RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
Re: RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
smg_shardul wrote: Sun Oct 15, 2017 4:18 pm I am unable to take vcds scan report it’s not working properly
For cornering lamp of right side I tried to test from output test it’s working but when I steer to right side it’s goes off in 2 secs..
Any solution to this ?
Your problem is that you bought the bixenon headlights 'repaired' and it seems that during the repair someone make a mistake with the positions of wires.....viewtopic.php?f=56&t=70289&start=75#p525570
For example, check the connections/wires inside the bixenon headlamp are in the right places (compare with left headlight).
I insist that I am not yet a fortune teller, magician o similar, but is likely what is happening with your right headlight.
Anything new about these little problems?
smg_shardul
Drives: Polo 6R
Post by smg_shardul »
ciclo wrote:Anything new about these little problems?
Today I tried to connect licence plate light to Bcm as per instructions the bcm wire is to be connected to blue grey wire in boot door but there is no such wire present
All wires are white in colour and 2 wires connected to licence plate are also white in colour should I connect to +ve terminal of the wire ?
Below is the photo of connector of licence plate light .
smg_shardul
Drives: Polo 6R
Cornering light issue solved after replacing defused D3S bulb...
It’s working fine now.
Only 3 things left
1) dimmer switch
2) wiring to licence plate light
3) coming home (semi automatic )may be due to incorrect coding vcds scanned report I will share tomorrow some codes are different need to change.
Thanks ciclo without your guidance and wiring this DIY was impossible..
Okay, do not worry, tomorrow we'll correct the BCM coding and do a BCM coding so that all the optional functions are activated.
smg_shardul
Drives: Polo 6R
sorry was really busy in work couldn't find time
here is the scanned report
i am unable to edit code so some codes are still not changed
Friday,27,October,2017,18:35:04:39744
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: MEXA16608GT067313 License Plate: ,MH9SHARDUL
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 56 0B
Address 01: Engine (J623-CWXB) Labels: None
Part No SW: 03L 906 023 SN HW: 03L 907 425 B
Component: R4 1.5l TDI H33 9977
Revision: --H33--- Serial number:
Coding: 00250116032500080000
Shop #: WSC 00000 000 08192
ASAM Dataset: EV_ECM15TDI20103L906023SN 001001
ROD: N/A
VCID: 040057528F805F66AE-8050
No ASAM data for: "EV_ECM15TDI20103L906023SN" (VW25)
Readiness: 0 0 0 0 0
Part No SW: 0AM 300 065 L HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6501
Revision: 00043014 Serial number: CU501510066015
Coding: 0000020
Shop #: WSC 01324 785 00200
VCID: 3878F3A24BC8CB8672-806C
Part No SW: 6R0 907 379 BN HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2C63422907C74617346A4254E0820908
Shop #: WSC 28939 002 1048576
ASAM Dataset: EV_Brake1ES9P0iBOSCH 003031
ROD: N/A
VCID: 0B127C6EA2DE101EEF-805E
No ASAM data for: "EV_Brake1ES9P0iBOSCH" (VW25)
1 Fault Found
0931 - ROD - Unknown Error Code
- 00 [009]
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 47
Mileage: 32861 km
Date: 2019.14.15
Time: 18:24:23
Address 04: Steering Angle (G085) Labels:* None
Serial number: 26071513471359
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X_VW25.rod
VCID: 7EF425BAE16C35B6F8-802A
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 418E9E46D8128A4EC5-8014
1 Fault Found
00457 - Control Module for Network (J519)
013 - Check DTC Memory - Intermittent
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Mileage: 32861 km
Time Indication: 0
Date: 2019.14.15
Time: 18:31:40
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 173171271
Coding: 3A904BBF48E10200013807916CCB96905A88676F600D30C1200000030000
VCID: 2B52DCEE4A9E701E0F-807E
Subsystem 1 - Part No: 5K7 955 559 C
Component: RLS 080617 04 42 0106
Coding: 008F77
Subsystem 2 - Part No SW: 6R0 959 802 CC HW: 6R0 959 802 CC
Component: ------------- 007 5521
Serial number: 13102670151005153008
Coding: 050000
Subsystem 3 - Part No SW: 6R0 959 801 BT HW: 6R0 959 801 BT
Serial number: 13202671151005132525
Coding: 050000
Subsystem 4 - Part No SW: 5TA 959 442 HW: 5TA 959 442
