Page 2 of 2
Re: Paint splashes on the bonnet, need Help!
Posted: Fri Aug 14, 2009 6:28 pm
by gilbo-6n
not sure to be honest m8 cuz a can get it free from work lol a would say between £5 and £10er but am just geussing
Posted: Fri Aug 14, 2009 8:21 pm
by mwbpsx
i believe its basically just a petrochem solvent so petrol should have same effect
Posted: Fri Aug 14, 2009 8:22 pm
by mwbpsx
if you have access to a polishing machine if all else fails wet sand and polish
Posted: Mon Aug 17, 2009 9:27 am
by Joe123
i could ask a m8 as he works at a garage. Might wet and polishing work then ?
Posted: Mon Aug 17, 2009 8:03 pm
by mwbpsx
just had a thought !! b4 you wet sand it try a clay bar. worth a try
Posted: Tue Aug 18, 2009 9:21 pm
by Tim_GTi
Joe123 wrote:i could ask a m8 as he works at a garage. Might wet and polishing work then ?
Yes quite possibly with a machine polisher.
Posted: Wed Aug 19, 2009 12:04 am
by kipper
depending on how much there is u tried a plastic scraper like a body filler applicator or a credit debit card? i got some plastic body filler things that ive used to scrape paint of befor on my car. it was spray paint so dont know how much different it'll be.
all i did was rested the edg at about a 20 degree angle and go over the paint then slowly raise the applicator till it reaches and scrapes the paint away just dont be to heavy handed and rushing it to much. then u can wipe the paint of with a tissue or something.
thats wat i did when i scraped paint of.... might help u.
Posted: Fri Aug 21, 2009 2:56 pm
by Joe123
cant get hold of a machine polisher so will have to try something else. Whats a clay bar, dont think ive come across it before?
Thanks for all the help
Posted: Fri Aug 21, 2009 7:34 pm
by mwbpsx
halfrauds do a Meguires Kit, clay bar and lube, just follow the instructions. You might also try signing up to detailing world, there will be someone in ur area that will have a polishing kit
Posted: Thu Aug 27, 2009 7:56 pm
by Joe123
Finally managed to get the paint off!
The clay bar worked like a charm for the little specs then i used t-cut and ALOT of elbow grease for the big specs.
Cant believe i finally got it off
Thanks everyone for the advise
Posted: Fri Aug 28, 2009 12:50 am
by mwbpsx
glad to be of help
