Page 9 of 10
Re: BCM Max upgrade in Vento IND manual transmission
Posted: Tue Aug 20, 2019 7:31 am
by sshakthi123
Thank you iichel. I will share as soon as I get it.
Re: BCM Max upgrade in Polo Sedan (Vento in india) manual highline
Posted: Sun Aug 25, 2019 12:06 pm
by sshakthi123
Ciclo,
ciclo wrote: Thu Jan 10, 2019 5:46 pm
I have added two Butt terminals in the steering column ring wiring to prevent you from having to remove the fuse box in case of other retrofits in the future. The fuses will remain the same (like in the pic).
I'm planning to take +15 and +30 signals from these butt terminals for,
1. Glove box light (+30)
2. Indirect TPMS and ESP off button (+15)
I know you already mentioned,
fuses remains same, still wanted to confirm once.
Thanks in advance.
- Sakthi
Posted: Sun Aug 25, 2019 12:23 pm
by ciclo
Yes.
Advise:
For the glove box light take the positive from the wire that feeds the footwell light, but the negative must be from a common ground point (chassis).
This will prevent the battery from draining in case of breakage or failure of the glove compartment switch.
https://drive.google.com/file/d/1Fuic3f ... sp=sharing
Posted: Sun Aug 25, 2019 12:45 pm
by sshakthi123
Got it. Thanks Ciclo.
Posted: Wed Aug 28, 2019 8:12 am
by sshakthi123
sshakthi123 wrote: Tue Aug 20, 2019 7:31 am
iichel,
Please find the coding from similar car - Vento, manual diesel transmission. As I said before, this is a retrofit and not from the factory.
Can you help with this.
Part No SW: 6R0 907 379 BN HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2C63212507C4461434708459E0820909
Shop #: WSC 00788 648 00255
VCID: 0B15112DA2455712B0-805E
Posted: Wed Aug 28, 2019 8:49 am
by iichel
Yes, this is excellent. Let's try the first coding, as soon as you have the ESP block in your car. I'm sure we'll figure out a good coding, maybe not in the first try but surely in the last.
Posted: Thu Aug 29, 2019 7:04 am
by sshakthi123
iichel,
I will be installing the ESP block over this weekend or sooner, can you give me a first coding so I can get the installation and coding completion to drive it and we will try more as needed.
Posted: Tue Sep 03, 2019 5:29 pm
by iichel
iichel wrote: Mon Aug 19, 2019 8:16 pm
It is not very easy to calculate an ESP9.0i coding, but I'll give it a try. I don't have any scans of cars that received this from factory.
My best guess for your ESP 9.0i module:
62DD2C63212A07C54615346A8459E082090D
With
HHC
ASR disabling by button
TPMS indirect
XDS
If you know anyone with the same configuration and ESP9.0i (VW Vento/Polo Sedan, RHD, diesel engine, manual), please post the coding here.
This will make the accuracy of the coding better.
Yes, it's this one.
Posted: Mon Sep 09, 2019 6:10 pm
by sshakthi123
Ciclo, iichel, Nikhil, Patil, Sheethal
Thank you for all your great help. I'm done with ESP installation.
[youtube]
https://youtu.be/fljUpbldvx0[/youtube]
Coding - I have used the one Nikhil had given me (
62DD2C63412A07C54615346A8259E0820909)
@iichel - the one you had given returned Error 31.
HHC - works fine
XDS - didn't know how to check (adapted to "Strong")
HBA - adapted to "Early"
TPMS - indirect TPMS added
Let me know if you have any suggestions.
Regards,
Sakthi
Re: Vento India mods - BCM Max, Auto lights, ESP, etc
Posted: Mon Sep 09, 2019 6:54 pm
by iichel
About what would you like to receive a suggestion?
Posted: Tue Sep 10, 2019 2:48 am
by sshakthi123
iichel wrote: Mon Sep 09, 2019 6:54 pm
If any coding updates required
Posted: Tue Sep 10, 2019 7:31 am
by iichel
It's fine like this
Posted: Thu Sep 12, 2019 6:11 pm
by sshakthi123
ciclo wrote: Sun Aug 25, 2019 12:23 pm
Advise:
Ciclo,
It helps. Wiring done as per your advise
thank you master. thanks to
Patil as well for his time and help.
Posted: Thu Sep 12, 2019 6:15 pm
by sshakthi123
Ciclo,
I'm planning the below as a next upgrade,
1. Composition or Discovery media
2. Sharkfin antenna
3. OEM sub woofer with amp (that should fit in inside the spare wheel)
Please help letting me know the required parts and how/where it can be sourced.
as always, appreciate your help in advance.
- Sakthi
Posted: Tue Sep 17, 2019 7:36 am
by ciclo
