Urgent help needed, fitting angel eye headlights
ModifiedMadness
- Sponsor
Ok, put it this way; they should not be HID headlights.
I still think if you have halogens and you want a crisp bright white, the best thing is to get the philips bulbs and add relays to bypass the cars wiring loom voltage drop.
Totally safe legal and works very well indeed. In fact, why they not design it like that in the 1st place!
hey mate...they look nice...i have a set on my mk4... they look a bit different to mine though...i had a problem with the halo illumination but you dont seem to have that prob... as in you can see the brightness of the bulbs around the ring... so i constructed my own illumination using 24 3mm LEDs..
fitting them is a nitemare i know...took me 3hours when i recieved em, as you ahve to cut around the plastic on the mk4..
the harness comes with relays so why would you need some more for the phillips bulbs?
put HIDs behind the projectors, they look the best behind projectors, thats my next plan for mine anyway...
