Boot Light - 03 Tdi Sport
Blade
Post by Blade »
vwclub.gr: could you post some extra pics on how you connected the ccfl's?
inder
Post by inder »
Blade wrote:vwclub.gr: could you post some extra pics on how you connected the ccfl's?
PC cold cathodes come with a little black box with the electrics in, so all you need to do, is cut off the PC molex and connect the remaining two wires from this box (red and black) to a 12v and -ve supply in the car, very simple
Hope helps
vwclub.gr
Post by vwclub.gr »
exactly, just cut the car's connector and connect the - to the black cable of the inverter's connector and the + to the red. From the other side of the inverter you have the 2 plugs for the 2 cool cathodes. It is very simple
inder
Post by inder »
yep, just make sure the 12v your using to supply power to it, is fused :)
Blade
Post by Blade »
The problem is I don't have a boot light/connector. Hopefully I can find the right connector with the guide pictures ( http://www.tigerstyle.co.uk/poloforum/v ... .php?t=976 ).
inder
Post by inder »
Do you have an amp in the boot? you can run it off the same feed as that
vwclub.gr
Post by vwclub.gr »
yes but the cool cathode won't light its time the boot is opened but it will be always on
inder
Post by inder »
Good point, still could put a switch on it - to put on/off manually though
or if you still can't find the loom for boot light or it is not present, you could install your own micro switch to control light on when boot is opened or wire directly into the micro switch in the boot lock
Goosey
Post by Goosey »
Mine has a light :idea: maybe it's an SE thing! sorry Sport guys! :lol:
