Page 2 of 72
Re: iichels Polo 6R 1.2TDI Bluemotion
Posted: Fri Mar 27, 2015 12:37 am
by IZVVC
HI THERE MATE GREAT INTRO, and beautiful car, just have a question on how you got the piano black trim on the inside, and where you got it from?
As I'm really looking to get the trim around the heater controls!
:mrgreen:
thanks in advance buddy
Posted: Fri Mar 27, 2015 6:31 am
by iichel
Hi! I got them second hand. In germany there's currently a set. look for 'Polo 6R Klavierlack' (klavierlack = piano laquer). They are from a GTI, but also come on the R-Line and the Blue GT
Posted: Fri Mar 27, 2015 1:46 pm
by ciclo
New specific coding for your BCM
3CB02BBF0821000021280F917EEB9ED95AC0673F7E2D30D1A00000030000
RLS: 06302D
copy and paste :lol:
It includes
- All changes you previously had.
- DRLs off when up the handbrake.
- Static cornering lights when reverse gear.
- Single LED DRL off when indicator is blinking.
- Automatic lights in headlights. CH/LH.
Notes:
- Wirings without diodes or capacitors (very important).
- Automatic lights wiring must be installed.
- Byte27, can be 01, 02, 03 HEX, I'm not sure, try from highest to lowest.
Good luck!
Tell us the results. :)
Posted: Fri Mar 27, 2015 3:56 pm
by IZVVC
iichel wrote:Hi! I got them second hand. In germany there's currently a set. look for 'Polo 6R Klavierlack' (klavierlack = piano laquer). They are from a GTI, but also come on the R-Line and the Blue GT
where should i look?
thanks for your help so far!
Posted: Fri Mar 27, 2015 4:29 pm
by iichel
@ciclo
Thanks, your enthousiasm and energy amazes me every time haha :)
Does this also include the light and rain sensor already? :) or where does the RLS (rain and light sensor) code go? 09 central electrics and then in the drop down menu for different modules?
@IZVVC
This is the eBay search term. I see they are already gone:
http://www.ebay.de/itm/VW-Polo-6R-6C-GT ... 2c984f86b8
You can put a RSS feed on this or check it regularly:
http://www.ebay.de/sch/i.html?_from=R40 ... k&_sacat=0
Posted: Sun Mar 29, 2015 10:43 am
by iichel
ciclo wrote:New specific coding for your BCM
RLS: 06302D
It includes
Notes:
Good luck!
ciclo thank you very much for this code.
the results:
- rain sensor works
- intermittent wipers work
- light sensor shows measurement values
- dimming mirror works
- dimming mirror works in reverse
- LED als DRL works
- LED as parking lights work
- Xenon low beam works
- Xenon high beam works when xenon on
- Cornering lights work in headlight
- Fog lights work
- DRL off when handbrake on wokrs
- Both cornering lights on in reverse works
- Single LED off for DRL with indicator
What does not work:
- High beam signal with xenon off
- Still flashing LEDs
Errors in BCM:
- no errors found related to lighting.
Posted: Sun Mar 29, 2015 1:25 pm
by ciclo
Try the following:
To Highbeam
Byte27------00 HEX
Byte21------0D HEX
To LEDs
All bytes are correct for leds, so I guess it has to be related to the BCM software. This is beyond my knowledge.
Unfortunately you have to use capacitors.
We have almost gotten that all lights operate in your retrofitting of xenon. (many interesting things about it)
Only remains to be checked LED license plate lights. (without resistance)
CH/LH? Have you softened the windshield?
Posted: Sun Mar 29, 2015 1:46 pm
by iichel
I have OEM LED license plate lights and they work.
The windshield has been softenend indeed as suggested with a P2000 grit sand paper. It now works perfect.
I will try the other codes.
Posted: Sun Mar 29, 2015 2:05 pm
by iichel
so still no luck in high beam going on when giving a signal
CH/LH does work
Posted: Sun Mar 29, 2015 3:47 pm
by ciclo
Ok. The problem is the cable running to PIN 37. BLACK CONNECTOR BCM https://drive.google.com/file/d/0B2nv91 ... edit?pli=1
Checks that is fully inserted, that's the only problem, when fully inserted, everything will work correctly, you can be sure.
Posted: Sun Mar 29, 2015 4:12 pm
by iichel
Yep that was the problem.
I kind of feel stupid now haha :oops:
Posted: Sun Mar 29, 2015 4:18 pm
by ciclo
So now everything works correctly?
Posted: Sun Mar 29, 2015 4:39 pm
by iichel
yep!
Posted: Sun Mar 29, 2015 7:16 pm
by grem
Where did you get the pianno black interior parts, Im in the UK and cant find them anywhere. Also do you have any photos of the gear stick and how you did the black roof lining?
Cheers great project!
Posted: Sun Mar 29, 2015 7:37 pm
by Mart!n-GTI-DK
grem wrote:Where did you get the pianno black interior parts, Im in the UK and cant find them anywhere. Also do you have any photos of the gear stick and how you did the black roof lining?
Those parts are all available at you local VW dealer.
