-and-byte mapping for Volume +, Volume -, Mute, and Track Skip commands there.
Also, look up some GitHub projects regarding "MQB steering wheel retrofits on PQ cars". Developers there have already coded the exact translation matrices you need for your Teensy.
If you hit a brick wall with the dual-baudrate code (FlexCAN_T4), the Official PJRC Teensy Forum is your best bet. But please, once you get it working, come back here and show us! We’d love to see a Polo 6R rocking a fully functional MQB MIB2 unit thanks to a tiny Teensy.
Best of luck!🤗
Hiroki
Post by Hiroki »
Thanks for the reply bro.
You are too kind, you are THE one and only Master Ciclo :).
Thanks for the info. Will look into it and will keep you posted
Thank you!!!
scissa
Drives: 6C 2015/5 CJZC
Post by scissa »
I have no idea and knowledge about the topic, but you can check this post too, he also does mfsw upgrade with can/linbus
There are also other posts connected to this one. Check them also
https://www.drive2.ru/l/728553722946258141/
Hiroki
Post by Hiroki »
Thank you scissa. I have checked. what I need is very simple capture of the traffic from MIB quadlock CAN (pin E6 and E12).
### Suitable vehicles
Ideally:
- Polo 6C with factory MIB2
- Golf Mk7
- Passat B8
- Tiguan Mk2
- Another VW with a Delphi MIB2
- Especially useful if the MIB part number begins with `3Q0 035 8xx`
My unit is:
Delphi MIB2
Part number: 3Q0 035 844 B
Software: MU-S-S-US 722 / 0879
The recording does not require changing or coding anything in the car. It is passive listening only.
### Equipment required
Any USB CAN interface that works with SavvyCAN, such as:
- CANable or CANable 2.0
- CANtact
- Macchina
- PCAN-USB
- ValueCAN
- Another CAN logger capable of recording raw CAN frames
A Windows, Linux or macOS laptop running the free SavvyCAN program is also required.
Unfortunately, VCDS by itself cannot make this type of raw CAN recording.
### Connection
The adapter needs only:
CAN High ( E6 )
CAN Low ( E12 )
Ground
connected in parallel with the infotainment CAN wires going to the MIB2.
A Quadlock breakout/extension harness is recommended so no factory wiring needs to be cut.
Important:
- Use passive or listen-only mode if available.
- Set the CAN speed to `500 kbps`.
- Do not transmit any messages.
- Disable the adapter’s 120-ohm termination resistor because it is connecting to an existing vehicle network.
- Please verify the correct CAN High and CAN Low wires for your vehicle before connecting.
### Recording procedure
1. Connect the CAN interface and laptop.
2. Open SavvyCAN.
3. Select the CAN interface.
4. Set the bus speed to `500000`.
5. Enable listen-only mode if the adapter supports it.
6. Confirm that CAN messages are appearing.
7. Switch the ignition OFF.
8. Start recording.
9. Wait approximately 20 seconds.
10. Switch the ignition ON without starting the engine.
11. Leave the ignition ON for at least 90 seconds.
12. Press one steering-wheel volume button, if fitted.
13. Select reverse briefly, with the brake applied and the car safely stationary.
14. Switch the ignition OFF.
15. Continue recording for another 60 seconds.
16. Stop and save the recording as a SavvyCAN log or CSV file.
The complete recording should be approximately three minutes.
Please also include:
Vehicle model:
Model year:
MIB part number:
MIB manufacturer, if known:
Factory parking sensors: Yes/No
Factory reverse camera: Yes/No
Multifunction steering wheel: Yes/No
The recording may contain the vehicle VIN. If you do not want that posted publicly, please send the file to me privately. I will use it only to identify the CAN messages and timing required by the MIB.
Even a recording made by someone who already has CAN-logging equipment would be extremely helpful.
Thank you!
Hiroki
Post by Hiroki »
Hi Community,
Just a little update of my project.
A brief history, I'm driving 2011 TSI 1.2 2011 CBZB polo. I had been doing a number of retrofits to my car and reached to direct TPMS where it hit a wall. My Cluster is a midline cluster so eventhough I can read the TPMS values in the VCDS, there is no way that I can see them easily. That triggered my curious mind to explore the options and found the MIB2 which going to be looking very good in my car :D.
So I started to source for the MIB2 which is a MQB unit and my car is a PQ car. They dont talk each other so I am developing a translator to achieve that.
Here is the update now.
- ignition on and off works well now.
- backlights are sync and the dimmer T58d works and sync with the car.
