Hello ciclo,
I'm getting ready for xenon retrofit.
I saw that cars with Xenon OEM headlamps are made with 2.5 mm wires.
On cars with halogen the supply is made with 1 mm wires.
Should I supply headlights with 2.5 wires or will it not be a problem with 1 mm ones?
Can you give me some advice?
Thank you,
Retrofitting LED headlights & BCM Max Adaptation+Auto Headlight with CH/LH on 2013 6R
CeciliuTabara
- Drives: POLO 6R DSG 2013
Re: Retrofitting LED headlights & BCM Max Adaptation+Auto Headlight with CH/LH on 2013 6R
Yes, please always respect wire thickness in the wiring diagram.
+ 1iichel wrote: Mon Feb 24, 2020 7:21 pm Yes, please always respect wire thickness in the wiring diagram.
CeciliuTabara
Hello again guys,
Yesterday i retrofitted OEM xenon headlights. For now passive.
It seems everything work fine, except the flah.
Flash not work. Motor for high beam are heard but the bulbs do not light up.
CH work fine.
Any ideea?
Thanks in advance!
Here is my BCM coding:
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 089 F HW: 7H0 937 089
Component: BCM T5GP Li4 H50 0251
Revision: BS050001 Serial number: 0465 300111639
Coding: 64B029B808A1000001280EC068AB8FD0F0C866FF60AE20C1200000000000
Shop #: WSC 64564 324 38760
VCID: 3979F2A0B0BEE287A0-806C
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 110113 05 54 0403
Coding: 06302D
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1621
Serial number: KU0KU019111200016909
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1621
Serial number: KU0KU028111200012325
Coding: 18BC30
Subsystem 4 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-MD9 H04 0103
Serial number: 29190001675950069296
Coding: A50000
CH work fine.
Any ideea?
Thanks in advance!
Coding: 06302D
Coding: 18BC30
Coding: 18BC30
Coding: A50000
Can you give this a try?
64B029B808A1000001280EC168AB8FD0F0C867FF60AF20C1200000000000
64B029B808A1000001280EC168AB8FD0F0C867FF60AF30C1200000000000
Hmm... the wire reaching slot T73a/62 on the black BCM connector must be installed. (spliced to SB34b) (erWin, elsawin)
I think you should take a look at the link below to find out what are all the lights on your bixenon headlights:
https://www.uk-polos.net/viewtopic.php? ... 85#p493598
... and thus be able to affirm that they work correctly.
CeciliuTabara
Hello guys,
Everything work very nice. Flash work corect now.
The coding delivered by the cycle made the DRLs work properly as well. I mention that they didn't work before.
The path of the BCM POLO is unsuspected,
Thank you !!
Thank you !!
Thanks for sharing the results!
Take care.
Take care.
