Thanks - do you think the plug and wires are sold separately?alexperkins wrote:The plug will have a part number on it
You'll then need suitable vw repair wires to suit
New GTI Owner, P130 Error
Re: New GTI Owner, P130 Error
6n2stan
- Drives: 6N2 GTI, Golf GTD + R32, T5.1 BiTDI DSG
I chased my wires back over the gearbox then cut it out and started again. There isn't a plug at the other end so it'll need soldering whatever.
They are indeed
Your local vw parts department can sort it for you
Understood, thanks but if I can get the plug and a length, Ill cut back and sort. It looks like someone else has had a hack at it and it doesnt look good.6n2stan wrote:I chased my wires back over the gearbox then cut it out and started again. There isn't a plug at the other end so it'll need soldering whatever.
To clear the code, Ive tried to leave the car's battery disconnected for hours - do I need to use a reader to clear it? This assumes ofc the fault is gone - a quick test drive yesterday gave me no jerks - so hopefully its sorted.
