Mart!n-GTI-DK
Posts: 1401 Joined: Sun Apr 26, 2009 7:43 pm
Drives: '14 Polo BlueGT
Post
by Mart!n-GTI-DK » Thu Mar 05, 2015 11:51 am
Can I get the Part number for the 6C GTI grill?¨
And WOW that steering wheels actually looks cooler without the buttons... Looks more like a Porsche GT steering wheel.
And can you see it the 6C GTI grill has the same kind of "flat spot" behind the GTI badge as the 6R GTI grill?
Nicomati
Posts: 47 Joined: Tue Jan 27, 2015 9:27 pm
Drives: VW POLO 6R
Post
by Nicomati » Thu Mar 05, 2015 6:23 pm
Hi Mayhem,
I have small contacts in VW Navarra hehe... this steering wheel is very beautiful and it's very comfortable!!
It gives you a great change to the car!
Greetings.
Nicomati
Drives: VW POLO 6R
Post
by Nicomati » Thu Mar 05, 2015 6:31 pm
Mart!n-GTI-DK wrote: Can I get the Part number for the 6C GTI grill?¨
Hi Mart!n,
thanks for the comment!!!
sorry i bought the Gti grill in Ebay and i havent the part number of the item...
yes, the grill 6C GTI has the same ''flat spot'' s**t...I bought a tsi emblem to cover this part of the grill.
I will upload photos when you have received this!
Greetings.
Mart!n-GTI-DK
Post
by Mart!n-GTI-DK » Thu Mar 05, 2015 6:42 pm
Nicomati wrote: Hi Mart!n,
yes, the grill 6C GTI has the same ''flat spot'' ****...I bought a tsi emblem to cover this part of the grill.
Greetings.
The part number is stamped on the back... Just want to confirm that it is:
6C0 853 651 E WYR
Nicomati
Drives: VW POLO 6R
Post
by Nicomati » Thu Mar 05, 2015 8:09 pm
Mart!n-GTI-DK wrote: Nicomati wrote: Hi Mart!n,
Greetings.
6C0 853 651 E WYR
Oh, didn't know where it was item number. When take the car will look the reference!
IZVVC
Posts: 142 Joined: Sat May 10, 2014 6:45 pm
Post
by IZVVC » Fri Mar 06, 2015 4:29 pm
Great looking car!
is the steering wheel a straight swap?
Mart!n-GTI-DK
Post
by Mart!n-GTI-DK » Fri Mar 06, 2015 4:32 pm
IZVVC wrote: Great looking car!
If you don't have buttons, Then yes.
Mart!n-GTI-DK
Post
by Mart!n-GTI-DK » Mon Mar 09, 2015 3:02 pm
Did you get a chance to confirm the part number with the one on your GTI grill?
Nicomati
Drives: VW POLO 6R
Post
by Nicomati » Thu Mar 12, 2015 8:30 pm
Mart!n-GTI-DK wrote: Did you get a chance to confirm the part number with the one on your GTI grill?
Sorry for the delay Mart!n.. I was so busy with examns, work, etc....
I attached the bill. You can see the reference of the piece!
Greetings.
Mart!n-GTI-DK
Post
by Mart!n-GTI-DK » Thu Mar 12, 2015 9:16 pm
Thanks.
Just needed to be completly sure before I ordered one both ciclo and I had found the same number. But I just needed the finale bit of proof.
Nicomati
Drives: VW POLO 6R
Post
by Nicomati » Thu May 07, 2015 5:40 pm
Hi at All!
Sorry for being absent! Between the work and the university i've been very busy.
In this time i've done a little modifications in my polo! The first and the most important is the OEM bixenon headlights that with ciclo's help may that all the lamps work as the OEM lamp. The other modification it's coming soon and are the sideskirts of vw polo 9n3 bluemotion!! very rare here in spain! i attached a few pictures! enjoy with this!! regards!
Nicomati
Drives: VW POLO 6R
Post
by Nicomati » Thu May 07, 2015 5:54 pm
Posts: 6694 Joined: Fri Nov 14, 2014 2:14 pm
Post
by iichel » Thu May 07, 2015 6:36 pm
wow looks good, those OEM xenons and the 6C grill!!
Nicomati
Drives: VW POLO 6R
Post
by Nicomati » Tue May 12, 2015 4:20 pm
Recently arrived from Germany!!!
Regards!!!
Post
by iichel » Tue May 12, 2015 6:11 pm
if you're going full OEM, this is what you'll need too:
Adapter
1J0973737 14 pin
1J0973835 10 pin
headlight washers
6R0 955 453 G enlarged reservoir
6R0 955 681 second pump
1J0 973 722 A terminal connector to pump
7M0 919 376 sensor for water level
7M0 919 382 O-ring sensor
7M0 973 202 connector sensor
6R0 955 970 B hoses to washers
6R0 955 978 A washer left
6R0 955 103 A washer right
automatic leveling
6R0 941 273 B sensor axle
6R0 907 357 module leveling
6R0 612 405 holder on rear axle
Dashboard
6Q0 941 334 adjustment of interior lighting (without manual headlight leveling)
wiring looms
* BCM to headlight
* wirings to pump and water level sensor
* wiring loom automatic leveling
