Lights!
NMavs
Re: Lights!
Post by NMavs »
NeilMcConville
Re: Lights!
Post by NeilMcConville »
With the 6000k and the Reflector yeah?
NMavs
Re: Lights!
Post by NMavs »
Id go for the 5000k with reflectors mate. Look alot better, 6000k are too blue. They dont cast as much light on the road itself.
CANDYMAN
Re: Lights!
Post by CANDYMAN »
Why go for the 35w Hid over the 55W hid? I thought Standard H7 bulbs are 55w so would you not do like for like??
CANDYMAN
Re: Lights!
Post by CANDYMAN »
Just found this on another forum relating to HID and engine re-map :shock: :cry: :shock: :cry: :shock:
Just for your info guys:
Changes to MoT from 1st January 2012
Taken from another forum:
Quote:
There are to be some changes to the MOT test from 1st January 2012 which are being introduced in response to European Commission Directive 2010/48/EU of the 5th July 2010 and which will effect those with aftermarket HID headlights and remapped ECUs:
4.1.4 Compliance with requirements:
(a) Lamp, emitted colour, position or intensity not in accordance with the requirements
(b) Products on lens or light source which obviously reduce light intensity or change emitted colour
(c) Light source and lamp not compatible
4.1.5. Levelling devices (where mandatory):
(a) Device not operating.
(b) Manual device cannot be operated from driver’s seat.
4.1.6 Headlamp cleaning device (where mandatory):
For anyone with a remap, section 6.1.9 may be relevant.
6.1.9 Engine performance:
(a) Control unit illegal modified.
(b) Illegal engine modification.
(by 'illegal', it is assumed that they mean changed/programmed differently from OEM specifications)
There will also be a new check on the general condition of the wiring:
4.11. Electrical wiring
(a) Wiring insecure or not adequately secured.
(b) Wiring deteriorated.
(c) Damaged or deteriorated insulation
and on the function of airbag and seat belt pre-tensioner systems:
7.1.4. Safety belt Pre-tensioners:
Pre-tensioner obviously missing or not suitable with the vehicle.
7.1.5. Airbag:
(a) Airbags obviously missing or not suitable with the vehicle.
(b) Airbag obviously non-operative.
7.1.6. SRS Systems:
SRS MIL indicates any kind of failure of the system.
hho87
Lights!
Post by hho87 »
Interesting read!
