Page 8 of 18
Re: BCM Max Transporter 2013
Posted: Thu Jan 27, 2022 7:41 pm
by samul
I just upgraded 086b to 087m and have similar error like you:
“00329 - Control Circuit for Unlocking Rear Lid
011 - Open Circuit“
Do you have 2 wings door or 1 lid? How you resolve it?
Do you have sliding doors? They are working fine with interior lights? Door are close but instruments and vcds says that they are open, if I open them vcds says that they are closed
maybe you know how to solve it?
Posted: Thu Jan 27, 2022 10:56 pm
by Shadow109
I have this fault because I retrofitted non oem electric tailgate
Please post an auto scan abd sure ciclo will help you
Posted: Sat Jan 29, 2022 11:14 am
by samul
Chassis Type: 7H-VN75 (6N0)
56-Radio -- Status: Not registered 0011
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CAAC) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 022 CH HW: 03L 907 309 K
Component: R4 2,0L EDC H32 9126
Revision: 26H32--- Serial number: 00000000000000
Coding: 01194012231400080000
Shop #: WSC 51187 142 82990
ASAM Dataset: EV_ECM20TDI01103L906022CH 002012
ROD: EV_ECM20TDI01103L906022CH_002.rod
VCID: 6DD17CB3BC91F7277E-8038
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 E HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0103
Revision: 00H43001
Coding: 508724AD89A60A9C24A79171695F10
Shop #: WSC 02736 790 49152
VCID: 3467A9D7973B66EF71-8060
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 91
Mileage: 283661 km
Time Indication: 0
Date: 2016.06.21
Time: 01:46:36
Count: 0
Count: 2065
Count: 128
Count: 252
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 AA HW: 7E5 907 047 AA
Component: Climatic-T5 H10 0101
Revision: 00004001
Coding: 0000000002
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ClimaticT5 A01002
ROD: EV_ClimaT5Basis.rod
VCID: 6ED37BBFB1970C3F47-803A
1 Fault Found:
13701936 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 283661 km
Date: 2022.01.29
Time: 00:03:53
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 M HW: 7H0 937 087
Component: BCM T5GP H+4 H34 0413
Revision: BO034001 Serial number: 0573 099140915
Coding: 2A2038B80A21201300204810380B8C500000430F60040000320000000000
Shop #: WSC 02759 790 12345
VCID: 3E738BFFA977BCBF97-806A
Subsystem 1 - Part No SW: 7E0 959 801 HW: 7E0 959 801 Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3310
Subsystem 2 - Part No SW: 7E0 959 802 HW: 7E0 959 802 Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3310
2 Faults Found:
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 91
Mileage: 283661 km
Time Indication: 0
Date: 2016.06.21
Time: 00:05:38
03302 - Response Closing Status of Passenger's Door
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 91
Mileage: 283661 km
Time Indication: 0
Date: 2016.06.21
Time: 00:00:31
Part No SW: 7E0 959 655 A HW: 7E0 959 655 A
Component: VW10Airbag00N H05 0011
Revision: -------- Serial number: 003E5000RVF9
Coding: 00000000000000000000000000000000304E
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
ROD: EV_AirbaVW10BPAVN750_VW12.rod
VCID: 3467A9D79F3B66EF71-8060
Part No SW: 7E0 920 860 A HW: 7E0 920 860 A
Component: KOMBI H16 0111
Coding: 160A00
Shop #: WSC 00000 790 50316
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04041
VCID: 2643439F59E7047FFF-8072
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 H34 0413
Revision: BO034001
Coding: 042200
VCID: 70EF65C7A3A31ACF55-8024
1 Fault Found:
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 6
Reset counter: 255
Mileage: 283661 km
Time Indication: 0
Date: 2016.06.21
Time: 11:02:10
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H16 0111
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09.rod
Address 56: Radio
Cannot be reached
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 E HW: 1K0 907 383 E
Component: Anhaenger H08 0080
Revision: 3A002002 Serial number: 00000122018278
Coding: 4100000100000000
Shop #: WSC 02736 790 00000
VCID: 2F6DA6BB7E1D45370C-807A
End-------------------------(Elapsed Time: 02:24)--------------------------
1. Radio - cannot be reached because i have android from aliexpress, it has some VAG module but VCDS show error, i remove it from CAN gateway installarion list
2. ABS error - i think it's because acu is low (11.8V), it's charging right now
3. 00329 - Control Circuit for Unlocking Rear Lid - this error is permanent
4. Sliding doors, there is no error, when doors are open vsds says closed, when i close them vcds says open (like on the picture)
Posted: Sun Jan 30, 2022 6:32 am
by ciclo
Hello samul.
