Little problem with the 1.4 16V
NOZ
Post by NOZ »
chunkychimpanzee wrote:
Tailor wrote:what is the throttle body? Where can I find this under the bonnet? Sorry, I am not good at mechanic side.. only good at cleaning the body work... :oops:
The throttle body is the part fitted to your air filter unit. Sits behind the engine block.
Iv had a few induction kits since and diagnosis said 'missing speed signal', no idea where to look for that. The temp sensor's the only thing I didn't check so far so i'll get on it asap
The speed signal is in the transmission chassis :P Its cnnected to the clutch and all that :D
Tailor
Post by Tailor »
The throttle body is the acelaration opening, it is under the original airbox, or if you have fitted an induction kit you will see it straight away.
It looks something like this:
http://www.bba-reman.com/content.aspx?c ... ottle_body
chunkychimpanzee
Post by chunkychimpanzee »
Thanks you guys.. I will have a look at these when its nice and sunny.. I may have to replace the temp sensor eventually, as it shows that does not work properly from the speedo... :?
