Cluster & fuel pump issue
Roffa230
- Drives: Polo 6N1 1.0
Re: Cluster & fuel pump issue
I have checked the wiring from the lambda sensor, and no visible cracks or breaks. However I met a Polo fan yesterday who was saying that it could be caused by a clogged injector. I searched a bit on the internet, and the symptoms seem to same i'm experiencing. Now my question is, are these injectors easy to remove so i can clean them. Or should i spend 3 times the average monthly salary to get them cleaned by the only company on the island that can do it?
Injectors have to be ultrasonically cleaned. It’s not something you can do yourself
The fault will be with the sensor. The injector won’t cause an oxygen error
