Racechip Install
Robby_boi86
Drives: 6C GTI
Re: Racechip Install
Post by Robby_boi86 »
FerhaTopaLGT
Drives: BlueGT
Post by FerhaTopaLGT »
Any electric cable ?
Tapatalk kullanarak iPhone aracılığıyla gönderildi
Robby_boi86
Drives: 6C GTI
No nothing to connect to battery
FerhaTopaLGT
Drives: BlueGT
Ok I'm looking still
FerhaTopaLGT
Drives: BlueGT
Robby_boi86
Drives: 6C GTI
Thank you
Have you tried contacting racechip maybe?
Oli3000
Drives: 6C 1.0tsi 110 6spd man SEL
Post by Oli3000 »
iichel wrote: Thu Dec 07, 2017 1:01 pm Have you tried contacting racechip maybe?
This. Or even contacting the reseller - I wouldn't be connecting the box if I thought it was for the wrong engine! If the pictures are wrong - is the box wrong too?
Ricmondo
Drives: Polo Blue GT
Post by Ricmondo »
Racechip are very helpful, they will advise upon suitability, convertibility and installation. If you need a different harness they will supply.
Great company to deal with.
robbo32
Drives: 2015 6C Gti
Post by robbo32 »
Hi
To fit second connector you need to remove the engine undertray and then you will find the boost connector you need to connect to.
It's an awkward one to remove as there is an Air con pipe right in front of it.
Took me a bit of time to get it off, but once done the racechip on their supplied settings really transforms the car, makes it much sharper and more eager than factory.
Make sure when you tie wrap the racechip cables that you route them away from the radiator fans which are unshrouded and therefore you need to be careful.
