Boost and Oil Pressure Gauge
david burton
Post by david burton »
kc wrote:best way to route the pipes if through the grommet where the bonnet latch will come through on LHD cars, plenty of room to play with
i think my amp power wire is using that.... :(
Gti_Lew
Post by Gti_Lew »
get rid then, excess weight, not needed :D
david burton
that's why I was asking if you can get ones that convert the pressure to an electrical signal before sending it to the gauge.
hmmm, the car is all about comfort and speed. If I was only bothered about speed there'd be no amp and no seats either! it's all about compromise :)
oh, and no heavy wheels 8)
Gti_Lew
Post by Gti_Lew »
thats the principle the diesel dump valves work on isnt it? electrical signals? i cant imagine the ECU would be impressed? not sure tbh
kc
Drives: an imaginary one... for now
Post by kc »
mine uses that as a amp cable too cheif, but its only a 1mm vacuum that you need to get through and it will fit... unless your running 0awg power cable...... which in that case... it will still fit!!
flyfs6
Post by flyfs6 »
Neat job dude. I dont have anywhere to put one at the moment, as my Pogo sits on the right and centre is occupied by a cubby box.
david burton
kc wrote:mine uses that as a amp cable too cheif, but its only a 1mm vacuum that you need to get through and it will fit... unless your running 0awg power cable...... which in that case... it will still fit!!
I drilled it out for the power cable - but maybe I've got the wrong end of the stick - I used the hole on the passenger footwell for this, and there was already a pipe through there (washer?), so that's why I had to widen it.
sounds like a plan, 1mm pipe is a lot smaller than I thought.
