Page 2 of 3
Re: Solution needed for replacement for TPK
Posted: Thu Apr 21, 2016 9:10 pm
by Willni
rcd310 is just your basic radio unit with fm/am/dab
rcd510 is a touch screen unit with a 6.5inch touch screen but no handsfree but can have it fitted
RNS 310/315 is a 4.5inch touch screen with maps and bluetooth built in
rns510 is a 6.5 inch touchscreen with maps but no bluetooth in it but can be fitted to it
I have the tpk bluetooth kit vw offer that i don't use, but at this time i haven't removed the microphone for it yet (it's hooked up to the ignition and cba)
Posted: Sun Apr 24, 2016 9:32 am
by jambokaos87
I am also looking for an all in one solution for my 14 plate Polo. A lot of the head units I've seen do not have DAB radios included which is quite important for me.
Posted: Sun Apr 24, 2016 10:06 pm
by Willni
jambokaos87 wrote:I am also looking for an all in one solution for my 14 plate Polo. A lot of the head units I've seen do not have DAB radios included which is quite important for me.
http://www.ebay.co.uk/itm/VW-RNS315-GPS ... SwQYZWv3Vv
something like that if you want bluetooth and dab built in
Posted: Mon Apr 25, 2016 6:17 am
by jambokaos87
Cheers Willni.
Is it a straight forward job to swap out the old unit? Would I no longer need the TPK Mount?
Posted: Mon Apr 25, 2016 6:18 am
by alexperkins
Very simple and yes the TPK can be removed
Posted: Mon Apr 25, 2016 6:46 am
by jambokaos87
Cheers mate. Ordered one now :D
Posted: Mon Apr 25, 2016 3:26 pm
by MattBlueGT
Jambo, did you order it from that eBay link?
Posted: Mon Apr 25, 2016 3:28 pm
by MattBlueGT
Alex, so you don't need any part of the tpk system with the 315 as its all internal? Also, I don't know if I have a gps antenna so will I need to fit one with it?
Posted: Mon Apr 25, 2016 3:40 pm
by alexperkins
You'll need a GPS antenna if it doesn't come with one plus a microphone if it doesn't come with one
Posted: Tue Apr 26, 2016 6:11 am
by jambokaos87
MattBlueGT wrote:Jambo, did you order it from that eBay link?
No mate, decided to hang fire until Friday (pay day) :)
Posted: Tue Apr 26, 2016 6:41 am
by jambokaos87
Couple of questions that I have before I take the plunge:
1) Will my existing DAB aerial (for RCD 310) work with the new RS 315?
2) Will the installed mic for the TPK kit (seems to be tucked behind the tim of the driver's side A-pillar) work with the new unit?
Posted: Tue Apr 26, 2016 8:18 am
by alexperkins
Yes same connection and no you need the appropriate mic
I'll post a link shortly
Posted: Tue Apr 26, 2016 8:29 am
by Willni
Here's the link for the microphone (it will sit hidden in at the dome lights)
http://www.ebay.co.uk/itm/VW-RNS315-RCD ... SwZd1VaDzp
And here's the sat nav antenna (if it's magnetic just sit it onto the back of the unit and it will work, that's what I did)
http://www.ebay.co.uk/itm/SAT-NAV-GPS-A ... xyrrpTfL5O
Posted: Tue Apr 26, 2016 8:32 am
by alexperkins
Ta willni. Saves me looking 8)
Posted: Tue Apr 26, 2016 11:00 am
by jambokaos87
Thanks very much guys
