Cameblt question, help!!
Sorry if I was not being clear. The info you need is on your build sticker (the sticker is about 10cm by 5cm at a guess) - the sticker contains info about your car such as colour, options, engine code, gearbox code, etc
The build sticker is located in the front of your service book. If you don't have your original service book then there should also be one on the car somewhere (i'll look for mine later) but try inside the boot, or on door pillars - basically they are not hidden.
When you locate it you will see ARC in big letters (this is your engine code) to the right of this will be (probably) ETG in big letters also (this is your gearbox code)
ModifiedMadness
- Sponsor
