Looney tuned project
david burton
...Roadrunner...
The windows aren't so dark as they appear in the pictures. The film i used for tinting is called "reflexive", so when you look from a smaller angle it seems to be darker, that they actualy are.
The wheels are indeed very light. They only weight 6.8kg/piece. This is the reason i bought them in the first place. I also like them very much, because it gives the car an motorsport look.
This week-end i will complete the first custom tail light. I will put some pictures as soon as possible
PS: I want to thank you all for your warm welcome.
...Roadrunner...
No. They were done by
No. They were done by a tinting company. The film is made by Llumar.
...Roadrunner... could you look under your side skirts and tell me how they are secured to the sill please. I got these skirts on my car, they are secured on the ends - one side two bolts and other slots in. When I got them and fitted them they have two feet about two foot away from both ends that I couldnt work out how they are ment to secure to the sill. I ended up making a bracket and sticking them to the sill. Are there any securing parts on yours that use the origonal mounting holes for the standard skirts?
Did you not get the two plastic Z brackets with the sills? The fit over the tabs on the sill and are secured with push on metal clips.MateyGuv wrote:...Roadrunner... could you look under your side skirts and tell me how they are secured to the sill please. I got these skirts on my car, they are secured on the ends - one side two bolts and other slots in. When I got them and fitted them they have two feet about two foot away from both ends that I couldnt work out how they are ment to secure to the sill. I ended up making a bracket and sticking them to the sill. Are there any securing parts on yours that use the origonal mounting holes for the standard skirts?
You then glue the sill to the car on the two flat faces of the plastic brackets the flat faces above the jacking covers and along the top edge.
I'll post up the diagrams shortly
...Roadrunner...
...Roadrunner...
[/img]
