Polo 6R 1.6 TDI with Amarok cluster
gti16
Drives: VW Polo 6r 1.6 TDI
Re: Polo 6R 1.6 TDI with Amarok cluster
Post by gti16 »
smg_shardul wrote: Mon Jul 24, 2017 4:46 am
gti16 wrote:
smg_shardul wrote: Sat Jul 22, 2017 3:53 am
What is eeprom?
I have purchased cluster on eBay it's used cluster
I have requested vw to install let's see what they do.
Eeprom is a component where all the definitions of the cluster are.
To access it is necessary to disassemble the entire cluster because it is located below the central display.
We need to change that component?
As this component is cheap you can replace and save the original.
The procedure is to extract the data from the eeprom and change the required fields and write again to the same eeprom or write to another without changing the original.
gelotus
Drives: 6r 1.6 TDI Highline
Post by gelotus »
A question to who have the amarok dashboard retrofitted in their car;
I've done swap, everything works correctly but the boot lid open warning doesn't.
If I test it with vcds, in the measurement channel IDE00303-MAS00222 there is there is the right behaviour, but nothing appears in the display.
The other doors works correctly.
Maybe because Amarok is a pickup, they have disabled the boot lid open warning in the eeprom.
Someone knows at which offset lies this setting so I can turn it on?
Thank you
gelotus
Post by gelotus »
In the end I was able to solve all the adaption issues with a massive multiple eeprom comparing from various models and versions. There are big changes in 1xxx eeprom layout, that was long and tedious. Brake fluid ok, speed signal ok, boot lid ok, fuel tank ok, low fuel warning ok, picture ok.
definitely looking good
Batch88
Drives: 6r
Post by Batch88 »
@gelotus possible help me?I have fit amarok cluster on polo 6r but have problem with low level fuel and speed,have you a correct EEPROM parameters? thanks
I think you have o skodapilot eeprom softwate that helps you.
https://skodapilot.com/vdoeditor/?lang=en
Batch88
Drives: 6r
Post by Batch88 »
Thanks I have this program but it's very difficult found correct and working parameters
mahesh_parmar
Drives: Polo 6R
Post by mahesh_parmar »
Polo 6R 1.2 TDI
I buy Amarok cluste
I want to install in polo can you help me for editing eprom Brake fluid , speed signal , boot lid , fuel tank , low fuel warning , picture
Sw/ 1009
Hw/ h04
Help me gelotus
Tobi94b
Drives: Polo 6R 1.2TDI @105 PS
Post by Tobi94b »
Hey there,
I have also retrofitted the Amarok cluster to my 1.2 TDI Polo. Did all the adaptions and changes in the eeprom with VDOeditor and manually using some russian spreadsheat I found :lol:
Like gelotus I already have compared many eeprom saves, but to this date wasn't able to find where the boot lid warning light and the TMPS is beeing enabled.
I've been driving around without those features for a year now, but would like to enable them.
gelotus wrote: Wed Jan 06, 2021 11:22 pm In the end I was able to solve all the adaption issues with a massive multiple eeprom comparing from various models and versions. There are big changes in 1xxx eeprom layout, that was long and tedious. Brake fluid ok, speed signal ok, boot lid ok, fuel tank ok, low fuel warning ok, picture ok.
Gelotus if you could help me? DM would be appreciated so much.
Best regards,
Tobi :)
shakjaq1
Drives: 6R 1.6TDI
Post by shakjaq1 »
Tobi94b wrote: Fri Mar 17, 2023 2:07 am Hey there,
Best regards,
Tobi :)
Hey Tobi, were you able to find a fix for the boot lid warning? I've looked all around- translated the russian spreadsheet and searched around forums but i couldn't find a fix for it anywhere.
ivanv
Drives: 6R 75 hp 1.6 TDI
Post by ivanv »
Hello,
Where do you find information about that retrofit, I would like to do it, also. Can someone help me with that information?
Ask the AIs. If you ask the right questions (prompt), you'll get the right answers.
If you don't ask the right questions, try again creatively. πŸ‘¨β€πŸŽ“
Note:
AIs or GPT chats know almost everything, except what I know and the important things. πŸ§™β€β™‚οΈπŸ˜
Warning:
AIs lie, which is a great part of their creative nature... this sounds like something we know very well. :lol:
shakjaq1
Drives: 6R 1.6TDI
Post by shakjaq1 »
ciclo wrote: Sat Apr 18, 2026 4:31 pm Ask the AIs. If you ask the right questions (prompt), you'll get the right answers.
Note:
Warning:
Hi master ciclo
I've tried putting that spreadsheet in all SOA AIs to look for anything remotely close to boot/trunk/lid in russian, and all have returned with nothing. I also tried deep research modes on chatgpt and claude, and all they could return was link to other forums where other people have asked the same question and have received no replies. I am really surprised that this information is gatekept while all other info on retrofits has been generously shared by you, iichel, and many other members of this and drive2ru forum.
Is this what you're looking for?
https://www.drive2.ru/l/583175745765950173/
I haven't tested this program -Vag Dash Editor-. Instrument panels weren't one of my concerns.
"24C32-24C64_V2.xlsx"
:arrow: https://docs.google.com/spreadsheets/d/ ... ue&sd=true
ivanv
Post by ivanv »
Thank you for the advice, ciclo! Appreciate it, but I try to not use much AI for this kind of things, I work on a daily basis with AI and it lies a lot, and for some specific things it "halucinates". :wink: And this is a cluster, if something is messed up, the car won't start as I know.
shakjaq1
Drives: 6R 1.6TDI
Post by shakjaq1 »
ciclo wrote: Sun Apr 19, 2026 4:21 am Is this what you're looking for?
I looked into this spreadsheet as well, much the same. The issue is that when you run amarok instrument clusters on polo, even after correcting the display image, the rear boot lid being open doesn't show up on the display. All four doors open/close state does show up, but the boot remains static. People have found the solution to this, but unfortunately it hasn't been shared anywhere - not in the spreadsheet, not in any forums(that i could look up).
