Public Service Announcement
- KennyPOLO_Gti
Dont bother with a H its not worth finding out if it will work on your car or not, The H requests more boost and smooths it out but is prone to limp mode as i found out, J requests less but smooths out the boost, the OEM isnt smooth, and surges around 3200 but in that surge provides up to 1,4 bar boost, personal preference tbh
- KennyPOLO_Gti
you dont lose any boost with the J valve, across much of the rev range you actually gain boost, just not as mush as the h valve increases boost by
mine is a diffferent car, power wise and smooth wise with my J valve fitted and i strongly advise people running tweeked cars to get one, one fdrive and you will notice the difference yourself
dont worry about losing your boost tho kenny, as you dont, you still gain between 1 - 3 psi, from reading on other forums