Are you absolutely sure that by making the BCM change from 086b to 087m you transferred the BCM and Gateway codings from one BCM to the other?
Posted: Sun Jan 30, 2022 8:39 am
by samul
I first tried to copy old coding, paste in new bcm, but it was rejected… so based on my print screens I checked manually all the same options in bcm, similar for can gateway and then it was accepted.
Posted: Sun Jan 30, 2022 3:09 pm
by ciclo
Please post the BCM 086 coding (and Gateway) in text form just before the change (no image or photo, please). Thank you.
... a full autoscan would be better.
Posted: Sun Jan 30, 2022 3:58 pm
by samul
This auto scan i made before i remove bcm 086 from car.
Revision: 00H43001
Revision: 00004001
Coding: 0000000002
Part No SW: 7H0 937 086 B HW: 7H0 937 086 B
Component: BCM T5GP M++4 H46 0207
Revision: BM046001 Serial number: 0154 341090297
Coding: B8A0203A0E212023002000003C2B8E500000430F60062040300000000000
Shop #: WSC 02736 790 12345
VCID: 326BAFCF6D2F68DF63-8066
7 Faults Found:
00910 - Indicator Lamp for Emergency Flashers (K6)
007 - Short to Ground - Intermittent
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 174
Mileage: 283490 km
Time Indication: 0
Date: 2016.06.18
Time: 03:23:03
00063 - Back-Up Light Switch (F4)
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 173
Mileage: 283331 km
Time Indication: 0
Date: 2016.06.18
Time: 00:10:28
03301 - Response Closing Status of Drivers Door
Fault Priority: 2
Fault Frequency: 1
Reset counter: 174
Mileage: 283594 km
Time Indication: 0
Date: 2016.06.18
Time: 02:34:35
Fault Priority: 2
Fault Frequency: 1
Reset counter: 174
Mileage: 283594 km
Time Indication: 0
Date: 2016.06.18
Time: 02:34:35
03303 - Response Closing Status of Rear Left Door
Fault Priority: 2
Fault Frequency: 15
Reset counter: 175
Mileage: 283331 km
Time Indication: 0
Date: 2016.06.18
Time: 00:18:53
03304 - Response Closing Status of Rear Right Door
Fault Priority: 2
Fault Frequency: 26
Reset counter: 175
Mileage: 283331 km
Time Indication: 0
Date: 2016.06.18
Time: 00:18:53
03442 - Return Message Closing Status of Rear Lid
Fault Priority: 3
Fault Frequency: 1
Reset counter: 174
Mileage: 283594 km
Time Indication: 0
Date: 2016.06.18
Time: 02:34:35
Coding: 160A00
Part No SW: 6N0 909 901 HW: 7H0 937 086 B
Component: GW-K-CAN TP20 0207
Coding: 042200
1 Fault Found:
000 - -
Fault Priority: 2
Fault Frequency: 254
Reset counter: 255
Mileage: 276384 km
Time Indication: 0
Date: 2016.06.18
Time: 12:11:34
Serial number:
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:21)--------------------------
Posted: Sun Jan 30, 2022 8:08 pm
by ciclo
Try to enter this BCM coding:
A8A020380E212023002000103C2B0C500000430F60060000300000000000
If it is accepted, Clear all DTCs, make the appropriate checks and do a new autoscan.
Posted: Mon Jan 31, 2022 5:48 pm
by samul
thx ciclo error 00329 vanish, new coding was accepted
something also changed with interior lights and sliding doors:
- all door close and unlock, instruments doesn't show that they are open also radio confirm that they are closed, but when i start engine interior lights are still enable
- when i open sliding doors radio confirm this fact
- when i stop engine, get off the car and lock by pilot interior lights turn off
- and 2 errors arrived, they are Intermittent but return
Revision: 00H43001
Revision: 00004001
Coding: 0000000002
Coding: A8A020380E212023002000103C2B0C500000430F60060000300000000000
2 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 131
Mileage: 283661 km
Time Indication: 0
Date: 2016.06.23
Time: 01:34:30
Fault Priority: 2
Fault Frequency: 1
Reset counter: 131
Mileage: 283661 km
Time Indication: 0
Date: 2016.06.23
Time: 01:34:30
Coding: 160A00
Revision: BO034001
Coding: 042200
1 Fault Found:
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Serial number:
Address 56: Radio
Cannot be reached
Posted: Mon Jan 31, 2022 7:55 pm
by ciclo
Disconnect the battery for a few seconds, reconnect, Clear all DTCs, do the relevant checks...
