---Onboard supply control unit---
J104 - ABS control unitK00591300803#BTJ104
J285 - Control unit in dash panel insertK00591300803#BTJ285
J446 - Parking aid control unitK00591300803#BTJ446
J519 - Onboard supply control unit, near driver side A-pillarK00591300803#BTJ519
J623 - Engine control unitK00591300803#BTJ623 K - Dash panel insert
T16p - 16-pin connector, brownK00591300803#BTT16p
T18a - 18-pin connector, near battery, greyK00591300804#BTT18a
T32 - 32-pin connector, blueK00591300803#BTT32
T47 - 47-pin connector, blackK00591300803#BTT47
T73b - 73-pin connector, colourlessK00591300803#BTT73b
T94 - 94-pin connector, blackK00591300803#BTT94
T94a - 94-pin connector, blackK00591300803#BTT94a
B383 - Connection 1 (powertrain CAN bus, high), in main wiring harness
B390 - Connection 1 (powertrain CAN bus, low), in main wiring harness
* - Only models with diesel engine
*2 - Gradually discontinued
*3 - Only models with petrol engine
*4 - Only models with automatic driving lights control
G24 - Tachograph
J345 - Trailer detector control unit, on left under dash panelK00591300803#BTJ345
J364 - Auxiliary heater control unit J519 - Onboard supply control unit, near driver side A-pillarK00591300803#BTJ519
T6b - 6-pin connector, black
T12 - 12-pin connector, redK00591300803#BTT12
T12f - 12-pin connector, black
T17f - 17-pin connector, behind glove compartment, black
A146 - Connection (convenience CAN bus, high), in dash panel wiring harness
A147 - Connection (convenience CAN bus, low), in dash panel wiring harness
B397 - Connection 1 (convenience CAN bus, high), in main wiring harness
B406 - Connection 1 (convenience CAN bus, low), in main wiring harness
* - Only models with no start/stop system
*2 - Only models with automatic driving lights control
In the diagrams of the Polo 6R these connections are not present, hence the confusion to upgrade to BCM Maxx 7H0937090?... (and "new steering wheels" with BCM "7E0" 937 089/090/090A ???-pr code)
Ah okay. As I read it, the T73b/18 and T73b/19 are always present and the T73b/54 and T73/b are optional (only with *4 automatic driving lights control and *2 gradually discontinued)
In 6R the problem was detect the instrument cluster to upgrade to BCM Maxx and improve equipment ... and as always in these upgrades is necessary that the wiring is in the right place.
your current BCM from your BlueGT is better ... 7H0937090B vs 7H0937090 ... all you have to do is unplug the white connector and check if you have the CAN wires at positions 54 and 57.
...but I am afraid that these BCM are not suitable for new steering wheels if someday you want make this upgrade.
It would be nice if with BCM 7H0937090 that I gave you, I could do new tests and also check if the trick works in my R-line without start-stop system.
I will then resend.
This airbag is perfect for Polo 6R, but if you install this type of airbag on a 6C you have to change the blue-white wire from T12/8 to T5/4 (with the proper terminal) and other changes depending on equipment. Or if you prefer http://www.aliexpress.com/item/OEM-Mult ... 40210.html
