Just about feeling well enough to tackle this. The biggest bugbear of this process for me is that I don't have access to a laptop with XP so I have to take my pc out to the car
I hope someone can help (and I hope you are reading Alex
Using their instructions as per their Wiki page for Throttle Body Alignment, I keep getting an error message. It states -
"No Response from Controller"
This message appears a minute or so after I have selected 01 - Engine.
The instructions say that "There are certain test conditions that must be met before doing a TBA -
No DTC's in the Engine Controller (Cant get into it to find out)
Throttle at idle position, foot off pedal. Yes, I was sure not to do that.
Throttle body must not be carbonised (
Coolant Temp between 5 and 95 degrees. Yes.
Battery Voltage at least 11.5v.
Not having a meter here to check the voltage, I am wondering if it is the battery that could have caused this problem. My meter will be back with me tomorrow so I can check.
Can the battery voltage be that crucial and cause the No response from the controller?
Do you have any other ideas?
Many thanks in advance.
Jes.