If we do not achieve a good result we will have to investigate a little more...
Do you still have the BCM 086?
Posted: Tue Feb 01, 2022 2:47 pm
by samul
Scan: 01 03 04 08 09 15 17 19 25 56 69 0B
Readiness: 0 0 0 0 1
Revision: 00H43001
Revision: 00004001
Coding: 0000000002
Coding: 160A00
Revision: BO034001
Coding: 042200
1 Fault Found:
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 283661 km
Time Indication: 0
Date: 2016.06.24
Time: 00:04:17
Serial number:
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:23)--------------------------
The interior lights continue to work with the ignition on.
Yes i still have bcm 086
Posted: Tue Feb 01, 2022 6:45 pm
by ciclo
Ok, I assume you have repeatedly checked the opening and closing of the rear sliding doors, and then you have done the autoscan, right?
I'm assuming your T5 doesn't have interior lights dimmer switch installed?
Please tell me the exact month and year of manufacture of your T5, it is important to check the diagrams.
Posted: Tue Feb 01, 2022 8:53 pm
by samul
What exactly I made today:
Unplug acu -> wait a 2-3 minutes -> plug it back -> auto scan -> remove errors -> auto scan -> open and close sliding doors -> read errors -> run engine -> check errors -> enable lights -> disable lights > check errors
Production date: 2010-01-12
I have interior lights on front like this
https://bt-cars.pl/223404-large_default ... 105-c-.jpg but i assume this isn’t what you asking for?
This is basic, naked transporter
i changed switch lever, add 3 wires to instruments and active mfd. changed light switch (from AliExpress with internal light sensor) but drl wasn’t started so I left it. Right now I changed bcm to install ccs but I stuck with mentioned earlier problems. No more changes in wiring
Posted: Wed Feb 02, 2022 5:25 am
by ciclo
Well, it is highly likely (but not 100%) that the problem is in the BCM coding regarding the "model" of lock installed for the central locking of the tailgate.
I think the lock is not sending the correct signal to the central locking and that is why the interior light stays on in the conditions where it should go off.
The Bytes involved are Byte2 (Bit3 and Bit5) and Byte7 (Bit4 and Bit5).
;LC,02,3,Zentralverriegelung/Heckklappe: ZV-Regler in eine Richtung verbaut
;LC,02,5,Zentralverriegelung/Heckklappe: Schloss mit vorheriger Verriegelung verbaut
;;LC,07,4,Heckklappenschloss mit Safe
;;LC,07,5,Motor fur Zentralverriegelung Heckklappe NICHT verbaut
It is impossible for me to know what type of central locking lock your T5 has installed for the tailgate, so you will have to try all possible combinations of said Bytes until the interior light does not stay on under normal conditions.
Start by testing this new BCM coding:
A8A0393A0E212013002008103C2B8C500000430F60060000300000000000
to know what new faults appear...
The fault diagnosed in the Gateway will disappear once the BCM coding is correct.
Posted: Wed Feb 02, 2022 9:16 pm
by samul
It seems that i have bad coding since i bought this car... I found auto scan from 11 May 2021, there was also Intermittent errors from sliding doors.
Revision: 00H43001
Revision: 00004001
Coding: 0000000002
Coding: A0A0203A0E212023002000003C2B8C540000430F60062040300000000000
2 Faults Found:
Fault Priority: 2
Reset counter: 216
Mileage: 255207 km
Time Indication: 0
Date: 2015.05.15
Time: 20:04:40
Fault Priority: 2
Reset counter: 222
Mileage: 255207 km
Time Indication: 0
Date: 2015.05.15
Time: 20:04:40
Coding: 160200
Coding: 042200
1 Fault Found:
000 - -
Fault Priority: 2
Reset counter: 255
Mileage: 255179 km
Time Indication: 0
Date: 2015.05.15
Time: 16:50:42
Serial number:
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:20)--------------------------
Is there any chance to get somehow original coding of bcm 086?
this was latest coding from you, earlier i paste you auto scan without errors... after night errors from sliding doors return.
I spent some time testing the encodings today, i tried to disable almost all function... currently waiting for the battery to recharge,
