Page 2 of 2
Re: Automatic hatch? Anyone?
Posted: Sat Apr 09, 2011 6:56 pm
by blazeguarder
Yeah, I had a quick look with vagcom yesterday and had the same problem as you. Just tried googling how it's done on Golfs and apparently they need to use version 704.1 to be able to change the option, as it's been removed from the current version.
I'm not particularly handy with vagcom yet since I only got it a couple of days ago, anyone else got any ideas where it might be?
Posted: Sat Apr 09, 2011 7:21 pm
by dood9n3
I have v10.6
Posted: Sat Apr 09, 2011 8:03 pm
by K.I.T.T.
if it is a coding problem (no conclusions drawn as yet), VAGCOM won't do squat. You need a hex editor (VDS-Pro) to do it. It's the same with the remote windows.
Ash
Posted: Sat Apr 09, 2011 8:35 pm
by Joz
Soo.. You can make the windows go up adn down in the polo with your remote just as with the golf?
Posted: Sat Apr 09, 2011 8:41 pm
by K.I.T.T.
Not on the 9n3 and some of the later 9ns. Only on 9ns built before 11/04.
Ash
Posted: Tue Apr 12, 2011 10:29 pm
by Joz
Bloody un-brilliant!
Bastards at VW!!!
This ruined my day..
Posted: Wed Feb 20, 2013 9:30 pm
by 9n3siss
hello,
ok have been trying to find the right struts to no avail....does any one know which ones work?
I dont care aout the vag-com as i have a clifford alarm that opens the boot for me...all the way i just need the right strut to push the tail gate up.
cheers
faz
Posted: Wed Feb 20, 2013 10:20 pm
by 9n3siss
hello again,
OK.....Found it......the struts you need are the ones from a
ford mondeo mk2 93-00
dimension
553 overall length
drop length 200
rod diameter 8m
shock diameter 19
force is 560 newton
now compare those with the original polo struts
polo 9n3(like mine)
dimension
500 overall length(not a problem as the length only opens as far as you need)
drop length 200
rod diameter 8m
shock diameter 19mm
force 400 newton
the ball joints on both are the same as the polo too...so it should be a straight swap.
let me know what you all think..now dont go buying these and stick em on your car....let me do it first and ill let you all know the outcome.
faz
For all those who have an original vw boot open button on there key fob...you will need to sort the system out with a vag-com.
but if you have an aftermarket alarm (like mine...Clifford)the all you need is the struts above...
Posted: Tue Jun 11, 2013 8:18 pm
by calvinw1
even though this was years ago, has anyone found a way to do this yet?