- MFSW works
- Car info works with details such as service interval and VIN etc.
- Time synchronization works. (able to get GPS time and sync it automatically to the Cluster)
- Able to control the Light, Opening and closing, Instrument cluster reset, Units, works and able to modify the options. (such as acoustic confirmation on/off, Autolock on/off, coming/leaving home light duration, etc)
- OPS working with the 8K ops. Activation via button, reverse gear works.
- 6C camera has some issues where I cant' put the camera to sleep when it is not in use (still trying to solve it).
And here is the problem now. We had very heavy rain and unfortunately my car got literally soaked in the rain. seems like the water get into the ECU somehow (still need to find where is that and need to fix it before reinstalling the new ECU) and ECU stopped working. When I take it out, I get the burn smell. try to power on with the bench wiring, power shoot up and more smell of smoke comes out. It is Simos 10.20 ECU. I open up the ECU and see a lot of area suspicious of electrical damage. I dont have advance tools to read or clone the ECU. I bought the same part number ECU from Ebay and it is sitting on my desk right now. I need to program it to my car. I have ODIS E and S with VNCI 6154B. I found online that if I get GEKO access, I can match it but some said it cannot.
I'm seeking advice from seniors here what could & should I do please.
ps. I'm very new to ODIS, (I used to use VCDS) so please be gentle if I ask stupid questions and guides.
Impressive work on the CAN translator!
Just as a side note, an MIB2 PQ (5C0) paired with a BCM Max upgrade (e.g., 7E0 937 090/190) can handle all of those functions natively on the 6R without needing a custom translator.🤷‍♂️
More importantly, I really hope "literally soaked" just means the plenum chamber/cowl area and not the cabin floor, if water got inside to the interior wiring and modules, it’s going to be a much bigger headache.
Regarding the Simos 10.20, keep in mind that VAG has heavily restricted GeKo when it comes to matching used ECUs nowadays, so ODIS online will very likely reject it, though I’m not 100% sure on how it stands right now, as I haven't used VW servers with a GeKo account in quite a while.
Your safest bet will probably be taking both units to a local tuner/specialist to clone the old ECU (or do an IMMO OFF) in boot/bench mode.
I sincerely wish you the best of luck with all this tinkering/learning, and I also sincerely thank you for keeping us informed in such detail.🤗
Hiroki
Post by Hiroki »
Thanks for the kind words Master Ciclo.
I understand that using PQ MIB would solve everything plug and play but the fun of challenging the impossible is the one that keep us all on this forum, I believe. And your car is the living proof of it and which excites me and motivate me to do all these things :D.
Moreover, I am trying to continue the "Explorer" project (mmlink) and hope that I could get in touch with that genius so we can do knowledge sharing and having fun of doing this (that's the most important part).
As for the water damage, it is just limited to engine bay but I definitely need to look into the full diagnostic of the system for real before fitting in the new ECU.
I had run out of all the options locally. Not even the IMMO off. Even online, a lot of ppl I contacted through forums and Facebook groups, they all said Simos 10.20 is almost impossible to do cloning and they all advised me to get some help with somebody/shop who has GEKO account coz they said the shop or person can submit the form to VAG and can do the adaptation. But that person/shop must be an authorized provider.
I really do hope I could get some guidance and help for my fellow forum members and seniors.
It’s great to hear the water damage was contained to the engine bay, that is a massive relief!
Don't get discouraged by what people are telling you on Facebook groups. The reason everyone says a Simos 10.20 (Infineon Tricore TC1767) is "impossible to clone" is because its immobilizer data (CS, PIN, MAC, VIN) is cryptographically tied to the processor's unique MCU ID / OTP area. You cannot just do a raw copy-paste from one ECU to another. and since your original ECU is fried, you can't read it anyway.
However, you do NOT need GeKo or an authorized dealer to get your car running again. Because your Polo 6R uses an IMMO 4 system where the Instrument Cluster is the immobilizer master, you have two very realistic paths you can solve remotely with help from specialists on forums like MHH Auto or CarTechnology:
Important note about your current tools
Your VNCI 6154B with ODIS-E/S is great for diagnostics, coding, and flashing official .frf/.odx files, but it cannot read/write the internal Tricore Flash/EEPROM needed to bypass or adapt the immobilizer. To use either method below, you will need a bench/boot programmer (or a local chiptuner who has one).
