Drilled AirBox Opinions
Tony Boi 92
Re: Drilled AirBox Opinions
Post by Tony Boi 92 »
k&n
can someonelink me please to what i need?
love to all ;)
Yeahhluke
Post by Yeahhluke »
Tony Boi 92
So if i buy that, thats all i need? nothing extra?
And defo get a nice noise outta it?
sorry to be such a newb but on previous cars i havent touched the airboxes so i dont know what to expect
Yeahhluke
Post by Yeahhluke »
that will come with everything you need for fitting and instructions, and it will give your the 'loud roar' noise your after 8)
Lucaio
Post by Lucaio »
You just unplug the airbox and whack it straight on to the throttle body, 10 minute job to fit.
andyc315
Re: Re: Drilled AirBox Opinions
Post by andyc315 »
Lucaio wrote:You just unplug the airbox and whack it straight on to the throttle body, 10 minute job to fit.
You do not do this. Not at all. Tony has a 1.8t for a start!
You take the airbox out and attach the filter to the MAF/TIP. It also looks like it comes with a cold air feed which may or may not be better than standard you'll have to ask someone else about that bit.
Sent from my GT-I9100P using Tapatalk 2
Lucaio
Post by Lucaio »
That's what the K&N instructions had on it?
What have I done wrong?
The biggest problem with that setup is there is no feed of cold air as such. The position of that filter allows it to use all the surrounding air from the engine, which will be hot.
Lucaio
Post by Lucaio »
alexperkins wrote:The biggest problem with that setup is there is no feed of cold air as such. The position of that filter allows it to use all the surrounding air from the engine, which will be hot.
Yeah I thought that, I do have some hoses on the way so I can place it in the gap on the left and have the cold air hose pointing directly towards it.
These are similar to the instructions I followed (these seems to be for the 9n not the 9n3): http://www.knfilters.com/instructions/57-0530_inst.pdf
Ideally you want to pipe it to somewhere near the wing or front of the car so it can get a good cold supply.
Gtiandy
Post by Gtiandy »
There you go,
• remove the air box lid and filter
•fit cone filter to the MAF allowing filter to sit in the box
•Job done
Now you can remove the whole air box but you will lose your cold air feed from the front of your car, so I recommend leaving it there to minimalise heat soak
andyc315
Post by andyc315 »
Gtiandy wrote:Image
There you go,
•Job done
This is good advice!
andyc315
Re: Re: Re: Drilled AirBox Opinions
Post by andyc315 »
I just meant that it is totally irrelevant for Tony's engine that was all :)
Tony Boi 92
woah everyones awake today 8)
so go for it guys yeah?
sound like exactly what i want
Yeahhluke
Post by Yeahhluke »
Tony Boi 92 wrote:woah everyones awake today 8)
yes go for it 8) any increse or decrease in power that it would give you/ the heatsoak thing, you wont even feel, cause it will be minimal either way
