Gti+ LED headlights seem low
barrywi
Re: Gti+ LED headlights seem low
Mine were turned fully up by the garage and they are now too high so I will try to reduce the height and report back.....when it stops raining, if ever.
roywolfey
- Drives: 2018 Polo GTI +
You are in Cumbria. As an ex-Cumbrian I can ascertain that the odds are stacked against you.
barrywi
Flipping Southerners!
roywolfey
Oi, I’m a fellow Cumbrian, so still regard myself as a Northerner.
Just happen to be living down South these days.
fazzy
- Drives: GTi++/TT/TDi/190E
Thanks for the good info.roywolfey wrote: Thu Dec 20, 2018 4:27 pm Tweaked mine up a bit today. Here's a picture of said 6mm hex screw including recessed cross screwdriver slots. This is on a GTI+ with LED Headlights.
Using a 6mm Hex T-Bar I rotated both the N/S and O/S height screws an initial 180 degrees anti-clockwise to raise and will monitor the results.
Edit. It still felt a bit low after 180 degree turn on the height screws, a further 180 degree, so a full turn anti-clockwise in total on each headlamp height screw, and the beam pattern seems good after a road test.
