BBS RX2 (GTI Split Rims) Refurb Guide
- bstardchild
- Moderator
- bstardchild
- Moderator
- bstardchild
- Moderator
As long as they are 3/8 drive they willinder wrote:great stuff, thanks for that - going to go for that 3rd link 'Torque Wrench 3/8" Drive - Brand New'
recon that's good? will fit to all my sockets?
- please don't use it as a ratchet for everything - it'll lose it accuracy
- remember to fully unwind the setting to zero when you've finished with it
I have very few 1/4 or 3/8 drive sockets - actually i have on set of each but I rarely use anything smaller than 1/2 and have a complete inch drive set (thats big boys toys
Has anyone used mirror polish? lol i have plenty of enhtusiasm but very little experience. If i wanted to mirror polish a 1 piece wheel would i have to strip it down then polish straight away? or powder coat it then polish over that? I want a finish like Silky V's design 90's if anyones seen em
http://www.tigerstyle.co.uk/poloforum/v ... hp?t=23068
After reading this guide and being a bit (no pun intented) confused about what tool to use to fit the bolts on the rim....I though I'd add my bit.
The bit needed (mentioned here as a VM8 tork bit) often confususes guys in the trade as it's not commonly used. An alloy refurb guy described it to me as a tool that the Germans love just because its a German thing.
....the bit thats needed is also known as a spline bit / multi-spline bit. Not to be confused with a standard tork (torque/torx) or star bit. These have about 6 points, the bit you need for the RXII has about 12 points.
It's available in most 'specialist drill bit sets'. I got mine from Halfords £19.99 for 5 bits various sizes). Halfords tools generally get a bad write up (and from my own experience) but the one I bought (halfords) was stronger than the titanium BBS bolts used on the RXIIs.
Most of my bolts came out very easily, but the ones that didnt caused me a real problem and now I'll have to get them drilled out, or removed by an engineering workshop. I'll probably ask a shop to remove them as I dont want to risk drilling out the mating thread on the wheel itself. I've heard a n impact driver is essential to shock the problem bolts out, but I was stupid enough to think my wheels wouldnt need that.
have fun
have fun
Hello
Good DIY Guide.
I'm going to start doing this over the summer to my new GTi - the wheels are not bad - but i like the polished lip!
Few of my own questions:
1. Did you use new bolts to build the wheel back up ? If so where can i get them! If not - how did u clean them to be new and silver again ?
2. Where would i be able to get new centres ? Ebay / VW yeah ?
3. Do you have to seal the two parts again for sure yeah ? And this will stop it repeating ?
4. Do you think a this will look good with a silver centre!
Thanks!
Neildo.
Good DIY Guide.
Thanks!
Neildo.
Redline
- Sponsor
- Drives: BMW 128ti
To try and answer some of your questions:www.neil-f.net wrote: Few of my own questions:
5. Did you use any power tools - or just hand tools ?
Thanks!
Neildo.
1. There's no reason to use brand new bolts, unless you damage some on removing them. Being titanium the bolts tend not to corrode so I don't know why they might need cleaning up?
2. If you mean centre caps, eBay has them all the time, and VW would be able to as well.
3. You don't have to use sealant on rejoining the centre to the rim. It does help prevent water getting between the two parts however.
4. Will what look good?!
5. I've never used power tools on the refurbs I've done. What I would recommend, as garnier says above, is investing in an impact driver to loosen the bolts initially.
To try and answer some of your questions:Redline wrote:www.neil-f.net wrote: Few of my own questions:
Thanks!
Neildo.
Ok thanks , i thought maybe the bolts would look old when the wheels were all redone and clean ! If i do want to get them all clean and shinny should i drop them into some paint stripper for a few mins - would this clean them up and make them nice and shiney new looking ?
Thanks , id like to get new ones if when i do this next month !
Maswell put some sealant in then while there split
With the lip polished and the centres still silver (instead of black like the the wheels in the diy guide.
Nice One, just hard work then. I know its a hard question to answer - but how long did it take you to make one wheel lip shiney with the autosol - seems the best to use ?.
Many Thanks for the time.
Neildo
If you don't fancy DIY try BJV Engineering . They are doing a full refurb on mine for £40 each as I've already split the rims. The centres will be powder coated and the rims will be diamond cut and laquered as per the originals. I have refurbed a set in the past and think it's worth spending to get them done properly.
