Pull off the cover that is exposed when you open your door (on a level with the steering wheel) Its full of good grounding points.deltalimamike wrote:Thanks ill have a proper look when I'm not suited up in a Services car park.alexperkins wrote:Normally one to the right hand side of the fusebox near the bonnet pull
Cigarette lighter socket
Re: Cigarette lighter socket
deltalimamike
- Drives: GT TSI
Thanks ill take a look.rsmagee wrote:Pull off the cover that is exposed when you open your door (on a level with the steering wheel) Its full of good grounding points.deltalimamike wrote:Thanks ill have a proper look when I'm not suited up in a Services car park.alexperkins wrote:Normally one to the right hand side of the fusebox near the bonnet pull
- Bigtam
- Drives: Polo GTI 2016
I am just waiting on the piggy back fuse arriving will let you know how I get on once I have done it