Serial number: 2991519341401746AJ2B
Coding: 250000
Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Component: ------------- 006 5520
Serial number: 13202580151005230949
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13102581150929004312
Coding: 020000
2 Faults Found
01504 - Bulb for License-Plate Light (X)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 47
Mileage: 32861 km
Time Indication: 0
Date: 2019.14.15
Time: 18:26:39
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 87
Mileage: 32861 km
Time Indication: 0
Date: 2019.14.15
Time: 18:31:42
Address 10: Park/Steer Assist (J446) Labels: None
Part No SW: 7E0 919 475 J HW: 7N0 919 475
Component: PARKHILFE 8K H06 0105
Revision: -------- Serial number: 28261224902578
Coding: 300104
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_VW75XAprkAssis8K 001003
ROD: N/A
VCID: 397EF6A6B8C2D28E8D-806C
No ASAM data for: "EV_VW75XAprkAssis8K" (VW25)
Address 15: Airbags (J234) Labels:. 5K0-959-655.clb
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW0121NNF
Coding: 003036
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_AirbaVW01BPAVW250 A01001
ROD: N/A
VCID: 499E8666E822420E1D-801C
No ASAM data for: "EV_AirbaVW01BPAVW250" (VW25)
Address 17: Instruments (J285) Labels:. 5K0-920-xxx-17.clb
Part No SW: 2H0 920 871 B HW: 2H0 920 871 B
Component: KOMBI H04 1009
Coding: 140A080000
Shop #: WSC 13202 938 12345
ASAM Dataset: EV_Kombi_UDS_VD_DRM09 A05730
ROD: N/A
VCID: 275A20DE5E76547EEB-8072
No ASAM data for: "EV_Kombi_UDS_VD_DRM09" (VW36 *)
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 102300
VCID: 68D863E29BE89B0622-803C
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H04 1009
ASAM Dataset: EV_Immo_UD_SVDD_RM09 A03710
ROD: N/A
VCID: 6ADC19EA8DE4A91634-803E
No ASAM data for: "EV_Immo_UD_SVDD_RM09" (VW36 *)
Address 44: Steering Assist (J500) Labels:. 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ASAM Dataset: EV_SteerAsssiNSK 014008
ROD: N/A
VCID: 418E9E46D0128A4EC5-8014
No ASAM data for: "EV_SteerAsssiNSK" (VW25)
Part No SW: 6RD 035 187 A HW: 6RD 035 187 A
Component: MIB2-S-R-CN 025 0210
Revision: -----001 Serial number: 02425GD0000489
Coding: 0000044004000A
Shop #: WSC 00081 790 00133
VCID: 45868A56CC3AA66EF9-8010
3 Faults Found
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 47
Mileage: 32861 km
Time Indication: 0
Date: 2019.14.15
Time: 18:26:08
00875 - Treble Speaker Front Right (R22)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 47
Mileage: 32861 km
Time Indication: 0
Date: 2019.14.15
Time: 18:26:08
00874 - Treble Speaker Front Left (R20)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 47
Mileage: 32861 km
Time Indication: 0
Date: 2019.14.15
Time: 18:26:08
End-------------------------(Elapsed Time: 02:55)--------------------------
Ok, we'll wait for you to install the Dimmer :?: and connect the license plate lights.
smg_shardul wrote: Mon Oct 23, 2017 8:29 am Hi Fernando ,
How to find difference between part number ?
I want to find the difference between part Number 6R2941039A, 6R2941039B, 6R2941039C, 6R2941039D
Can you help me out here ?
Regards
Shardul.
https://ifinterface.com/page/page3.php?langid=1 ... how does it work? :arrow: viewtopic.php?f=10&t=42713#p466570
therefore, the difference is in the date in which these models bixenon headlights were installed.
Left --- for 6R RHD
smg_shardul
Drives: Polo 6R
Regards
Shardul.
Left --- for 6R RHD
This means any part from 4 of them can be fitted to one vehicle?
No, all parts of a system (set of parts) must be of the same production dates according to ETKA.
ETKA will tell you if the parts are compatible with each other.
These previous links are also included in the installation guide... :|
smg_shardul
Drives: Polo 6R
My friend is having polo sedan his existing car have only fog lamps he upgraded Bcm which supports cornering lamps and he want to connect it to fog lamps how to connect it?
If we connect just two wires T73/B9 & T73/B10 to +ve of fog lamp will it work ?
Thanks in advance
Maybe, ...show me a fuse box picture and an autoscan from that Polo Sedan.
smg_shardul
Drives: Polo 6R
ciclo wrote:Maybe, ...show me a fuse box picture and an autoscan from that Polo Sedan.
Ok I will share you vcds scanned report and fuse box pic by tomorrow
Thanks ..
Regards
Shardul..
