You cant remove the bulb from the dash - its an LED. Itd need taping over or something but that isnt a fix at all mate!!!!
Scan it with VAGCOM and post up the fault codes asap.
Stuck, need advice/help
Re: Stuck, need advice/help
I know its not a fix, its an MOT passer though.
I'm almost 100% certain that the code logged will be -
"2 Faults Found: 00287 - ABS Wheel Speed Sensor; Rear Right (G44) 35-00 -00287
ABS Wheel Speed Sensor; Rear Right (G44) 16-10 - Signal Outside Specifications - Intermittent"
This is what i cleared after mending the sensor,
will check tonight
will check tonight
Thursday, 19 May 2011, 19:43:57
1 Fault Found:
00287 - ABS Wheel Speed Sensor: Rear Right (G44)
04-10 - Mechanical Malfunction - Intermittent
Hot off the press exactly as i sodding thought.
Why, why, why do i keep getting this code! Mechanical malfunction? its brand new!!
To add to my confusion it truely is intermittent, for example one thing that upsets the job is doing a u-turn to the right - weird!
Or it will just randomly occur under light breaking after driving for a good period, no rhyme or reason!
1 Fault Found:
Leave it with me. Ill put it into ELSA (VW workshop manual) and get the official error description
Thanks Alex,
I've got a feeling the sensor has slipped back from the tuning wheel, i.e. its not sitting directly over the top of it.
I had to JB weld in it and i reckon this explains why its very intermittent.
Re-seated the bastard and, touch wood, it seems ok.
Also, this time i had vagcom so could spin the wheel to check the reading.
