6R 1.6TDI 90HP CAYB 2009
Re: 6R 1.6TDI 90HP CAYB 2009
Yes. Just clear it
Ugabista
Drives: Vw Polo 6R 1.6TDI 90CV CAYB
Post by Ugabista »
I delete the error but back immediately, then something must not be right. Wonder why?
Turn off aux in monitoring in long coding helper. That should stop it
Ugabista
Post by Ugabista »
In which module?, Media in (2E)? I'll check it tomorrow and then give feedback, thanks [emoji106]
Ugabista
Post by Ugabista »
I can not change the byte to clear the error...[emoji20]
RNS 510
About RNS315, I do not know.
Ugabista
Post by Ugabista »
Is the same as mine.
I think the problem is I have VCDS 14.10.1 before had the 12.12 and could make changes. Now this changes what I do, will not be recorded ... :(
Ugabista
Post by Ugabista »
Ugabista
Post by Ugabista »
Hi guys :)
Does anyone know me indicate how can I do with the VCDS the state of particle filter saturation?
What steps to bring about a regeneration with the VCDS?
Thanks a lot for the help :wink:
Ugabista
Post by Ugabista »
I can not enter the MEASURING BLOCKS 08, it is shaded. :cry:
Ugabista
Post by Ugabista »
New Mod.
RNS510
I have a problem I can not put the camera reversing working on the radio, listen to the radio open but no sign. In VCDS try to activate the camera option but it gives me error 78, I leave the program and go back in, the option is active and even after you reset the radio, no picture appears when no meto reversing. Someone I can help ??
When installed RNS315 earlier just had to activate a camera option rear view and was soon working ....
SCAN VCDS
Saturday,06,February,2016,21:56:10:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WVWZZZ6RZAY0xxxxx License Plate: 6R 02/2016
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 37 44 56 77
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYB) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 D HW: 03L 906 023 D
Component: 1,6l R4 CR td H13 9970
Revision: --H13--- Serial number:
Coding: 00114014000400080000
Shop #: WSC 15628 784 95450
ASAM Dataset: EV_ECM16TDI02103L 003009
ROD: N/A
VCID: 275D1D175E18CF26F59-8072
No ASAM data for: "EV_ECM16TDI02103L" (VW36 *)
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 R HW: 6R0 907 379 R
Component: ESP8.2i front H04 0002
Revision: --------
Coding: 210228E3417400B4842714E582D900421300
Shop #: WSC 02069 000 00000
VCID: 4D918FBF1024C5762F5-8018
Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
Part No SW: 6R0 820 045 E HW: 6R0 820 045 E
Component: Climatic 24 0600
Revision: 00 10 24
VCID: 306FF64B63D6889E243-8065
1 Fault Found:
16372 - Control Module; Unspecified Internal Error
014 - Defective
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 31090 km
Time Indication: 0
Date: 2013.14.04
Time: 21:04:20
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 D HW: 6R0 937 087 D
Component: BCM PQ25 H+4 H46 0207
Revision: BF046001 Serial number: 0147 127100851
Coding: 3CB02BBF08A10000003800007CAB1CD00000410F60860040200000000000
Shop #: WSC 00058 261 91255
VCID: 3E73D873A9826EEEA6F-806B
Subsystem 1 - Part No SW: 6R0 959 801 H HW: 6R0 959 801 H Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 004 0803
Coding: 08BC30
Subsystem 2 - Part No SW: 6R0 959 802 K HW: 6R0 959 802 K Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 004 0803
Coding: 08BC30
Subsystem 3 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 811 B HW: 6R0 959 811 B
Component: J388__TSG_HL 004 0803
Coding: 08BC32
Subsystem 5 - Part No SW: 6R0 959 812 B HW: 6R0 959 812 B
Component: J389__TSG_HR 004 0803
Coding: 08BC32
Address 15: Airbags Labels: None
Revision: ------(- Serial number: 003DW056D4RC
Coding: 053038304169
ASAM Dataset: EV_AirgaVW10BUAVW250 A01001
ROD: N/A
VCID: 55A167DF34F48DB6975-8000
Subsystem 1 - Serial number: 3526GRG40239GWDL0R8S
Subsystem 2 - Serial number: 3582SRG400009<CCFA5V
Subsystem 3 - Serial number: 3516GRG401V9GWDKNJHY
Subsystem 4 - Serial number: 3526GRG40239GWDL0R8S
No ASAM data for: "EV_AirgaVW10BUAVW250" (SE41)
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 861 B HW: 6R0 920 861 B
Component: KOMBI H23 0110
Coding: 140A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 3467FA5B9FCEB4BE40B-8061
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087 D
Component: GW-K-CAN TP20 0207
Coding: 002200
VCID: F0EFB64B2356489EE43-80A5
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H23 0110
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7661156854
Coding: 010000
Shop #: WSC 12345 123 12345
VCID: 29591B2F400CF956E3D-807C
1 Fault Found:
03138 - Input AUX IN
009 - Open or Short to Ground
Fault Status: 01101001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 229
Mileage: 0 km
Time Indication: 0
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 C HW: 1T0 035 680
Component: RNS-MID H04 2760
Revision: AB001001 Serial number: VWZ6Z7K1978363
Coding: 0C010240020000A100
Shop #: WSC 00051 261 87199
VCID: 2E53E83379E29E6E36F-807B
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10130
Shop #: WSC 00000
VCID: 2E53E833EDE29E6E36F-807B
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 N HW: 7P6 035 730 N
Component: TELEFON H16 4217
Revision: 1B001001 Serial number: 00007670015483
Coding: 0611000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3D71DF7FAC8475F6BF5-8068
End ---------------------------------------------------------------------
HELP :cry:
I assume it isn't the high camera that the dedicated controller?
Ugabista
Post by Ugabista »
alexperkins wrote:I assume it isn't the high camera that the dedicated controller?
It is the emblem rear camera with RGB plug. In RNS315 works well ..like this; http://www.cars-equipment.com/www/en/sh ... rear-view/
Ugabista
Post by Ugabista »
Already activated the module 10 - Park / Steer assist in Installion List, changed the Coding for 040102400200002100 appears Coding rejected Error 78: Unknown (0x78), then I reset the radio back in and he takes Coding but still does not give anything when I put the reverse gear...
