"new" coilovers........
Kelk11
Post by Kelk11 »
coilovers can go on either side, regarding camber there is a limit at which they can be adjusted so mine is a 1 degree the best i could. have a look in the gti section about 10 topics down that is mine lowered.
kipper
Post by kipper »
Kelk11 wrote:coilovers can go on either side, regarding camber there is a limit at which they can be adjusted so mine is a 1 degree the best i could. have a look in the gti section about 10 topics down that is mine lowered.
guessing its a red gti then?
when u say yours is 1 degree do u mean u got a negative camber of 1 degree?
if so mine isnt that far of that but i wanna lower mine more but still wanna make it so the wheels sit flat not angled.
Kelk11
Post by Kelk11 »
yes it is the red one, its 1 degree negative camber it was the closest to zero it would go, before it was done it was over 3 degrees out.
Tim_GTi
Post Whore
Post by Tim_GTi »
1 degree out is nice, looks better and technically better handling 8)
kipper
Post by kipper »
hows it better handling then? wouldnt it mean it would pull to the side more tho?
Redline
Sponsor
Drives: BMW 128ti
Post by Redline »
No, because it's going to be -1 degree each side isn't it, so it shouldn't pull to one side if it is setup equally.
Negative camber gives a greater tyre contact patch during cornering, that's why a slight amount tends to be good.
kipper
Post by kipper »
so no more then 1 degree is fine then?
do u know much the car lowers once the coilovers have settled?
i put them on last tuesday and adjusted them on thursday and since then it seems to be lower so im guessing its settled but am gonna leave it for a bit then maybe even lower them more.
Tim_GTi
Post Whore
Post by Tim_GTi »
i would've thought a week would be a good length of time to let the springs settle.
kipper
Post by kipper »
well it looks like they settled and since stlling they seem to of lowered themselves between 15-20mm. prob lower it more tho over the nxt week or so...... not scrapping enough bumps.......... well any actually :D
