Vento ~ Polo Sedan 1.5 Tdi RHD
sshakthi123
Drives: Vento 1.5 TDI MT and Polo 6R 1.2 Tsi Dsg
Re: BCM Max upgrade in Vento IND manual transmission
Post by sshakthi123 »
Thank you iichel. I will share as soon as I get it.
sshakthi123
Re: BCM Max upgrade in Polo Sedan (Vento in india) manual highline
Ciclo,
ciclo wrote: Thu Jan 10, 2019 5:46 pm I have added two Butt terminals in the steering column ring wiring to prevent you from having to remove the fuse box in case of other retrofits in the future. The fuses will remain the same (like in the pic).
I'm planning to take +15 and +30 signals from these butt terminals for,
1. Glove box light (+30)
2. Indirect TPMS and ESP off button (+15)
I know you already mentioned, fuses remains same, still wanted to confirm once.
Thanks in advance.
- Sakthi
Yes.
Advise:
For the glove box light take the positive from the wire that feeds the footwell light, but the negative must be from a common ground point (chassis).
This will prevent the battery from draining in case of breakage or failure of the glove compartment switch.
:arrow: https://drive.google.com/file/d/1Fuic3f ... sp=sharing :)
sshakthi123
Got it. Thanks Ciclo.
sshakthi123
sshakthi123 wrote: Tue Aug 20, 2019 7:31 am Thank you iichel. I will share as soon as I get it.
iichel,
Please find the coding from similar car - Vento, manual diesel transmission. As I said before, this is a retrofit and not from the factory.
Can you help with this.
   Part No SW: 6R0 907 379 BN    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0001
   Serial number: --------------
   Coding: 62DD2C63212507C4461434708459E0820909
   Shop #: WSC 00788 648 00255
   VCID: 0B15112DA2455712B0-805E
Yes, this is excellent. Let's try the first coding, as soon as you have the ESP block in your car. I'm sure we'll figure out a good coding, maybe not in the first try but surely in the last.
sshakthi123
iichel,
I will be installing the ESP block over this weekend or sooner, can you give me a first coding so I can get the installation and coding completion to drive it and we will try more as needed.
iichel wrote: Mon Aug 19, 2019 8:16 pm It is not very easy to calculate an ESP9.0i coding, but I'll give it a try. I don't have any scans of cars that received this from factory.
My best guess for your ESP 9.0i module:
62DD2C63212A07C54615346A8459E082090D
With
HHC
ASR disabling by button
TPMS indirect
XDS
If you know anyone with the same configuration and ESP9.0i (VW Vento/Polo Sedan, RHD, diesel engine, manual), please post the coding here.
This will make the accuracy of the coding better.
Yes, it's this one.
sshakthi123
Ciclo, iichel, Nikhil, Patil, Sheethal
Thank you for all your great help. I'm done with ESP installation.
[youtube]https://youtu.be/fljUpbldvx0[/youtube]
Coding - I have used the one Nikhil had given me (62DD2C63412A07C54615346A8259E0820909)
@iichel - the one you had given returned Error 31.
HHC - works fine
XDS - didn't know how to check (adapted to "Strong")
HBA - adapted to "Early"
TPMS - indirect TPMS added
Let me know if you have any suggestions.
Regards,
Sakthi
Re: Vento India mods - BCM Max, Auto lights, ESP, etc
About what would you like to receive a suggestion?
sshakthi123
iichel wrote: Mon Sep 09, 2019 6:54 pm About what would you like to receive a suggestion?
If any coding updates required
It's fine like this
sshakthi123
ciclo wrote: Sun Aug 25, 2019 12:23 pm Advise:
Ciclo,
It helps. Wiring done as per your advise :D thank you master. thanks to Patil as well for his time and help.
sshakthi123
Ciclo,
I'm planning the below as a next upgrade,
1. Composition or Discovery media
2. Sharkfin antenna
3. OEM sub woofer with amp (that should fit in inside the spare wheel)
Please help letting me know the required parts and how/where it can be sourced.
as always, appreciate your help in advance.
- Sakthi
https://www.ebay.com/itm/NEU-Antenne-6R ... SwA3dYdUaj
https://www.ebay.com/itm/VW-Plug-Play-S ... Swr41XIgxL
Find the information that suits your needs.
uk-polos.net, drive2.ru/com, team-bhp.com, etc.
