That's such a cool picture!!alexperkins wrote:I did - thanks mate
Teaser photo....
The GTI! - Alex's Thread - Leather :D
The GTI! - Alex's Thread - Back on the GTI scene :)
- Trottagti
Re: The GTI! - Alex's Thread - Back on the GTI scene :)
Why they wasn't colour coded from factory I do not know..... CC splitter is for winners.
gregperkins
- Drives: 2011 Ibis White Audi A3 2.0 TDI Sport
My splitter is actually covered in red carbon, but in the picture it looks like paint!
Tim_GTi wrote:Very nice!!
Man that CC splitter makes a huge difference, looks great. You gunna have it done on yours also mate?
Cheers guys. Will try get a few more up tonight
@Tim - Yes gonna do it to mine when I get a spare 5 minutes. Ive got a spare brand new GTI splitter should it all fail. Will probably sand down the original, fill the dents and paint it up myself
- Tim_GTi
- Post Whore
HA! Just switched to my macbook after viewing this thread on my phone, I didn't realise the three cars! Only shows up two on phone
I noticed that too
I think between me, dad and greg we own the majority of red polo GTIs in Poole and bournemouth haha
- Endi_GTI
Sweet Picture Alex, may take a drive up to add to the photo
bradley1983
I'm still around thanks Mr Perkins!!!alexperkins wrote:I noticed that too
You are indeed Brad
In any case a little update
I fitted LEDs all round - namely number plate lights, interior lamp, boot lamp and sidelights for under a fiver! In the process of doing so, I managed to knock the back of the drivers headlight and smash the leveller clip which seems to break on all the polos and often render headlights to the grave. I was in discussions with a guy to billet then out of aluminium, which he has now done and they are pretty damn good. Though I couldnt wait, so got one of these:
And my drill and file out and got to work on making a new one. Needless to say it was a great idea for replacement and worked a treat. For anyone interested its an 8mm hole, with a 5mm groove cut into the 8mm hole, then a countersunk hole on the back to screw into the headlight.
The passenger side window motor failed, then the drivers side jammed. So i proceeded to replace the pass side, and unjam the drivers. Put it all back together to find 30 mins later it had locked up again!! So had to take it all off again and replace the motor on the drivers side too! What a palava
Ive added a few little touches to the exterior - ill get a photo up later
Managed to source a brand new set of rear mudflaps, and currently in the process of sorting some front ones out, though as im currently running 50 profile tyres, I cant fit the flaps on as the gap is too small and itll cause the mudflaps to rub
Also double braced the front exhaust bracket as sadly itd rusted away and someone had made a feeble attempt with mild steel jubilee clips to fix it. Changed them for two marine grade stainless steel ones - needless to say its never coming apart now!!
I also managed to strip one of the engine mount bolts when replacing the left engine hydromount. They are fixed into cast alloy, so not very strong at all after a few times of removing and refitting. Picked up a helicoil kit on ebay for under a tenner, and its worked a treat. If anything, the helicoil thats in there is stronger than the original fixing. Its certainly not going to strip any time soon
Some more photos for you all
Aquavalver
- Drives: 2013 Polo Blue GT
I've just done this too! Did you find the paint on the rear ones had flaked off/lifted a lot?alexperkins wrote:Painted the calipers yesterday
Looks much fresher to say the least!!!
The rears were awful. This is mainly due to the fact the rear calipers on newer dubs are cast aluminium as opposed to steel on the fronts
Hey Alex loving the last picture with the autumn trees in the back ground
3 polos in one family is a good effort
You're probably the best person to ask Mr Perkins as i know you've done this a few times.
On a G60 brake upgrade i have got some Carriers ready but was wondering what discs and pads you recommend?.Can i buy regular G60 Pads and discs?.I guessing the discs need to be 22mm think rather than 25mm?.