Option 1: Transfer Immo Data from your Cluster to the eBay ECU (Cleanest & OEM-like)
Since your original ECU is dead, you pull the security data directly from your car's cluster instead:
1. Read the Cluster Immo Data: You (or a local automotive locksmith) need to read the immobilizer block (CS, PIN, MAC, VIN) from your Midline cluster via OBD using a tool like VVDI2, AVDI/Abrites, Smok UHDS, or Carprog.
2. Read the eBay ECU: Read the full Flash and EEPROM from the donor Simos 10.20 in Boot/Bench mode (using tools like PCMflash, KTAG, Flex, Autotuner, etc.).
3. Remote Adaptation: Post both files (Cluster Immo data + Donor ECU dump) on MHH Auto or CarTechnology (or contact a VAG immo specialist there). They can inject your cluster's CS/PIN/MAC into the donor ECU file and recalculate the checksums for that specific donor MCU ID.
4. Write & Start: Flash the modified file back to the eBay ECU. The car will start normally with zero warnings on the cluster.
Option 2: Software IMMO OFF on the eBay ECU (Fastest & Cheapest DIY route)
Contrary to what you were told, 100% working software IMMO OFF solutions DO exist for the Simos 10.20, and you don't need anything from your old ECU or cluster:
1. Get a cheap programmer: If no local shop can read it for you, you can easily buy an affordable clone/budget tool yourself... for example, a PCMflash (Module 53 / 71) + Scanmatik 2 Pro clone or a KTAG (for boot mode). Given your Teensy/CAN skills, doing a bench/boot pinout connection will be a walk in the park for you.
2. Read the donor ECU: Read the Flash and EEPROM of your eBay Simos 10.20.
3. Remote Patch: Upload the files to MHH Auto or CarTechnology requesting an IMMO OFF for Simos 10.20. Someone will patch the flash file specifically for your donor ECU's MCU ID and fix the checksums (usually for free or a small fee).
4. Write & Start: Write the patched file back to the donor ECU, plug it into the car, and it will fire right up. (Note: With IMMO OFF on a PQ25 car, the engine will run perfectly, though you might get an "Immobilizer active" message or a flashing key icon on the Midline cluster).
Before plugging the donor ECU into the car, make sure to check all power/ground pins on the ECU harness connector with a multimeter (or a test light under load) to ensure the water didn't cause a short circuit in the wiring loom that could fry the replacement unit.
Keep pushing forward, your PQ-to-MQB translator work is seriously inspiring for the whole community!💪👍
scissa
Post by scissa »
Hiroki wrote: Mon Nov 23, 2026 8:02 pm Hi Community,
- MFSW works
It is sad to hear the rain affected your car and possibly other cars too.
Going to the dealer route will be always expensive and hard to do since they mostly don't want to do cars older than 10 years. But I see passat B6 generation in the dealers still, it purely depends.
If you really want to use official way, your VAG approved shop will mail the situation to the secondhand part activation VAG mail address, they will inspect it and give permission to your shop, then you will be able to code it to your car. At least this is the case with PQ26/MQB electronics.
My advice would be remove the EEPROM and MCU and Flash chips from your board, and transfer them to the new board.
People here in Turkey do all crazy ECU stuff, they can even repair most severely damaged units, but most of the time they just transfer these 3 components and most of the time it will work great.
Sometimes it is possible to change your ECU to something else completely. I see people with 1.8T changing their Bosch ME3.... something to ME7.5. Some EA189 1.6 TDI(PCR 2.1) cars get swapped to 2.0 TDI (Bosch) units too.
Worst case would be a Standalone ECU, but it will be not an original solution and will cost too much.
However for me the best case would be swapping the main components. Also, if possible, Bench read those components just in case.
Have you actually done that swap yourself on a Simos 10.20, or are you just repeating hearsay from older ECUs?
Because on a Simos 10.20, there are no separate EEPROM and Flash chips to remove, they are both internally integrated inside the Infineon Tricore TC1767 BGA processor itself.
Transplanting an automotive BGA chip is not a simple hot-air job, it requires an infrared/bottom preheater rework station, removing automotive underfill epoxy without ripping copper pads off the PCB, cleaning, and precision reballing with a dedicated stencil to align hundreds of microscopic solder balls underneath the package. ⚠
More importantly, Hiroki already stated that when he powered up the original ECU on the bench, current spiked and smoke came out. That means the internal 5V/3.3V rails or the MCU itself is dead-shorted. Desoldering a shorted BGA processor from a water-damaged board and reballing it onto a good donor ECU is a guaranteed way to ruin the replacement board too.
So definitely do not touch it with a hot air station, Hiroki, stick to the software routes on the intact donor ECU!
